Hi. I wonder how u can see the cpu temp? Mine isnot showing that ;(
//Adde
Most likely you did not install this instance on a Raspberry pi.
The Temperature is queried here:
If you want, you can tinker with the code and use your own code to query the temperature for your processor.
OK Thx
I find where to change.. Thx for help again ![]()
//Adde
