Pi-Hole 5.1 - pihole -c (bug)
If I put this in the wrong place, I apologize. Not certain how to submit a bug.
I just updated to 5.1 and pihole -c shows FTL offline.
I have looked at the code and the reason is the file /var/run/pihole-FTL.port is empty.
If you populate the file with the correct informaton, then pihole -c will work
echo 4711 > /var/run/pihole-FTL.port
pihole -c
Please post solution here as well:
https://github.com/pi-hole/pi-hole/issues/3558#issuecomment-659520246
Thanks! Nice catch!
Bada bing! That did the trick. 1st time it wouldnt run so I had to sudo su 1st then run the echo and that worked nicely.
Thanks
Ditto with the "sudo su" to make the edit.
Thanks everyone!
Having the same issue with docker . Updated this file file with root but no luck .
echo 4711 > /var/snap/docker/common/var-lib-docker/overlay2/5f8552d8ed105df51274e390cf1/diff/run/pihole-FTL.port
UPDATE :Clearing cache resolved the issue
Use
echo 4711 | sudo tee /var/run/pihole-FTL.port
Root is needed to write the file.
4 posts were split to a new topic: Pihole chronometer connection refused
