How do I update Pi-hole?
At this time, we cannot update Pi-hole from the Web interface as we need to restart the server, which would interrupt the update process.
Run the following command on your Pi-hole:
pihole -up
You will need to SSH into your machine or access it directly via a keyboard and monitor. Typically, Pi-hole is running as a headless server so SSH is the preferred choice to run the command.
Pi-hole v3.2.1 Released With Lots Of Fixes
The pihole Command With Examples
Pi-hole funktioniert nicht
Pihole Dashboard Keeps Breaking
Temporary failure in name resolution
Not able to update to release 4.0
Dnsmasq fails on Pi-hole 3.3
Pi-hole version is v4.2.2 (Latest: v4.3.2) doesnt update
Web Interface not showing any queries
PiHole randomly stop serving DNS
Pihole works after restarting dns but stops blocking ads after a few minutes
Dashboard not updating
DNS service not running and unable start
Can't checkout web FTLDEV
Blacklist problem
Pi-hole won’t work unless dns service is manually restarted after each boot
Can't connect to web interface (I have no idea what I'm doing)
"FTL offline" and "Lost connection to API"
Trouble blacklisting and blocking ads
I'm having trouble with my DNS and I don't know where to start troubleshooting
DNS working but items not getting blocked
Query Log bug tied to compression in lighttpd
Does FTLDNS support the "bogus-nxdomain" option and cache-size > 10000?
Pi hole not blocking on synology nas
[fixed] Pi-Hole newbie with DNS issues
Unexplained pi-hole fail
Posting debug -- Pihole doing nothing -- please help.
Unable to use unbound as upstream DNS server
Pi-hole error installing in ubuntu 18.04.3
Version mismatch shown for FTL
Pi-Hole Not Working (not resolving DNS)
How can I start IVP6
Error connecting to database, cannot repair
Bedeutungen der Warnungen im Debug Log
Raspberry Pi B+ Help with installing
Install Fail on DO 18.04 LTS Droplet
(solved) Pi-hole works on clients but not on the Raspi4 itself
Keine Internet verbindung
Pihole giving issues after php version got updated to 7.4
Client List not loading
Pi hole enabled but not blocking ads
PI-Hole auf Synology kein Zugriff von Windows auf DNS-Server PI-Hole
DNS service not running and FTL offline after last update
High CPU, High RAM, not working, dnsmasq issues? - Solved
10 posts were split to a new topic: Pi-hole command not found
A post was split to a new topic: Unable to update (FTL can't install)
