(solved) Pi-hole works on clients but not on the Raspi4 itself
I use pi-hole in the very latest version on a Pi4, GB with the very latest Raspberry Pi OS (previously called Raspbian).
Pi-holes blocking works on the other devices on the network, but not on the Pi4 itself, where pi-hole is installed.
What am I doing wrong?
Greetings
Karl
Debug Token:This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2020-10-04:18:20:18 debug log has been initialized.
[i] Core: v5.1.2 (How do I update Pi-hole?)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.1.2-0-g6b536b7
[i] Web: v5.1.1 (How do I update Pi-hole?)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.1.1-0-ga03d1bd
[✓] FTL: v5.2
[i] 1.4.53
[i] 7.3.19
[✓] Distro: Raspbian
[✓] Version: 10
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.178.20/24 matches the IP found in /etc/pihole/setupVars.conf
fd00::acf6:d445:ee09:392b does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
fe80::1226:e7c5:dba9:179b does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.178.1
  • Pinging 192.168.178.1...
    [✓] Gateway responded.
[80] is in use by lighttpd
[53] is in use by pihole-FTL
[✓] adecn-w.atdmt.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] adecn-w.atdmt.com is 0.0.0.0 via Pi-hole (192.168.178.20)
[✓] doubleclick.com is 172.217.168.238 via a remote, public DNS server (8.8.8.8)
[✓] amazon.de.session-id-click.com is :: via localhost (::1)
[✗] Failed to resolve amazon.de.session-id-click.com via Pi-hole (fd00::826a:7d68:27bb:9d91)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.178.20/24
IPV6_ADDRESS=fd00::826a:7d68:27bb:9d91
PIHOLE_DNS_1=9.9.9.9
PIHOLE_DNS_2=149.112.112.112
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=true
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 5042176 Okt 4 16:21 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 12
updated 1601821310
gravity_count 83811
Last gravity run finished at: So 4. Okt 16:21:50 CEST 2020
----- First 10 Gravity Domains -----
localhost.localdomain
n2019cov.000webhostapp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
ns6.0pendns.org
dns.0pengl.com
ios.0pengl.com
0x4fc271.tk
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2020-09-30 22:03:18 2020-09-30 22:03:18 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2020-09-30 22:03:18 2020-09-30 22:03:18 Migrated from /etc/pihole/adlists.list
2 1 0 https://mirror1.malwaredomains.com/files/justdomains 2020-09-30 22:03:18 2020-09-30 22:03:18 Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 122 Okt 4 16:21 /etc/pihole/local.list
192.168.178.20 raspberrypi
fd00::826a:7d68:27bb:9d91 raspberrypi
192.168.178.20 pi.hole
fd00::826a:7d68:27bb:9d91 pi.hole
-rw-r--r-- 1 root root 234 Sep 30 22:03 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 15 Sep 30 22:03 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1393 Sep 30 22:03 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=9.9.9.9
server=149.112.112.112
interface=eth0
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Sep 30 22:03 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4066 Sep 30 22:03 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
       "X-Frame-Options" => "DENY"
   $HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1755 Sep 30 22:03 /etc/cron.d/pihole
36 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
16 17 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 304 Okt 4 17:13 /var/log/lighttpd/error.log
2020-10-04 00:00:01: (server.c.1759) logfiles cycled UID = 0 PID = 23544
2020-10-04 17:12:56: (server.c.2059) server stopped by UID = 0 PID = 1
2020-10-04 17:13:03: (server.c.1464) server started (lighttpd/1.4.53)
2020-10-04 17:13:03: (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 4335 Okt 4 17:27 /var/log/pihole-FTL.log
[2020-10-04 17:13:03.711 608M] Using log file /var/log/pihole-FTL.log
[2020-10-04 17:13:03.711 608M] ########## FTL started! ##########
[2020-10-04 17:13:03.711 608M] FTL branch: master
[2020-10-04 17:13:03.711 608M] FTL version: v5.2
[2020-10-04 17:13:03.711 608M] FTL commit: dbd4a69
[2020-10-04 17:13:03.711 608M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-04 17:13:03.711 608M] FTL user: pihole
[2020-10-04 17:13:03.711 608M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-04 17:13:03.711 608M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-04 17:13:03.711 608M] SOCKET_LISTENING: only local
[2020-10-04 17:13:03.711 608M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-04 17:13:03.711 608M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-04 17:13:03.711 608M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-04 17:13:03.711 608M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-04 17:13:03.711 608M] DBINTERVAL: saving to DB file every minute
[2020-10-04 17:13:03.711 608M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-04 17:13:03.711 608M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-04 17:13:03.711 608M] PRIVACYLEVEL: Set to 0
[2020-10-04 17:13:03.711 608M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-04 17:13:03.711 608M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-04 17:13:03.711 608M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-10-04 17:13:03.711 608M] DBIMPORT: Importing history from database
[2020-10-04 17:13:03.711 608M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-04 17:13:03.711 608M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-04 17:13:03.711 608M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-04 17:13:03.711 608M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-04 17:13:03.711 608M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-04 17:13:03.711 608M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-04 17:13:03.711 608M] PARSE_ARP_CACHE: Active
[2020-10-04 17:13:03.711 608M] CNAME_DEEP_INSPECT: Active
[2020-10-04 17:13:03.712 608M] DELAY_STARTUP: No delay requested.
[2020-10-04 17:13:03.712 608M] NICE: Set process niceness to -10 (default)
[2020-10-04 17:13:03.712 608M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-04 17:13:03.712 608M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-04 17:13:03.712 608M] Finished config file parsing
[2020-10-04 17:13:03.722 608M] Database version is 7
[2020-10-04 17:13:03.722 608M] Database successfully initialized
[2020-10-04 17:13:03.745 608M] New upstream server: 9.9.9.9 (0/1024)
[2020-10-04 17:13:03.752 608M] New upstream server: 149.112.112.112 (1/1024)
[2020-10-04 17:13:03.793 608M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-04 17:13:03.801 608M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-04 17:13:03.813 608M] Imported 5289 queries from the long-term database
[2020-10-04 17:13:03.813 608M] -> Total DNS queries: 5289
[2020-10-04 17:13:03.813 608M] -> Cached DNS queries: 1440
[2020-10-04 17:13:03.813 608M] -> Forwarded DNS queries: 2691
[2020-10-04 17:13:03.813 608M] -> Blocked DNS queries: 1158
[2020-10-04 17:13:03.813 608M] -> Unknown DNS queries: 0
[2020-10-04 17:13:03.813 608M] -> Unique domains: 350
[2020-10-04 17:13:03.813 608M] -> Unique clients: 2
[2020-10-04 17:13:03.813 608M] -> Known forward destinations: 2
[2020-10-04 17:13:03.813 608M] Successfully accessed setupVars.conf
[2020-10-04 17:13:03.829 610M] PID of FTL process: 610
[2020-10-04 17:13:03.829 610/T611] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-04 17:13:03.829 610/T613] Listening on Unix socket
[2020-10-04 17:13:03.831 610/T612] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-04 17:13:03.831 610M] Reloading DNS cache
[2020-10-04 17:13:03.832 610M] Blocking status is enabled
[2020-10-04 17:13:03.910 610M] INFO: No regex blacklist entries found
[2020-10-04 17:13:03.910 610M] INFO: No regex whitelist entries found
[2020-10-04 17:13:03.915 610M] Compiled 0 whitelist and 0 blacklist regex filters for 2 clients in 9.7 msec
[2020-10-04 17:27:56.951 610M] Resizing "/FTL-strings" from 8192 to 12288
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 Okt 4 17:13 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 144 Okt 4 17:13 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 4096 Okt 4 17:13 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 65536 Okt 4 17:13 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 28 Okt 4 17:13 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 77824 Okt 4 17:13 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4096 Okt 4 17:13 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 458752 Okt 4 17:59 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Okt 4 17:13 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 12288 Okt 4 17:27 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 20480 Okt 4 17:13 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Locale
LANG=de_DE.UTF-8
-rw-r--r-- 1 pihole pihole 95472 Okt 4 18:20 /var/log/pihole.log
-----head of pihole.log------
Oct 4 17:13:03 dnsmasq[610]: started, version pi-hole-2.81 cachesize 10000
Oct 4 17:13:03 dnsmasq[610]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Oct 4 17:13:03 dnsmasq[610]: warning: interface eth0 does not currently exist
Oct 4 17:13:03 dnsmasq[610]: using only locally-known addresses for domain use-application-dns.net
Oct 4 17:13:03 dnsmasq[610]: using nameserver 149.112.112.112#53
Oct 4 17:13:03 dnsmasq[610]: using nameserver 9.9.9.9#53
Oct 4 17:13:03 dnsmasq[610]: read /etc/hosts - 5 addresses
Oct 4 17:13:03 dnsmasq[610]: failed to load names from /etc/pihole/custom.list: No such file or directory
Oct 4 17:13:03 dnsmasq[610]: read /etc/pihole/local.list - 4 addresses
Oct 4 17:13:23 dnsmasq[610]: query[A] www.youtube.com from 192.168.178.23
Oct 4 17:13:23 dnsmasq[610]: forwarded www.youtube.com to 149.112.112.112
Oct 4 17:13:23 dnsmasq[610]: forwarded www.youtube.com to 9.9.9.9
Oct 4 17:13:23 dnsmasq[610]: reply www.youtube.com is
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 216.58.207.78
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 172.217.22.78
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 172.217.22.110
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 172.217.23.110
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 216.58.212.142
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 172.217.22.46
Oct 4 17:13:23 dnsmasq[610]: reply youtube-ui.l.google.com is 172.217.21.238
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[?] Would you like to upload the log? [y/N]
The Pi needs to be setup to use Pi-hole, the same as other clients. How you do this is a bit different on the Pi than with other clients, since Pi-hole is running on the Pi.
Your current nameserver is shown in file /etc/resolv.conf. You won't make any changes here, but make the changes in file /etc/dhcpcd.conf instead. You will see an entry similar to this in the dhcpcd.conf file:
interface eth0
static ip_address=192.168.0.155/24
static routers=192.168.0.1
If the nameserver is not the loopback address (as shown above), then change it to the loopback address, save the file and restart the Pi with sudo reboot now
Good evening.
Thank you very much for the quick response!
What would be the loopback address in your example?
This term does not mean anything to me - unfortunately.
Greetings
Karl
Most distributions come with a loopback network interface named "lo" and already configured with IP 127.0.0.1 out of the box:
The most common IPv4 address used is 127.0.0.1.
Commonly these loopback addresses are mapped to the hostnames, localhost or loopback.
127.0.0.1 is the loopback address. In the example I showed, that Pi is using Pi-hole for DNS on the loopback IP. You want your nameserver line to look the same.
Thank you to all giving advice.
I will try this tomorrow and report then how it worked.
Have a good night!
Karl
As a newcomer to the forum I cannot list other forum users by name,
I would like to thank those who helped me a lot with the loopback setting!
Works great!
Greetings
Karl
