Can't connect to web interface (I have no idea what I'm doing)
[Being able to connect to the web interface and see it working]
[Every step of the way has been a problem, and I am currently 6 hours into trying to get it to work and still no luck. I can't upload the debug, so I copied and pasted it. I am sorry if that doesn't help, as I can't use the web interface to load it correctly. I got all the way to configuring my router with primary DNS server being the pi zero w, and secondary being 8.8.8.8. So far, I haven't been able to connect to the web interface, and have had several red errors in the debugs. Every tutorial I have seen or potential fix has led to another thing that doesn't seem to be working. I am about to give up but giving this one last shot with you guys. This is my frist time doing any of this stuff, so I have no idea what I am doing clearly.]
_[
[i] Core: v3.3 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.3-0-g1e87850
[i] Web: v3.3 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0 (How do I update Pi-hole?)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.72
[i] 1.4.35
[i] 5.6.33
[✓] Raspbian GNU/Linux 8 (jessie)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
/opt/pihole/piholeDebug.sh: line 470: $'[\E[32m✓\E[0m] \E[32marmv6l\E[0m': comma nd not found
[✓] IPv4 address(es) bound to the wlan0 interface:
192.168.0.7/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the wlan0 interface:
fe80::ac5d:6d92:5f2f:e231 does not match the IP found in /etc/pihole/setupVar s.conf (Use IPv6 ULA addresses for Pi-hole)
As long as one of them is green, and it matches what is in /etc/pihole/setupV ars.conf, there is no need for concern.
The link to the FAQ is for an issue that sometimes occurs when the IPv6 addre ss changes, which is why we check for it.
[i] Default IPv4 gateway: 192.168.0.1
  • Pinging 192.168.0.1...
    [✓] Gateway responded.
[22] is in use by sshd
[80] is in use by lighttpd
*** [ DIAGNOSING ]: Name resolution (IPv4) using a random blocked domain and a k nown ad-serving domain
shuf: /etc/pihole/gravity.list: No such file or directory
dig: '' is not a legal name (unexpected end of input)
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (192.168.0.7)
[✓] doubleclick.com is 172.217.2.78 via a remote, public DNS server (8.8.8.8)
[✗] dnsmasq daemon is failed
[✓] lighttpd daemon is active
[✗] pihole-FTL daemon is unknown
PIHOLE_INTERFACE=wlan0
IPV4_ADDRESS=192.168.0.7/24
IPV6_ADDRESS=
PIHOLE_DNS_1=4.2.2.1
PIHOLE_DNS_2=4.2.2.2
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
[✗] X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Date: Fri, 16 Feb 2018 00:32:25 GMT
Server: lighttpd/1.4.35
[✓] X-Pi-hole: The Pi-hole Web interface is working!
ls: cannot access /etc/pihole/gravity.list: No such file or directory
head: cannot open ‘/etc/pihole/gravity.list’ for reading: No such file or direct ory
tail: cannot open ‘/etc/pihole/gravity.list’ for reading: No such file or direct ory
-rw-r--r-- 1 root root 234 Feb 15 05:04 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1509 Feb 15 05:04 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=4.2.2.1
server=4.2.2.2
interface=wlan0
-rw-r--r-- 1 root root 3027 Feb 15 05:04 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
index-file.names = ( "index.php", "index.html", "index.lighttpd.ht ml" )
compress.filetype = ( "application/javascript", "text/css", "text/h tml", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'let sencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
       "X-Frame-Options" => "DENY"
   $HTTP["url"] =~ ".ttf$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Feb 15 05:04 /etc/cron.d/pihole
31 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker loc al
11 19 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remo te
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote rebo ot
-rw-r--r-- 1 www-data www-data 291 Feb 16 00:21 /var/log/lighttpd/error.log
2018-02-15 05:03:54: (log.c.164) server started
2018-02-15 05:21:55: (server.c.1558) server stopped by UID = 0 PID = 1
2018-02-15 05:22:09: (log.c.164) server started
2018-02-16 00:21:33: (server.c.1558) server stopped by UID = 0 PID = 1
2018-02-16 00:21:47: (log.c.164) server started
-rw-r--r-- 1 dnsmasq root 0 Feb 15 05:04 /var/log/pihole.log
]_
I have also heard something about making it a gateway, but I have no idea how to do that. I also don't have static IPs for everything on the network. The PI zero w is static, and I am not sure if that is maybe messing things up. I also couldn't connect to github for an FTL update that failed to load. I am currently at that step but cannot figure that out. I did this headless as well.
[✗] Job for dnsmasq.service failed. See 'systemctl status dnsmasq.service' and 'journalctl -xn' for details.
pihole-FTL: no process found
[✗] DNS service is NOT running
Here is what it says in regard to the FTL thing.
Are you able to update Jessie to Stretch ? Or maybe easier reinstall with Stretch ?
Or else read this:
https://pi-hole.net/2018/02/14/pi-hole-v3-3-released-its-extra-special/
I initially used the stretch, but I couldn't get to the point where I am currently at with it. I don't believe I was able to Putty into it with stretch. However after learning some stuff I will retry it since I was most likely doing things wrong. I looked on some forums and heard that the Jessie was better for the pi zero w. My friend was successful doing his by setting everything up in a pi3 (so he didn't have to headless), then placing it into the Pi zero W to ssh the batch onto it. I will give you an update this evening hopefully.
The "sshd" daemon is not started default at boot with Raspbian Stretch like it does with Jessie (see point 2):
https://www.raspberrypi.org/documentation/remote-access/ssh/
I appreciate the help. I was trying to do headless, and just couldn't figure it out, so I had my friend help me. I ended up putting the Mirco sd into my pi3 just so I didn't have to buy a new keyboard, and was able to do it not headless. I ended up formatting the micro sd and using stretch. Through the pi3 I was able to switch the settings to wlan0 and make sure the ip settings were correct. Reinstalled with a fresh pihole and eventually after another few hours got it working. It turns out in the wpa_supplicant.conf file, I was missing the four command lines above the ssid info, i.e. the country=US etc. stuff. That was what was causing my problem with connecting at home. My router was also reassigning the pi the reserved ip it gave it originally. So matter what I was changing it too, I could never putty or admin in because it kept switching to default. It was an absolute cluster but it works now and I am happy. The next step is figuring out how to get correct stats on the web interface instead of showing localhost for half of them.
