Www.googleadservices.com 8,894k denied requests (while asleep?)
Less internet usage while asleep?
When checking pi.hole, after waking up for the night, there are about 8,000 'requests' from www.googleadservices.com being blocked. It starts around 22:00 and ends around 3:00.
Other then whitelisting this, Any insight? Ty :slight_smile:
Image of graph, https://imgur.com/CYAujET
Image of Logs, https://imgur.com/a/cYwAD
n/a
Try configure the router like described in below FAQ instead of pointing the WAN DNS part of the router to Pi-hole.
That way you'll be able to see from which device/IP those DNS queries are coming from.
Thank you very much for offering your assistance on this request. I really appreciate your willingness to help out.
Reading the FAQs better and saw
"Log into your router’s configuration page and find the DHCP/DNS settings. Note: make sure you adjust this setting under your LAN settings and not the WAN."
My router GUI (r7000) doesn't seem to have a LAN DNS, just a "internet" DNS. :frowning:
Also, Found LAN DNS server for local names on Netgear R7000
Suppose I'll just enable DHCP on the Pi-hole.
Yeah, if the router doesnt have settings to push Pi-hole's IP address to the clients as a DNS server through DHCP, thats the only alternative if want to figure out which device is doing those DNS queries:
