Update Gravity / pihole -g
runs successfully
I'm seeing this error instead on both commands:
[✗] DNS resolution is currently unavailable
[✗] DNS resolution is not available
I've already checked and did the suggestions here and here but to no avail.
I also did this suggestion from Reddit which is closer to the issue but found no luck
Side note: pihole -d wasn't able to send debug so pasting it here.
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2021-09-03:06:17:12 debug log has been initialized.
[i] Core: v5.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.3.1-0-g4736e03
[i] Web: v5.5.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.5.1-0-gfb9bd56
[✓] FTL: v5.8.1
[i] 1.4.53
[i] 7.3.29
[i] dig return code: 10
[i] dig response: dig: couldn't get address for 'ns1.pi-hole.net': failure
[✗] Distro: Raspbian
[✗] Error: Raspbian is not a supported distro (https://docs.pi-hole.net/main/prerequisites/)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.100.5/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::84c0:eb75:13a9:528e does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.100.1
* Pinging 192.168.100.1...
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[53] is in use by pihole-FTL
[80] is in use by lighttpd
[✓] sciskanie938.rest is 0.0.0.0 via localhost (127.0.0.1)
[✓] sciskanie938.rest is 0.0.0.0 via Pi-hole (192.168.100.5)
Timeout: 10 seconds
WARN: Could not sendto() in send_dhcp_discover() (/root/project/src/dhcp-discover.c:223): Network is unreachable
* Received 548 bytes from eth0:192.168.100.1
Offered IP address: 192.168.100.172
Server IP address: N/A
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.100.1
lease-time: 604800 ( 7d )
netmask: 255.255.255.0
router: 192.168.100.1
dns-server: 192.168.100.1
domain-name: "cg.shawcable.net"
--- end of options ---
DHCP packets received on interface wlan0: 0
[✓] lighttpd daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
Active: active (exited) since Fri 2021-09-03 04:41:56 BST; 1h 35min ago
Process: 15735 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Sep 03 04:41:55 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Sep 03 04:41:55 raspberrypi pihole-FTL[15735]: Not running
Sep 03 04:41:55 raspberrypi su[15753]: (to pihole) root on none
Sep 03 04:41:55 raspberrypi su[15753]: pam_unix(su:session): session opened for user pihole by (uid=0)
Sep 03 04:41:56 raspberrypi pihole-FTL[15735]: FTL started!
Sep 03 04:41:56 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.100.5/24
IPV6_ADDRESS=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
BLOCKING_ENABLED=true
HTTP/1.1 200 OK
Expires: Fri, 03 Sep 2021 05:17:51 GMT
Cache-Control: max-age=0
Date: Fri, 03 Sep 2021 05:17:51 GMT
Server: lighttpd/1.4.53
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 5406720 Sep 3 05:33 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 14
updated 1630640523
gravity_count 90237
Last gravity run finished at: Fri 3 Sep 04:42:03 BST 2021
----- First 10 Gravity Domains -----
localhost.localdomain
wizhumpgyros.com
coccyxwickimp.com
n2019cov.000webhostapp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
ns6.0pendns.org
dns.0pengl.com
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2021-09-03 04:41:56 2021-09-03 04:41:56 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2021-09-03 04:41:56 2021-09-03 04:41:56 Migrated from /etc/pihole/adlists.list
38 1 0 https://hosts.oisd.nl/ 2021-09-03 05:32:50 2021-09-03 05:32:50
-rw-r--r-- 1 root root 48 Sep 3 04:42 /etc/pihole/local.list
192.168.100.5 raspberrypi
192.168.100.5 pi.hole
-rw-r--r-- 1 root root 234 Sep 3 04:41 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 15 Sep 3 04:41 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1385 Sep 3 04:41 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=eth0
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Sep 3 04:41 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4066 Sep 3 04:41 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1755 Sep 3 04:41 /etc/cron.d/pihole
49 4 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
34 16 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 500 Sep 3 05:27 /var/log/lighttpd/error.log
-----head of error.log------
2021-09-03 04:40:43: (server.c.1464) server started (lighttpd/1.4.53)
2021-09-03 04:41:45: (server.c.2059) server stopped by UID = 0 PID = 1
2021-09-03 04:41:46: (server.c.1464) server started (lighttpd/1.4.53)
2021-09-03 05:26:55: (server.c.2059) server stopped by UID = 0 PID = 1
2021-09-03 05:26:56: (server.c.1464) server started (lighttpd/1.4.53)
2021-09-03 05:27:15: (server.c.2059) server stopped by UID = 0 PID = 1
2021-09-03 05:27:16: (server.c.1464) server started (lighttpd/1.4.53)
-----tail of error.log------
-rw-r--r-- 1 pihole pihole 14305 Sep 3 05:33 /var/log/pihole-FTL.log
[2021-09-03 04:41:56.103 15766M] Using log file /var/log/pihole-FTL.log
[2021-09-03 04:41:56.104 15766M] ########## FTL started! ##########
[2021-09-03 04:41:56.104 15766M] FTL branch: master
[2021-09-03 04:41:56.104 15766M] FTL version: v5.8.1
[2021-09-03 04:41:56.104 15766M] FTL commit: b90ab8b1
[2021-09-03 04:41:56.104 15766M] FTL date: 2021-04-21 20:03:47 +0100
[2021-09-03 04:41:56.104 15766M] FTL user: pihole
[2021-09-03 04:41:56.104 15766M] Compiled for armv7hf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2021-09-03 04:41:56.105 15766M] Creating mutex
[2021-09-03 04:41:56.108 15766M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2021-09-03 04:41:56.108 15766M] SOCKET_LISTENING: only local
[2021-09-03 04:41:56.108 15766M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2021-09-03 04:41:56.109 15766M] MAXDBDAYS: max age for stored queries is 365 days
[2021-09-03 04:41:56.109 15766M] RESOLVE_IPV6: Resolve IPv6 addresses
[2021-09-03 04:41:56.109 15766M] RESOLVE_IPV4: Resolve IPv4 addresses
[2021-09-03 04:41:56.109 15766M] DBINTERVAL: saving to DB file every minute
[2021-09-03 04:41:56.109 15766M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2021-09-03 04:41:56.109 15766M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2021-09-03 04:41:56.109 15766M] PRIVACYLEVEL: Set to 0
[2021-09-03 04:41:56.109 15766M] IGNORE_LOCALHOST: Show queries from localhost
[2021-09-03 04:41:56.109 15766M] BLOCKINGMODE: Null IPs for blocked domains
[2021-09-03 04:41:56.110 15766M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2021-09-03 04:41:56.110 15766M] DBIMPORT: Importing history from database
[2021-09-03 04:41:56.110 15766M] PIDFILE: Using /run/pihole-FTL.pid
[2021-09-03 04:41:56.110 15766M] PORTFILE: Using /run/pihole-FTL.port
[2021-09-03 04:41:56.110 15766M] SOCKETFILE: Using /run/pihole/FTL.sock
[2021-09-03 04:41:56.110 15766M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2021-09-03 04:41:56.110 15766M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2021-09-03 04:41:56.110 15766M] GRAVITYDB: Using /etc/pihole/gravity.db
[2021-09-03 04:41:56.111 15766M] PARSE_ARP_CACHE: Active
[2021-09-03 04:41:56.111 15766M] CNAME_DEEP_INSPECT: Active
[2021-09-03 04:41:56.111 15766M] DELAY_STARTUP: No delay requested.
[2021-09-03 04:41:56.111 15766M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2021-09-03 04:41:56.111 15766M] NICE: Set process niceness to -10 (default)
[2021-09-03 04:41:56.111 15766M] MAXNETAGE: Removing IP addresses and host names from network table after 365 days
[2021-09-03 05:32:16.614 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:18.049 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:18.641 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:19.735 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:20.673 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:21.313 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:21.701 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:22.662 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:22.731 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:24.042 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:24.760 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 1.0 msec
[2021-09-03 05:32:25.310 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:25.787 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:26.407 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:26.812 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:29.205 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:29.843 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:30.613 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:30.870 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 1.0 msec
[2021-09-03 05:32:31.800 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:31.903 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 1.0 msec
[2021-09-03 05:32:33.866 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:33.934 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 1.0 msec
[2021-09-03 05:32:50.520 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:50.985 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:53.067 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:54.014 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 1.0 msec
[2021-09-03 05:32:54.134 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:55.043 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:55.490 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:56.071 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:32:56.724 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:32:57.097 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
[2021-09-03 05:33:00.938 15768M] Received: Real-time signal 0 (34 -> 0)
[2021-09-03 05:33:01.365 15768/T15772] Compiled 0 whitelist and 0 blacklist regex filters for 3 clients in 0.9 msec
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 684032 Sep 3 04:41 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 224 Sep 3 04:41 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 4096 Sep 3 04:41 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 4096 Sep 3 04:41 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 28 Sep 3 04:41 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 12288 Sep 3 04:41 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4096 Sep 3 04:41 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 229376 Sep 3 05:30 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Sep 3 04:41 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 81920 Sep 3 04:45 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 28672 Sep 3 04:41 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
LANG=en_GB.UTF-8
-rw-r--r-- 1 pihole pihole 44338 Sep 3 06:17 /var/log/pihole.log
-----head of pihole.log------
Sep 3 04:41:56 dnsmasq[15768]: started, version pi-hole-2.85 cachesize 10000
Sep 3 04:41:56 dnsmasq[15768]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset auth cryptohash DNSSEC loop-detect inotify dumpfile
Sep 3 04:41:56 dnsmasq[15768]: using only locally-known addresses for domain use-application-dns.net
Sep 3 04:41:56 dnsmasq[15768]: using nameserver 8.8.4.4#53
Sep 3 04:41:56 dnsmasq[15768]: using nameserver 8.8.8.8#53
Sep 3 04:41:56 dnsmasq[15768]: read /etc/hosts - 5 addresses
Sep 3 04:41:56 dnsmasq[15768]: read /etc/pihole/custom.list - 0 addresses
Sep 3 04:41:56 dnsmasq[15768]: failed to load names from /etc/pihole/local.list: No such file or directory
Sep 3 04:42:06 dnsmasq[15768]: read /etc/hosts - 5 addresses
Sep 3 04:42:06 dnsmasq[15768]: read /etc/pihole/custom.list - 0 addresses
Sep 3 04:42:06 dnsmasq[15768]: read /etc/pihole/local.list - 2 addresses
Sep 3 04:45:20 dnsmasq[15768]: query[A] v10.events.data.microsoft.com from 192.168.100.1
Sep 3 04:45:20 dnsmasq[15768]: forwarded v10.events.data.microsoft.com to 8.8.4.4
Sep 3 04:45:20 dnsmasq[15768]: forwarded v10.events.data.microsoft.com to 8.8.8.8
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* curl failed, falling back to netcat for transmission.
nc: getaddrinfo for host "tricorder.pi-hole.net" port 9999: Temporary failure in name resolution
* A local copy of the debug log can be found at: /var/log/pihole_debug.log
