Unexplained pi-hole fail
[PiHole had been running very well (with unbound also acting as upstream DNS) for around a month without any issues.]
_[Suddenly and without any changes by myself PiHole stopped working. As I had this set as my sole DNS, and I also force all DNS traffic through this using firewall settings in Unifi gateway, this effectively knocked out my internet.
I was able to SSH in to my pi and also to look at the web interface.
The web interface showed that FTL was offline and also the DNS service. I could restrart the DNS briefly before it crashed again. FTL remained offline throughout.
I managed to temporarily deal with this by reverting my router to use an external DNS.
Meanwhile I did the following updated my Pi resolv.conf to an external DNS and then ran pihole -r
This seemed to fix the problem but I am reluctant to leave this without an answer as to why it broke.
While this is only a home network, having my pi setup as my sole DNS makes it fairly mission critical and so I am afraid this will happen again and a very inconvenient time so any thoughts on causes would be great.]_
_[*** [ INITIALIZING ]
[i] 2019-06-26:19:48:52 debug log has been initialized.
[i] Core: v4.3 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v4.3-0-g1d43c0a
[i] Web: v4.3 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v4.3-0-g44aff72
[?] FTL: v4.3 (How do I update Pi-hole?)
[i] 1.4.45
[i] 7.0.33
[?] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[?] armv7l
[?] IPv4 address(es) bound to the eth0 interface:
192.168.1.111/24 matches the IP found in /etc/pihole/setupVars.conf
[?] IPv6 address(es) bound to the eth0 interface:
fe80::fb64:adc1:d2d2:e66b does not match the IP found in /etc/pihole/setupVars.conf (Use IPv6 ULA addresses for Pi-hole)
  • Pinging 192.168.1.1...
    [?] Gateway responded.
:22 sshd (IPv4)
:22 sshd (IPv6)
127.0.0.1:5353 unbound (IPv4)
127.0.0.1:8953 unbound (IPv4)
:80] is in use by lighttpd
*:8080 java (IPv6)
*:8880 java (IPv6)
*:8443 java (IPv6)
*:8843 java (IPv6)
*:6789 java (IPv6)
127.0.0.1:27117 mongod (IPv4)
[?] Failed to resolve pepcriskalertus.club via localhost (127.0.0.1)
[?] Failed to resolve pepcriskalertus.club via Pi-hole (192.168.1.111)
[?] doubleclick.com is 172.217.169.78 via a remote, public DNS server (8.8.8.8)
[?] lighttpd daemon is active
[?] pihole-FTL daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.111/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=true
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
[?] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[?] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 15600162 Jun 23 03:49 /etc/pihole/gravity.list
-rotation.de
-sso.anbtr.com
-traffic.com
0-07.ru
zzzrtrcm2.com
zzzxxxcc.no-ip.biz
zzzyzs.net
zzzzzqp.com
-rw-r--r-- 1 root root 2509 May 25 18:20 /etc/pihole/adlists.list
https://adaway.org/hosts.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
https://v.firebog.net/hosts/Easylist.txt
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts;showintro=0
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/UncheckyAds/hosts
https://www.squidblacklist.org/downloads/dg-ads.acl
https://hosts-file.net/grm.txt
https://reddestdream.github.io/Projects/MinimalHosts/etc/MinimalHostsBlocker/minimalhosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/KADhosts/hosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Spam/hosts
https://v.firebog.net/hosts/static/w3kbl.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-blocklist.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.2o7Net/hosts
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
https://hosts-file.net/exp.txt
https://hosts-file.net/emd.txt
https://hosts-file.net/psh.txt
https://mirror.cedia.org.ec/malwaredomains/immortal_domains.txt
https://www.malwaredomainlist.com/hostslist/hosts.txt
https://bitbucket.org/ethanr/dns-blacklists/raw/8575c9f96e5b4a1308f2f12394abd86d0927a4a0/bad_lists/Mandiant_APT1_Report_Appendix_D.txt
https://v.firebog.net/hosts/Prigent-Malware.txt
https://v.firebog.net/hosts/Prigent-Phishing.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-malware.txt
https://ransomwaretracker.abuse.ch/downloads/RW_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/CW_C2_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/LY_C2_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/TC_C2_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/TL_C2_DOMBL.txt
https://v.firebog.net/hosts/Shalla-mal.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Risk/hosts
https://www.squidblacklist.org/downloads/dg-malicious.acl
-rw-r--r-- 1 root root 48 Jun 23 03:49 /etc/pihole/local.list
192.168.1.111 raspberrypi
192.168.1.111 pi.hole
-rw-r--r-- 1 root root 234 May 25 00:14 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1625 Jun 26 19:33 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
server=208.67.222.222
server=208.67.220.220
domain-needed
bogus-priv
interface=eth0
-rw-r--r-- 1 root root 3102 May 25 00:14 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
       "X-Frame-Options" => "DENY"
   $HTTP["url"] =~ ".ttf$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1704 May 25 00:14 /etc/cron.d/pihole
48 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
58 19 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 2024 Jun 26 19:49 /var/log/lighttpd/error.log
2019-06-23 06:25:03: (server.c.1534) logfiles cycled UID = 0 PID = 13258
2019-06-25 22:31:42: (log.c.217) server started
2019-06-25 23:07:37: (log.c.217) server started
2019-06-25 23:18:22: (log.c.217) server started
2019-06-25 23:41:25: (log.c.217) server started
2019-06-26 19:44:43: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2019-06-26 19:45:28: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 188
2019-06-26 19:45:28: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 189
2019-06-26 19:46:34: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2019-06-26 19:49:01: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 188
2019-06-26 19:49:01: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 189
-rw-r--r-- 1 pihole pihole 9930 Jun 26 19:34 /var/log/pihole-FTL.log
[2019-06-26 19:30:16.205 670] Shutting down...
[2019-06-26 19:30:16.680 670] Finished final database update
[2019-06-26 19:30:16.684 670] ########## FTL terminated after 71327360.0 ms! ##########
[2019-06-26 19:30:18.109 1817] Using log file /var/log/pihole-FTL.log
[2019-06-26 19:30:18.110 1817] ########## FTL started! ##########
[2019-06-26 19:30:18.110 1817] FTL branch: master
[2019-06-26 19:30:18.110 1817] FTL version: v4.3
[2019-06-26 19:30:18.110 1817] FTL commit: 9e8273b
[2019-06-26 19:30:18.110 1817] FTL date: 2019-05-18 16:00:39 -0400
[2019-06-26 19:30:18.110 1817] FTL user: pihole
[2019-06-26 19:30:18.110 1817] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-06-26 19:30:18.110 1817] SOCKET_LISTENING: only local
[2019-06-26 19:30:18.111 1817] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-06-26 19:30:18.111 1817] MAXDBDAYS: max age for stored queries is 365 days
[2019-06-26 19:30:18.111 1817] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-06-26 19:30:18.111 1817] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-06-26 19:30:18.111 1817] DBINTERVAL: saving to DB file every minute
[2019-06-26 19:30:18.111 1817] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-06-26 19:30:18.111 1817] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-06-26 19:30:18.111 1817] PRIVACYLEVEL: Set to 0
[2019-06-26 19:30:18.111 1817] IGNORE_LOCALHOST: Show queries from localhost
[2019-06-26 19:30:18.112 1817] BLOCKINGMODE: Null IPs for blocked domains
[2019-06-26 19:30:18.112 1817] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-06-26 19:30:18.112 1817] DBIMPORT: Importing history from database
[2019-06-26 19:30:18.112 1817] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-06-26 19:30:18.112 1817] PORTFILE: Using /var/run/pihole-FTL.port
[2019-06-26 19:30:18.112 1817] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-06-26 19:30:18.112 1817] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-06-26 19:30:18.112 1817] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-06-26 19:30:18.112 1817] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-06-26 19:30:18.113 1817] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-06-26 19:30:18.113 1817] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-06-26 19:30:18.113 1817] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-06-26 19:30:18.113 1817] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-06-26 19:30:18.113 1817] PARSE_ARP_CACHE: Active
[2019-06-26 19:33:53.088 2062] -> Unique domains: 149
[2019-06-26 19:33:53.088 2062] -> Unique clients: 15
[2019-06-26 19:33:53.088 2062] -> Known forward destinations: 1
[2019-06-26 19:33:53.088 2062] Successfully accessed setupVars.conf
[2019-06-26 19:33:53.097 2064] PID of FTL process: 2064
[2019-06-26 19:33:53.098 2064] Listening on port 4711 for incoming IPv4 telnet connections
[2019-06-26 19:33:53.099 2064] Listening on port 4711 for incoming IPv6 telnet connections
[2019-06-26 19:33:53.099 2064] Listening on Unix socket
[2019-06-26 19:33:53.102 2064] Received SIGHUP, reloading cache
[2019-06-26 19:33:53.102 2064] Blocking status is enabled
[2019-06-26 19:33:53.103 2064] INFO: No whitelist file found
[2019-06-26 19:33:53.103 2064] Compiled 0 Regex filters and 0 whitelisted domains in 0.3 msec (0 errors)
[2019-06-26 19:34:02.749 2064] /etc/pihole/gravity.list: parsed 733611 domains (took 9644.8 ms)
[2019-06-26 19:34:02.751 2064] New forward server: 208.67.220.220 (1/512)
[2019-06-26 19:34:02.757 2064] New forward server: 208.67.222.222 (2/512)
[2019-06-26 19:34:04.096 2064] Resizing "/FTL-strings" from 4096 to 8192
[2019-06-26 19:34:05.159 2064] !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[2019-06-26 19:34:05.160 2064] ----------------------------> FTL crashed! <----------------------------
[2019-06-26 19:34:05.160 2064] !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[2019-06-26 19:34:05.160 2064] Please report a bug at https://github.com/pi-hole/FTL/issues
[2019-06-26 19:34:05.160 2064] and include in your report already the following details:
[2019-06-26 19:34:05.160 2064] FTL has been running for 12 seconds
[2019-06-26 19:34:05.160 2064] FTL branch: master
[2019-06-26 19:34:05.160 2064] FTL version: v4.3
[2019-06-26 19:34:05.161 2064] FTL commit: 9e8273b
[2019-06-26 19:34:05.161 2064] FTL date: 2019-05-18 16:00:39 -0400
[2019-06-26 19:34:05.161 2064] FTL user: started as pihole, ended as pihole
[2019-06-26 19:34:05.161 2064] Received signal: Segmentation fault
[2019-06-26 19:34:05.161 2064] at address: 1996062720
[2019-06-26 19:34:05.162 2064] with code: SEGV_MAPERR (Address not mapped to object)
[2019-06-26 19:34:05.162 2064] Backtrace:
[2019-06-26 19:34:05.162 2064] B[0000]: /usr/bin/pihole-FTL(+0x1a25c) [0x46325c]
[2019-06-26 19:34:05.163 2064] B[0001]: /lib/arm-linux-gnueabihf/libc.so.6(__default_rt_sa_restorer+0) [0x76dd86c0]
[2019-06-26 19:34:05.163 2064] Thank you for helping us to improve our FTL engine!
[2019-06-26 19:34:05.163 2064] FTL terminated!
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 Jun 26 19:33 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 Jun 26 19:33 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 65536 Jun 26 19:33 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 12288 Jun 26 19:33 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 28 Jun 26 19:33 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 53248 Jun 26 19:33 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 393216 Jun 26 19:34 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Jun 26 19:33 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 8192 Jun 26 19:34 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 1844058 Jun 26 19:34 /var/log/pihole.log
-----head of pihole.log------
Jun 26 19:30:13 dnsmasq[670]: query[A] spectrum.s3.amazonaws.com from 192.168.1.245
Jun 26 19:30:13 dnsmasq[670]: forwarded spectrum.s3.amazonaws.com to 127.0.0.1
Jun 26 19:30:13 dnsmasq[670]: reply error is SERVFAIL
Jun 26 19:30:13 dnsmasq[670]: query[A] spectrum.s3.amazonaws.com from 192.168.1.1
[?] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[?] There was an error uploading your debug log.
  • A local copy of the debug log can be found at: /var/log/pihole_debug.log]_
You're running an outdated version of Pi-hole. The bug you encountered had been fixed in FTL v4.3.1, which we released on May 25.
Please update your Pi-hole and you should never see this bug again. Sorry for the inconvenience and thanks for using the Pi-hole!
That's good to hear. I updated the Pi-hole as part of my troubleshooting process, so hopefully this is solved.
Thanks for the speedy reply.
