pihole blocks ads on clients
Pihole works after restarting dns but stops blocking ads after a few minutes
1tdurbl232
##Debug Output:
e[3Je[He[2JThis process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2017-12-27:19:06:25 debug log has been initiated.
[i] Core: v3.2.1 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.2.1-0-ge602008
[i] Web: v3.2.1 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.2.1-0-g31dddd8
[✓] FTL: v2.13
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.19
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
ip address/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::3806:3cee:b056:dc89 does not match the IP found in /etc/pihole/setupVars.conf (Use IPv6 ULA addresses for Pi-hole)
- Pinging 192.168.1.1...
[✓] Gateway responded.
[22] is in use by sshd
[53] is in use by dnsmasq
[80] is in use by lighttpd
[✓] www.barbiemobi.cn is ip address via localhost (127.0.0.1)
[✓] www.barbiemobi.cn is ip address via Pi-hole (ip address)
[✓] doubleclick.com is 216.58.219.238 via a remote, public DNS server (8.8.8.8)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=ip address/24
IPV6_ADDRESS=
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
[✓] X-Pi-hole: A black hole for Internet advertisements.
[✓] X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 3720197 Dec 27 18:34 /etc/pihole/gravity.list
ip address 0.0.0.0
ip address 0000mps.webpreview.dsl.net
ip address 0001.2waky.com
ip address 000dom.revenuedirect.com
ip address zzsyw.com
ip address zztxdown.com
ip address zzz.clickbank.net
ip address zz.zeroredirect1.com
-rw-r--r-- 1 root root 633 Dec 18 18:16 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 79 Dec 27 19:05 /etc/pihole/blacklist.txt
dc.ads.linkedin.com
www.facebook.com
adservex.media.net
sharethrough.adnxs.com
-rw-r--r-- 1 root root 44 Dec 27 18:34 /etc/pihole/local.list
ip address raspberrypi
ip address pi.hole
-rw-r--r-- 1 root root 234 Dec 27 18:34 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 117 Dec 26 18:46 /etc/pihole/whitelist.txt
raw.githubusercontent.com
mirror1.malwaredomains.com
sysctl.org
zeustracker.abuse.ch
s3.amazonaws.com
hosts-file.net
-rw-r--r-- 1 root root 1516 Dec 27 18:34 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=208.67.222.222
server=208.67.220.220
interface=eth0
-rw-r--r-- 1 root root 3027 Dec 27 18:34 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1630 Dec 27 18:34 /etc/cron.d/pihole
47 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
55 17 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 4520 Dec 27 19:05 /var/log/lighttpd/error.log
2017-12-24 06:25:04: (server.c.1534) logfiles cycled UID = 0 PID = 5971
2017-12-26 18:46:09: (server.c.1828) server stopped by UID = 0 PID = 1
2017-12-26 18:46:10: (log.c.217) server started
2017-12-26 18:55:37: (server.c.1828) server stopped by UID = 0 PID = 1
2017-12-26 18:55:57: (log.c.217) server started
2017-12-27 17:57:55: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: file(http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=infoc2.duba.net&bp): failed to open stream: HTTP request failed! in /var/www/html/pihole/index.php on line 136
2017-12-27 17:57:55: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_filter() expects parameter 1 to be array, string given in /var/www/html/pihole/index.php on line 137
2017-12-27 17:57:55: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_values() expects parameter 1 to be array, null given in /var/www/html/pihole/index.php on line 137
2017-12-27 17:58:20: (server.c.1828) server stopped by UID = 0 PID = 1
2017-12-27 17:58:21: (log.c.217) server started
2017-12-27 17:59:31: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: file(http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=infoc2.duba.net&bp): failed to open stream: HTTP request failed! in /var/www/html/pihole/index.php on line 136
2017-12-27 17:59:31: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_filter() expects parameter 1 to be array, string given in /var/www/html/pihole/index.php on line 137
2017-12-27 17:59:31: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_values() expects parameter 1 to be array, null given in /var/www/html/pihole/index.php on line 137
2017-12-27 18:24:59: (server.c.1828) server stopped by UID = 0 PID = 1
2017-12-27 18:27:31: (log.c.217) server started
2017-12-27 18:31:35: (server.c.1828) server stopped by UID = 0 PID = 1
2017-12-27 18:34:22: (log.c.217) server started
2017-12-27 18:47:20: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2017-12-27 18:47:20: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2017-12-27 18:47:37: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2017-12-27 18:47:37: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2017-12-27 18:48:08: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2017-12-27 18:48:08: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2017-12-27 19:05:26: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2017-12-27 19:05:26: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
-rw-r--r-- 1 pihole pihole 15869 Dec 27 19:05 /var/log/pihole-FTL.log
[2017-12-27 00:00:02.298] Gravity list entries: 106669
[2017-12-27 00:00:02.298] No blacklist present
[2017-12-27 00:00:02.298] No wildcard blocking list present
[2017-12-27 00:00:02.298] Reading from /var/log/pihole.log.1 (rw-r--r--)
[2017-12-27 00:00:02.298] Notice: Increasing queries struct size from 0 to 10000 (320.25 KB)
[2017-12-27 00:00:02.298] Notice: Increasing overTime struct size from 0 to 100 (324.25 KB)
[2017-12-27 00:00:02.298] Notice: Increasing forwarded struct size from 0 to 4 (324.32 KB)
[2017-12-27 00:00:02.347] New forward server: 8.8.4.4 google-public-dns-b.google.com (0/4)
[2017-12-27 00:00:02.348] Notice: Increasing domains struct size from 0 to 1000 (344.36 KB)
[2017-12-27 00:00:02.348] Notice: Increasing clients struct size from 0 to 10 (344.53 KB)
[2017-12-27 00:00:02.348] New client: 127.0.0.1 localhost (0/10)
[2017-12-27 00:00:02.399] New forward server: 8.8.8.8 google-public-dns-a.google.com (1/4)
[2017-12-27 00:00:02.435] Notice: Increasing overTime struct size from 100 to 200 (349.63 KB)
[2017-12-27 00:00:02.469] New client: 10.8.0.2 (1/10)
[2017-12-27 00:00:02.535] New client: 10.8.0.3 (2/10)
[2017-12-27 00:00:02.565] New client: ip address raspberrypi (3/10)
[2017-12-27 00:00:02.593] Reading from /var/log/pihole.log (rw-r--r--)
[2017-12-27 17:19:50.262] NOTICE: Received signal SIGHUP - re-reading gravity files
[2017-12-27 17:19:50.472] Gravity list entries: 106669
[2017-12-27 17:19:50.473] No blacklist present
[2017-12-27 17:19:50.473] No wildcard blocking list present
[2017-12-27 17:31:19.563] New client: 10.8.0.4 (4/10)
[2017-12-27 17:58:23.005] FATAL: FTL received SIGTERM from PID/UID 15792/0, scheduled to exit gracefully
[2017-12-27 17:58:23.006] Shutting down...
-rw-r--r-- 1 dnsmasq root 557045 Dec 27 19:06 /var/log/pihole.log
-----head of pihole.log------
Dec 27 00:00:02 dnsmasq[935]: query[PTR] 4.4.8.8.in-addr.arpa from 127.0.0.1
Dec 27 00:00:02 dnsmasq[935]: forwarded 4.4.8.8.in-addr.arpa to 8.8.4.4
Dec 27 00:00:02 dnsmasq[935]: forwarded 4.4.8.8.in-addr.arpa to 8.8.8.8
Dec 27 00:00:02 dnsmasq[935]: reply 8.8.4.4 is google-public-dns-b.google.com
Dec 27 00:00:02 dnsmasq[935]: query[PTR] 8.8.8.8.in-addr.arpa from 127.0.0.1
Dec 27 00:00:02 dnsmasq[935]: forwarded 8.8.8.8.in-addr.arpa to 8.8.4.4
Dec 27 00:00:02 dnsmasq[935]: reply 8.8.8.8 is google-public-dns-a.google.com
Dec 27 00:00:02 dnsmasq[935]: query[PTR] 2.0.8.10.in-addr.arpa from 127.0.0.1
Dec 27 00:00:02 dnsmasq[935]: forwarded 2.0.8.10.in-addr.arpa to 8.8.4.4
Dec 27 00:00:02 dnsmasq[935]: query[PTR] 3.0.8.10.in-addr.arpa from 127.0.0.1
Dec 27 00:00:02 dnsmasq[935]: forwarded 3.0.8.10.in-addr.arpa to 8.8.4.4
Dec 27 00:00:02 dnsmasq[935]: query[PTR] 8.1.168.192.in-addr.arpa from 127.0.0.1
Dec 27 00:00:02 dnsmasq[935]: /etc/pihole/local.list ip address is raspberrypi
Dec 27 00:59:00 dnsmasq[935]: query[PTR] 2.0.8.10.in-addr.arpa from 127.0.0.1
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Using openssl for transmission.
[✓] Your debug token is: 1tdurbl232
- Provide the token above to the Pi-hole team for assistance at
- https://discourse.pi-hole.net
- Your log will self-destruct on our server after 48 hours.
- A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
