I concatenated every BlockList I could find
Just some stats from a blocklist
https://ncloud.zaclys.com/index.php/s/MPYSjLkb8cE8gPN/download
https://ncloud.zaclys.com/index.php/s/2Tiwb43tGKQ3BSQ/download
Very expermential youtube list
https://ncloud.zaclys.com/index.php/s/TJkqZjCt99Xxjab/download
https://twitter.com/smokingwheels
Hey :slight_smile: I Like your Blocklists, but can't whitelist
uptobox.com
streamcloud.eu
soundcloud.com
and many more don't work, connection refused.
Nice work!
Just add the list to my installation but it's completely crippling my installation;
Active Temp: 36.9 °C
Load: 1.16 1.02 0.94
Memory usage: 68.4 %
Memory was <40% and load on average <0.3
Is this normal for an RaspberryPi 2B model?
Is this CPU use after gravity updated after you added the blocklists, or while gravity was updating?
What is the output of this command after you have the new blocklists in gravity?
echo ">stats" | nc localhost 4711
This was while updating gravity but also after some time.
This morning the only host "active" is my VPN connection from work to home with default gateway over PiHole and see the result;
just check "htop" and looks like FTL is eating a lot of mem & cpu time;
popup window with audio "you computer is blocked
Current blocklist 11:56 pm 26/11/18
Took longer than usual had to go and get my pihole.
a1089.dscd.akamai.neta2ss1.a2hosting.coma771.dscq.akamai.netacminvestmentgroup.techmediasolutions.comapple-finance.query.yahoo.comauthentication.logmeininc.combuilds.cdn.getgo.comcheckappexec.microsoft.comcheckout.stripe.comcobalten.comcohortaws-avmh-elb-03-2045070367.ap-southeast-2.elb.amazonaws.comcs9.wac.phicdn.netd3jdtixm7cvu7y.cloudfront.netdhwll352ue16m.cloudfront.netdjqa3u7clvbhe.cloudfront.netduomagazine.com.aue13678.dspb.akamaiedge.nete673.dsce9.akamaiedge.neteaxrxvbxdwjencrypted-tbn0.gstatic.comencrypted-tbn1.gstatic.comencrypted-tbn3.gstatic.cometlalumiere.comfp-vs.azureedge.netfp.msedge.netgo.pub2srv.comgoogleads.g.doubleclick.nethipointecare.comhispanicengineer.comi2.wp.comikimhxrhiincoming.telemetry.mozilla.orginternethealthreport.orgirujulhrms.rnrdatalex.comiteactive-mel01.msedge.netjs.stripe.comlaunch.getgo.comlaw.scu.edulb-hyuna-signup-us-east-1-p1.infra.systemslivetileedge.dsx.mp.microsoft.comlocation.services.mozilla.comlygdph9h-d9b9bb68427c9484cd3393d8b5daeeb25747782b-sac.d.aa.online-metrix.netm.stripe.commozilla.wpengine.commy.vultr.com.cdn.cloudflare.netmyessentials.competitioncentral.com.aunull-byte.wonderhowto.como-ring.msedge.netocsp.pki.googocsp.sca1b.amazontrust.comolympia.prod.mozaws.netp58-ckdatabase.fe.apple-dns.netpagead2.googlesyndication.comparaquadtas.org.aupgl.yoyo.orgprod-tp.sumo.moz.worksprogressiveatheists.orgpublicsuffix.orgr1---sn-a5msen7s.googlevideo.comr1---sn-aigzrn76.googlevideo.comr1---sn-ntqe6n76.googlevideo.comr3---sn-ntq7yned.googlevideo.comr4---sn-ntqe7n7z.googlevideo.coms10.histats.coms4.histats.comsafebrowsing.googleapis.comsc-f6eade8.jssmokingwheels.comstevehanov.castrasbourgfloorball.comstratmindsevents.comstripecdn.map.fastly.nettiles.r53-2.services.mozilla.comtime-ios.g.aaplimg.comtnreca.comuxpa2017.orgweatherstonecm.comweblibrary.cdn.getgo.comwinsupports72.clubwww.aasb.gov.auwww.anglicare.asn.auwww.austrac.gov.auwww.cinematech.todaywww.fastsupport.comwww.get-express-vpn.comwww.googletagservices.comwww.instahu.comwww.lifewire.comwww.mintpayments.comwww.my-ftm.comwww.newphilosopher.comwww.nridigital.comwww.prolegis.com.auwww.saltburnlearningcampus.co.ukwww.sbnonline.comwww.startupdaily.netwww.stb.academywww.thesummitla.comwww.town-mobile.netwww.westendmagazine.comxen-media.comxpguihticzvxoyt3.ggpht.com
Regex & Wildcard blocking
  • (^|.)2mdn.net$
(^|.)expertcity.com$(^|.)gvt1.com$
is this still maintained?
I was just wondering the same thing. I’d rather not choke up my hole with large unmaintained lists.
Thanks, you helped me to decide not to add this/these list/s.
Not at the moment I have cash flow problems.
I'm in the process of setting up a automatic updated lists but I can't afford the power to run it
https://www.synergy.net.au/Your-home/Energy-plans/Home-Plan-A1
From site.
|Supply charge |101.5493 cents per day|
|Supply charge: additional homes^ |40.3762 cents per day|
|Electricity charge |28.3272 cents per unit|
If some sort of donation thing is setup, then I can continue and improve my service.
Yes they are rather large.
Not sure on a Raspberry Pi 2B as I don't own one to test.
I run it on a Raspberry Pi 3 B and it takes the memory out to ~88% displayed in red.
Sometimes it takes 5 mins to whitelist a site.
Perhaps you could raise a post with an issue on this forum.
I tried on an Odroid and the lack of verbosity for a long time concerned me, so I just went elsewhere. Don't think I'll be trying again, so I won't be raising an issue on the forum, apologies.
All cool Mate!
Should run on any old Pentium 4 Deb 9 XFCE. (NonFree Firmware on USB stick).
Try this one list
https://ncloud.zaclys.com/index.php/s/gwb95DL8sbTcJmx/download
The Pi-hole seems to be ok the correct functions are seen.
#Spottily
The memory problem seems to under control. Thank you all.
then you can try to block 10 million domains :grinning:
Yes Ok. I have been working on it for over 6 months now I cant really afford the Electricity Cost in Australia ATM.
Nearly 30 cents per kw/h.
Running on about 40% duty cycle.
Running Bar fridge $25 with 2 sides with 40 mm covered in isolite.
Hey check my maths please! 40 Watt Edison costs 12 cents for 3 hours?
40 watts for 3 hours is 120 watt hours, or 0.120 KWh. At 30 cents per KWh, this is 0.120 * 30 = 3.6 cents.
Ok here is a Windows host file editor I tried selling fo one AUD free install.
You will need to run Quick Basic 64 (QB64) from https://www.qb64.org/
There is a helpful forum community to help with coding.
https://www.qb64.org/forum/index.php?topic=1158.0
Can be modified to do what ever you want like a small scale PI-Hole
Open resource monitor in network activity and highlight the one you want. > CTRL C.
Image PID Address Send (B/sec) Receive (B/sec) Total (B/sec)
firefox.exe 5000 167.99.26.239 202 198 400
Add at a blank part of program putting a REM statement in front to allow you to run program to block and unblock things.
Currently I switch between Simple phone and Smart old phone for contact on twitter hits both devices ????
Ps Thank you for the maths sort out. But there is the cost of the Edison around $5 lasts 300 hours (Guess cold filament turn on)
A summary of the lists.
Note: The number of domains is not correct when using these lists I will one day try and sort it out.
https://smokingwheels.github.io/Pi-hole/allhosts
https://smokingwheels.github.io/Pi-hole/searchengine
https://smokingwheels.github.io/Pi-hole/fromlog
https://smokingwheels.github.io/Pi-hole/yacysearchengine
old hosts file 350 mb was 21 segments Git hub limit now have better free host.
Sorted and uniq hosts from above list 128 mb
Piholewin short
https://ncloud.zaclys.com/index.php/s/zxTBEefigEMAiqd/download
Youtube blocklist
Spotoify
version 4 16 3 19 add blocker 4. in QB64
Also blocks IP's.
https://ncloud.zaclys.com/index.php/s/cS2JsxqTFPjZtnw/download
QB64 add blocker source.
https://ncloud.zaclys.com/index.php/s/oa9f64fGt35eSKH/download
