* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
You can check and see if there's any local debug logs in /var/log, for the debugger to just stop at that point without any further output indicates something pretty wrong. Did it just go back to the console? You should have been prompted to answer yes or no.
How are you accessing the terminal? SSH or a keyboard?
All is now working. My router was causing DNS issues. I had to change DNS on the router, and reboot. Pi-hoe is now working to update and resolve github.com.
