Will my pi zero still hold up to the new version, performance wise?
Probably will work even better actually.
Upgraded from 5.0 beta on Asus Tinkerboard (running dietpi) and RPI Zero-W (raspbian).
No problems at all, thanks!
5 posts were split to a new topic: Change a list
A post was split to a new topic: Host nameserver behavior in V5
Thanks everyone for this update. I swap between two pi-hole instances (PI and a container on my Synolgoy). I did the Pi update and started to point selected hardware towards it and it's working great. can't wait to take advantage of the per client configuration.
A post was split to a new topic: MAC Vendor database not updated with V5.0
Really like the new per-client blocking feature... thanks and donation sent!
A post was split to a new topic: Questions after V5.0 update
Thank you so much to all the devs and testers for a great job. This has been a very smooth upgrade!
Thanks alot devs, amazing ! ![]()
A post was split to a new topic: PHP and updating
3 posts were split to a new topic: Are new clients associated with a default group?
Everybody here says it but I must thank you too. This realease really solved my "problem" with specific blocking because of new groups option. Now I can easilly associate extra regex domain for specific group (that's the difference between new and default group - not much but that's exactly what I need) so when I'm in "working mode" I can use that domain (it's associated only for default group) but right when I'm after work I can switch my device to default group (which has that specific regex extra) and I can see that those things are blocked now (and I don't have to add or remove that regex again and agin like before). Really nice and working feature!
And that local DNS records ... again thank you!
I already support this amazing project as a monthly patron.
The developers, including the staff, again invested a lot of work, time and research to offer us a new release with useful extensions and many improvements.
The whole Pi-hole team did and does great work, also with support here in the board.
Guys, you rock! My $100 donation is on its way to you.
They said they are currently thinking about how to improve this.
Source: Groups and DHCP - #7 by DL6ER
Yes, check out my most recent comment in the linked topic.
We're working on this. It is not all that straightforward as it may seem, especially since MAC addresses are only visible in the immediate vicinity of your Pi-hole (it will not work across routers, VLANs, etc.). You can monitor https://github.com/pi-hole/FTL/pull/762 for our progress. Currently, it is still a feature draft, albeit a working one. If you (or anyone else) want to test it at any point, it would be appreciated.
A post was split to a new topic: VPN Issues after 5.0 upgrade
A post was split to a new topic: Batch import whitelists
