Trouble setting up IPv6 with Pi-Hole
This is actually a continuation of this thread. I was in the middle of my exam phase when I opened it and was too stressed out to try to solve the problem. Well, nothing has changed really.
When I type ip addr this is what I see
    inet6 ::1/128 scope host
    link/ether 00:e0:4c:36:02:67 brd ff:ff:ff:ff:ff:ff
    inet 192.168.184.34/24 brd 192.168.184.255 scope global noprefixroute eth0
    inet6 2a04:4540:7100:2800:20a:adeb:b82a:a992/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 7188sec preferred_lft 3588sec
    inet6 fe80::f9d8:a73b:2fb6:8839/128 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether b8:27:eb:ed:21:70 brd ff:ff:ff:ff:ff:ff
I am trying to enter the Link Local adress in my router, but it doesn't work. It only works with the non-static address, which is of course not practical. What do I do now?
It is also weird that Pi-Hole shows me a different IPv6 address, which also doesn't work
Okay, I tried reinstalling Pi-Hole and it seems to pick the dynamic IPv6 address as the one for blocking ads. This address is saved in the settings and stays the same, even when the address has changed after some time. So Pi-Hole doesn not know the difference between a static or dynamic IPv6 address.
It uses what ever IP address you tell it to.
Your output shows IPv4 addresses for your interfaces. Use that. Pi-hole will happily respond to AAAA queries over IPv4.
Otherwise you'll need to find a forum to support you learning how IPv6 works. This isn't it.
