Install Fail on DO 18.04 LTS Droplet
Pihole successfully installs on DO 18.04 LTS droplet
Install fails with a message that "DNS resolution is not available, trying again in 180 secs"
I've read various different posts regarding how to fix this failure, however having tried multiple times I'm still in the dark as to why it doesn't work.
Has anyone managed to male Pihole work on an 18.04 server on DO and, if so, what is the workaround.
If it helps, this is the output from the install command.
[ ✓ ] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[ ✓ ] Update local cache of available packages
[ ✓ ] Disk space check
[ ✓ ] Checking apt-get for upgraded packages... 16 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[i] Checking for dhcpcd5 (will be installed)
[ ✓ ] Checking for git
[ ✓ ] Checking for iproute2
[ ✓ ] Checking for whiptail
[ ✓ ] Checking for dnsutils
[i] Processing apt-get install(s) for: dhcpcd5, please wait...
Selecting previously unselected package dhcpcd5.
(Reading database ... 60123 files and directories currently installed.)
Preparing to unpack .../dhcpcd5_6.11.5-0ubuntu1_amd64.deb ...
Unpacking dhcpcd5 (6.11.5-0ubuntu1) ...
Setting up dhcpcd5 (6.11.5-0ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for ureadahead (0.100.0-21) ...
Processing triggers for systemd (237-3ubuntu10.42) ...
[ ✓ ] Supported OS detected
[i] SELinux not detected
[i] Using upstream DNS: OpenDNS (ECS) (208.67.222.222, 208.67.220.220)
[i] Your static IPv4 address: xxx.128.174.xxx
[i] Your static IPv4 gateway: xxx.128.160.xxx
[ ✓ ] Set IP address to xxx.128.174.xxx
[i] You may need to restart after the install is complete
[i] Unable to find IPv6 ULA/GUA address, IPv6 adblocking will not be enabled
[i] IPv4 address: xxx.128.174.xxx
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[ ✗ ] Check for existing repository in /etc/.pihole
[i] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole...HEAD is now at 6b536b7 Merge pull request #3564 from pi-hole/release/v5.1.2
[ ✓ ] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole
[ ✗ ] Check for existing repository in /var/www/html/admin
[i] Clone https://github.com/pi-hole/AdminLTE.git into /var/www/html/admin...HEAD is now at a03d1bd Merge pull request #1498 from pi-hole/release/v5.1.1
[ ✓ ] Clone https://github.com/pi-hole/AdminLTE.git into /var/www/html/admin
[i] Main Dependency checks...
[ ✓ ] Checking for cron
[ ✓ ] Checking for curl
[ ✓ ] Checking for iputils-ping
[ ✓ ] Checking for lsof
[i] Checking for netcat (will be installed)
[ ✓ ] Checking for psmisc
[ ✓ ] Checking for sudo
[i] Checking for unzip (will be installed)
[ ✓ ] Checking for wget
[i] Checking for idn2 (will be installed)
[i] Checking for sqlite3 (will be installed)
[ ✓ ] Checking for libcap2-bin
[ ✓ ] Checking for dns-root-data
[i] Checking for lighttpd (will be installed)
[i] Checking for php-common (will be installed)
[i] Checking for php-cgi (will be installed)
[i] Checking for php-sqlite3 (will be installed)
[i] Checking for php-xml (will be installed)
[i] Checking for php-intl (will be installed)
[i] Processing apt-get install(s) for: netcat unzip idn2 sqlite3 lighttpd php-common php-cgi php-sqlite3 php-xml php-intl, please wait...
Selecting previously unselected package libgamin0.
(Reading database ... 60147 files and directories currently installed.)
Preparing to unpack .../00-libgamin0_0.1.10-5build1_amd64.deb ...
Unpacking libgamin0 (0.1.10-5build1) ...
Selecting previously unselected package gamin.
Preparing to unpack .../01-gamin_0.1.10-5build1_amd64.deb ...
Unpacking gamin (0.1.10-5build1) ...
Selecting previously unselected package libsodium23:amd64.
Preparing to unpack .../02-libsodium23_1.0.16-2_amd64.deb ...
Unpacking libsodium23:amd64 (1.0.16-2) ...
Selecting previously unselected package lighttpd.
Preparing to unpack .../03-lighttpd_1.4.45-1ubuntu3.18.04_amd64.deb ...
Unpacking lighttpd (1.4.45-1ubuntu3.18.04) ...
Selecting previously unselected package netcat-traditional.
Preparing to unpack .../04-netcat-traditional_1.10-41.1_amd64.deb ...
Unpacking netcat-traditional (1.10-41.1) ...
Selecting previously unselected package netcat.
Preparing to unpack .../05-netcat_1.10-41.1_all.deb ...
Unpacking netcat (1.10-41.1) ...
Selecting previously unselected package php-common.
Preparing to unpack .../06-php-common_1%3a60ubuntu1_all.deb ...
Unpacking php-common (1:60ubuntu1) ...
Selecting previously unselected package php7.2-common.
Preparing to unpack .../07-php7.2-common_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-common (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php7.2-json.
Preparing to unpack .../08-php7.2-json_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-json (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php7.2-opcache.
Preparing to unpack .../09-php7.2-opcache_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-opcache (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php7.2-readline.
Preparing to unpack .../10-php7.2-readline_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-readline (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php7.2-cli.
Preparing to unpack .../11-php7.2-cli_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-cli (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php7.2-cgi.
Preparing to unpack .../12-php7.2-cgi_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-cgi (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php-cgi.
Preparing to unpack .../13-php-cgi_1%3a7.2+60ubuntu1_all.deb ...
Unpacking php-cgi (1:7.2+60ubuntu1) ...
Selecting previously unselected package php7.2-intl.
Preparing to unpack .../14-php7.2-intl_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-intl (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php-intl.
Preparing to unpack .../15-php-intl_1%3a7.2+60ubuntu1_all.deb ...
Unpacking php-intl (1:7.2+60ubuntu1) ...
Selecting previously unselected package php7.2-sqlite3.
Preparing to unpack .../16-php7.2-sqlite3_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-sqlite3 (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php-sqlite3.
Preparing to unpack .../17-php-sqlite3_1%3a7.2+60ubuntu1_all.deb ...
Unpacking php-sqlite3 (1:7.2+60ubuntu1) ...
Selecting previously unselected package php7.2-xml.
Preparing to unpack .../18-php7.2-xml_7.2.24-0ubuntu0.18.04.6_amd64.deb ...
Unpacking php7.2-xml (7.2.24-0ubuntu0.18.04.6) ...
Selecting previously unselected package php-xml.
Preparing to unpack .../19-php-xml_1%3a7.2+60ubuntu1_all.deb ...
Unpacking php-xml (1:7.2+60ubuntu1) ...
Selecting previously unselected package sqlite3.
Preparing to unpack .../20-sqlite3_3.22.0-1ubuntu0.4_amd64.deb ...
Unpacking sqlite3 (3.22.0-1ubuntu0.4) ...
Selecting previously unselected package unzip.
Preparing to unpack .../21-unzip_6.0-21ubuntu1_amd64.deb ...
Unpacking unzip (6.0-21ubuntu1) ...
Selecting previously unselected package idn2.
Preparing to unpack .../22-idn2_2.0.4-1.1ubuntu0.2_amd64.deb ...
Unpacking idn2 (2.0.4-1.1ubuntu0.2) ...
Setting up idn2 (2.0.4-1.1ubuntu0.2) ...
Setting up unzip (6.0-21ubuntu1) ...
Setting up netcat-traditional (1.10-41.1) ...
Setting up sqlite3 (3.22.0-1ubuntu0.4) ...
Setting up libsodium23:amd64 (1.0.16-2) ...
Setting up php-common (1:60ubuntu1) ...
Created symlink /etc/systemd/system/timers.target.wants/phpsessionclean.timer → /lib/systemd/system/phpsessionclean.timer.
Setting up netcat (1.10-41.1) ...
Setting up php7.2-common (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/calendar.ini with new version
Creating config file /etc/php/7.2/mods-available/ctype.ini with new version
Creating config file /etc/php/7.2/mods-available/exif.ini with new version
Creating config file /etc/php/7.2/mods-available/fileinfo.ini with new version
Creating config file /etc/php/7.2/mods-available/ftp.ini with new version
Creating config file /etc/php/7.2/mods-available/gettext.ini with new version
Creating config file /etc/php/7.2/mods-available/iconv.ini with new version
Creating config file /etc/php/7.2/mods-available/pdo.ini with new version
Creating config file /etc/php/7.2/mods-available/phar.ini with new version
Creating config file /etc/php/7.2/mods-available/posix.ini with new version
Creating config file /etc/php/7.2/mods-available/shmop.ini with new version
Creating config file /etc/php/7.2/mods-available/sockets.ini with new version
Creating config file /etc/php/7.2/mods-available/sysvmsg.ini with new version
Creating config file /etc/php/7.2/mods-available/sysvsem.ini with new version
Creating config file /etc/php/7.2/mods-available/sysvshm.ini with new version
Creating config file /etc/php/7.2/mods-available/tokenizer.ini with new version
Setting up php7.2-sqlite3 (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/sqlite3.ini with new version
Creating config file /etc/php/7.2/mods-available/pdo_sqlite.ini with new version
Setting up php7.2-readline (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/readline.ini with new version
Setting up php7.2-json (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/json.ini with new version
Setting up php7.2-intl (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/intl.ini with new version
Setting up php-intl (1:7.2+60ubuntu1) ...
Setting up php-sqlite3 (1:7.2+60ubuntu1) ...
Setting up php7.2-opcache (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/opcache.ini with new version
Setting up php7.2-xml (7.2.24-0ubuntu0.18.04.6) ...
Creating config file /etc/php/7.2/mods-available/dom.ini with new version
Creating config file /etc/php/7.2/mods-available/simplexml.ini with new version
Creating config file /etc/php/7.2/mods-available/wddx.ini with new version
Creating config file /etc/php/7.2/mods-available/xml.ini with new version
Creating config file /etc/php/7.2/mods-available/xmlreader.ini with new version
Creating config file /etc/php/7.2/mods-available/xmlwriter.ini with new version
Creating config file /etc/php/7.2/mods-available/xsl.ini with new version
Setting up php-xml (1:7.2+60ubuntu1) ...
Setting up php7.2-cli (7.2.24-0ubuntu0.18.04.6) ...
update-alternatives: using /usr/bin/php7.2 to provide /usr/bin/php (php) in auto mode
update-alternatives: using /usr/bin/phar7.2 to provide /usr/bin/phar (phar) in auto mode
update-alternatives: using /usr/bin/phar.phar7.2 to provide /usr/bin/phar.phar (phar.phar) in auto mode
Creating config file /etc/php/7.2/cli/php.ini with new version
Setting up php7.2-cgi (7.2.24-0ubuntu0.18.04.6) ...
update-alternatives: using /usr/bin/php-cgi7.2 to provide /usr/bin/php-cgi (php-cgi) in auto mode
update-alternatives: using /usr/lib/cgi-bin/php7.2 to provide /usr/lib/cgi-bin/php (php-cgi-bin) in auto mode
Creating config file /etc/php/7.2/cgi/php.ini with new version
Setting up php-cgi (1:7.2+60ubuntu1) ...
Setting up gamin (0.1.10-5build1) ...
Setting up libgamin0 (0.1.10-5build1) ...
Setting up lighttpd (1.4.45-1ubuntu3.18.04) ...
Created symlink /etc/systemd/system/multi-user.target.wants/lighttpd.service → /lib/systemd/system/lighttpd.service.
Processing triggers for ufw (0.36-0ubuntu0.18.04.1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for libc-bin (2.27-3ubuntu1.2) ...
[ ✓ ] Enabling lighttpd service to start on reboot...
[ ✓ ] Creating user 'pihole'
[i] FTL Checks...
[ ✓ ] Detected x86_64 architecture
[ ✓ ] Downloading and Installing FTL
[ ✓ ] Installing scripts from /etc/.pihole
[ ✓ ] No dnsmasq.conf found... restoring default dnsmasq.conf...
[ ✓ ] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[ ✓ ] Creating directory for blocking page, and copying files
[ ✓ ] Backing up index.lighttpd.html
[ ✓ ] Installing sudoer file
[ ✓ ] Installing latest Cron script
[ ✓ ] Installing latest logrotate script
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[ ✓ ] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[✓] Disabling systemd-resolved DNSStubListener and restarting systemd-resolved
[✓] Restarting lighttpd service...
[✓] Enabling lighttpd service to start on reboot...
[i] Restarting services...
[✓] Enabling pihole-FTL service to start on reboot...
[✓] Restarting pihole-FTL service...
[i] Creating new gravity database
[i] Migrating content of /etc/pihole/adlists.list into new database
[✓] Deleting existing list cache
[✗] DNS resolution is currently unavailable
[✗] DNS resolution is not available
I attempted to generate a debug token using pihole -d however this process fails. Here is the echo of the debug output.
*** [ INITIALIZING ]
[i] 2020-08-23:15:25:40 debug log has been initialized.
[i] Core: v5.1.2 (How do I update Pi-hole?)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.1.2-0-g6b536b7
[i] Web: v5.1.1 (How do I update Pi-hole?)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.1.1-0-ga03d1bd
[✓] FTL: v5.2 (How do I update Pi-hole?)
[i] 1.4.45
[i] 7.2.24
[✗] Distro: Ubuntu
[✗] Error: Ubuntu is not a supported distro (https://docs.pi-hole.net/main/prerequisites/)
*** [ DIAGNOSING ]: SELinux
*** [ DIAGNOSING ]: Processor
[i] x86_64
178.128.174.213/20 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
10.16.0.5/16 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
178.128.174.213/32 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
fe80::38b8:66ff:fe39:7092> does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 178.128.160.1
  • Pinging 178.128.160.1...
    [✓] Gateway responded.
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[80] is in use by lighttpd
[53] is in use by pihole-FTL
dig: '' is not a legal name (unexpected end of input)
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (178.128.174.213)
[✓] doubleclick.com is 216.58.211.174 via a remote, public DNS server (8.8.8.8)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=178.128.174.213
IPV6_ADDRESS=
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-r--r-- 1 root root 98304 Aug 23 15:16 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 12
date: invalid date ‘@’
Last gravity run finished at:
----- First 10 Gravity Domains -----
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2020-08-23 15:16:42 2020-08-23 15:16:42 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2020-08-23 15:16:42 2020-08-23 15:16:42 Migrated from /etc/pihole/adlists.list
2 1 0 https://mirror1.malwaredomains.com/files/justdomains 2020-08-23 15:16:42 2020-08-23 15:16:42 Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 238 Aug 23 15:16 /etc/pihole/logrotate
/var/log/pihole.log {
su root syslog
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root syslog
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 15 Aug 23 15:16 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1399 Aug 23 15:16 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=208.67.222.222
server=208.67.220.220
interface=eth0
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Aug 23 15:16 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4066 Aug 23 15:16 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
       "X-Frame-Options" => "DENY"
   $HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1755 Aug 23 15:16 /etc/cron.d/pihole
12 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
43 16 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 874 Aug 23 15:25 /var/log/lighttpd/error.log
2020-08-23 15:16:33: (log.c.217) server started
2020-08-23 15:16:38: (server.c.1828) server stopped by UID = 0 PID = 1
2020-08-23 15:16:39: (log.c.217) server started
2020-08-23 15:25:56: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 227
2020-08-23 15:25:56: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 228
-rw-r--r-- 1 pihole pihole 7071 Aug 23 15:25 /var/log/pihole-FTL.log
[2020-08-23 15:16:41.882 22707M] Using log file /var/log/pihole-FTL.log
[2020-08-23 15:16:41.882 22707M] ########## FTL started! ##########
[2020-08-23 15:16:41.882 22707M] FTL branch: master
[2020-08-23 15:16:41.882 22707M] FTL version: v5.2
[2020-08-23 15:16:41.882 22707M] FTL commit: dbd4a69
[2020-08-23 15:16:41.882 22707M] FTL date: 2020-08-09 22:09:43 +0100
[2020-08-23 15:16:41.882 22707M] FTL user: pihole
[2020-08-23 15:16:41.882 22707M] Compiled for x86_64 (compiled on CI) using gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
[2020-08-23 15:16:41.882 22707M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-08-23 15:16:41.882 22707M] SOCKET_LISTENING: only local
[2020-08-23 15:16:41.882 22707M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-08-23 15:16:41.882 22707M] MAXDBDAYS: max age for stored queries is 365 days
[2020-08-23 15:16:41.882 22707M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-08-23 15:16:41.882 22707M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-08-23 15:16:41.882 22707M] DBINTERVAL: saving to DB file every minute
[2020-08-23 15:16:41.882 22707M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-08-23 15:16:41.882 22707M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-08-23 15:16:41.882 22707M] PRIVACYLEVEL: Set to 0
[2020-08-23 15:16:41.882 22707M] IGNORE_LOCALHOST: Show queries from localhost
[2020-08-23 15:16:41.882 22707M] BLOCKINGMODE: Null IPs for blocked domains
[2020-08-23 15:16:41.882 22707M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-08-23 15:16:41.882 22707M] DBIMPORT: Importing history from database
[2020-08-23 15:16:41.882 22707M] PIDFILE: Using /run/pihole-FTL.pid
[2020-08-23 15:16:41.882 22707M] PORTFILE: Using /run/pihole-FTL.port
[2020-08-23 15:16:41.882 22707M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-08-23 15:16:41.882 22707M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-08-23 15:16:41.882 22707M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-08-23 15:16:41.882 22707M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-08-23 15:16:41.882 22707M] PARSE_ARP_CACHE: Active
[2020-08-23 15:16:41.883 22707M] CNAME_DEEP_INSPECT: Active
[2020-08-23 15:16:41.883 22707M] DELAY_STARTUP: No delay requested.
[2020-08-23 15:16:41.883 22707M] NICE: Set process niceness to -10 (default)
[2020-08-23 15:16:41.883 22707M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-08-23 15:16:41.883 22707M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-08-23 15:16:41.883 22707M] Finished config file parsing
[2020-08-23 15:16:42.125 22707M] -> Cached DNS queries: 0
[2020-08-23 15:16:42.125 22707M] -> Forwarded DNS queries: 0
[2020-08-23 15:16:42.125 22707M] -> Blocked DNS queries: 0
[2020-08-23 15:16:42.125 22707M] -> Unknown DNS queries: 0
[2020-08-23 15:16:42.125 22707M] -> Unique domains: 0
[2020-08-23 15:16:42.125 22707M] -> Unique clients: 0
[2020-08-23 15:16:42.125 22707M] -> Known forward destinations: 0
[2020-08-23 15:16:42.125 22707M] Successfully accessed setupVars.conf
[2020-08-23 15:16:42.144 22710M] PID of FTL process: 22710
[2020-08-23 15:16:42.145 22710M] Reloading DNS cache
[2020-08-23 15:16:42.145 22710M] Blocking status is enabled
[2020-08-23 15:16:42.150 22710/T22714] Listening on Unix socket
[2020-08-23 15:16:42.150 22710/T22713] Listening on port 4711 for incoming IPv6 telnet connections
[2020-08-23 15:16:42.150 22710/T22712] Listening on port 4711 for incoming IPv4 telnet connections
[2020-08-23 15:16:42.181 22710M] SQLite3 message: no such table: domain_audit in "SELECT EXISTS(SELECT domain, CASE WHEN substr(domain, 1, 1) = '' THEN '' || substr(:input, - length(domain) + 1) ELSE :input END matcher FROM domain_audit WHERE matcher = doma (1)
[2020-08-23 15:16:42.182 22710M] gravityDB_open("SELECT EXISTS(... domain_audit ...)") - SQL error prepare: SQL logic error
[2020-08-23 15:16:42.182 22710M] SQLite3 message: no such table: domain_audit in "SELECT EXISTS(SELECT domain, CASE WHEN substr(domain, 1, 1) = '' THEN '' || substr(:input, - length(domain) + 1) ELSE :input END matcher FROM domain_audit WHERE matcher = doma (1)
[2020-08-23 15:16:42.182 22710M] gravityDB_count(0): Gravity database not available
[2020-08-23 15:16:42.182 22710M] gravityDB_count(3): Gravity database not available
[2020-08-23 15:16:42.182 22710M] WARN: Database query failed, assuming there are no blacklist regex entries
[2020-08-23 15:16:42.182 22710M] gravityDB_count(4): Gravity database not available
[2020-08-23 15:16:42.182 22710M] WARN: Database query failed, assuming there are no whitelist regex entries
[2020-08-23 15:16:42.182 22710M] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 0.5 msec
[2020-08-23 15:25:56.183 22710M] Reloading DNS cache
[2020-08-23 15:25:56.183 22710M] Blocking status is enabled
[2020-08-23 15:25:56.194 22710M] gravityDB_count(SELECT value FROM info WHERE property = 'gravity_count':wink: - SQL error step no more rows available
[2020-08-23 15:25:56.195 22710M] Count of gravity domains not available. Please run pihole -g
[2020-08-23 15:25:56.195 22710M] INFO: No regex blacklist entries found
[2020-08-23 15:25:56.195 22710M] INFO: No regex whitelist entries found
[2020-08-23 15:25:56.195 22710M] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 0.8 msec
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 331776 Aug 23 15:16 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 144 Aug 23 15:16 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 4096 Aug 23 15:16 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 98304 Aug 23 15:16 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 48 Aug 23 15:16 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 45056 Aug 23 15:16 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4096 Aug 23 15:16 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 262144 Aug 23 15:16 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Aug 23 15:16 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 Aug 23 15:16 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 4096 Aug 23 15:16 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Locale
LANG=C.UTF-8
-rw-r--r-- 1 pihole pihole 1333 Aug 23 15:25 /var/log/pihole.log
-----head of pihole.log------
Aug 23 15:16:42 dnsmasq[22710]: started, version pi-hole-2.81 cachesize 10000
Aug 23 15:16:42 dnsmasq[22710]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Aug 23 15:16:42 dnsmasq[22710]: LOUD WARNING: listening on 178.128.174.213 may accept requests via interfaces other than eth0
Aug 23 15:16:42 dnsmasq[22710]: LOUD WARNING: use --bind-dynamic rather than --bind-interfaces to avoid DNS amplification attacks via these interface(s)
Aug 23 15:16:42 dnsmasq[22710]: using only locally-known addresses for domain use-application-dns.net
Aug 23 15:16:42 dnsmasq[22710]: using nameserver 208.67.220.220#53
Aug 23 15:16:42 dnsmasq[22710]: using nameserver 208.67.222.222#53
Aug 23 15:16:42 dnsmasq[22710]: read /etc/hosts - 8 addresses
Aug 23 15:16:42 dnsmasq[22710]: failed to load names from /etc/pihole/custom.list: No such file or directory
Aug 23 15:16:42 dnsmasq[22710]: failed to load names from /etc/pihole/local.list: No such file or directory
Aug 23 15:25:56 dnsmasq[22710]: read /etc/hosts - 8 addresses
Aug 23 15:25:56 dnsmasq[22710]: failed to load names from /etc/pihole/custom.list: No such file or directory
Aug 23 15:25:56 dnsmasq[22710]: failed to load names from /etc/pihole/local.list: No such file or directory
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* curl failed, falling back to netcat for transmission.
nc: getaddrinfo for host "tricorder.pi-hole.net" port 9999: Temporary failure in name resolution
  • A local copy of the debug log can be found at: /var/log/pihole_debug.log
