Temporary failure in name resolution
First thing first I have both Pi-hole and Squid on my Raspberry PI
Everything working thing except for my web-interface which stoped worked but the Pi hole was still filtering
The web interface is displaying text only
<?php /* * Pi-hole: A black hole for Internet advertisements * (c) 2017 Pi-hole, LLC (https://pi-hole.net) * Network-wide ad blocking via your own hardware.
I have no issue with webmin (squid)
Something happen today and I had no internet at all from the PI
I had to edit sudo nano /etc/resolv.conf and add 208.67.222.222 instead.
I installed Pi-hole again (still no web interface)
if I change resolv.conf with 127.0.0.1, no internet again.
Any troubleshooting step you could recommande me?
Many thanks in advance
Did you install another web server? The web interface requires lighttpd with PHP.
Run pihole -d for a debug token.
Thank you you're reply,
I have Apache 2
log
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2017-12-13:22:21:19 debug log has been initiated.
[i] Core: v3.2 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.2-0-g5ba4135
[i] Web: v3.2 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.2-0-gf74cd82
[✓] FTL: vDev-437af07 (How do I update Pi-hole?)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.19
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] IPv4 address(es) bound to the enxb827ebf6ab73 interface:
10.0.4.70/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the enxb827ebf6ab73 interface:
fe80::21c1:8ec4:3d3:1a3d does not match the IP found in /etc/pihole/setupVars.conf (Use IPv6 ULA addresses for Pi-hole)
[i] Default IPv4 gateway: 10.0.4.1
[10000] is in use by miniserv.
is in use by
[139] is in use by smbd
is in use by
[22] is in use by sshd
[3128] is in use by squid
[445] is in use by smbd
[53] is in use by dnsmasq
[80] is in use by lighttpd
[25] is in use by master
[3306] is in use by mysqld
[953] is in use by named
[✗] Failed to resolve ad.doubleclick.net.21724.9075.302br.net via localhost (127.0.0.1)
[✗] Failed to resolve ad.doubleclick.net.21724.9075.302br.net via Pi-hole (10.0.4.70)
[✓] doubleclick.com is 10.192.168.148 via a remote, public DNS server (8.8.8.8)
[✗] dnsmasq daemon is failed
[✗] lighttpd daemon is failed
PIHOLE_INTERFACE=enxb827ebf6ab73
IPV4_ADDRESS=10.0.4.70/24
IPV6_ADDRESS=
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
[✗] X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Server: nginx/1.10.3
Date: Wed, 13 Dec 2017 22:22:06 GMT
Content-Type: text/html
Content-Length: 940
Last-Modified: Wed, 13 Dec 2017 20:36:08 GMT
Connection: keep-alive
ETag: "5a318f38-3ac"
Accept-Ranges: bytes
HTTP/1.1 403 Forbidden
Content-Length: 169
-rw-r--r-- 1 root root 3513139 Dec 10 02:10 /etc/pihole/gravity.list
10.0.4.70 0.0.0.0
10.0.4.70 0000mps.webpreview.dsl.net
10.0.4.70 0001.2waky.com
10.0.4.70 zzsyw.com
10.0.4.70 zztxdown.com
10.0.4.70 zzz.clickbank.net
10.0.4.70 zz.zeroredirect1.com
-rw-r--r-- 1 root root 633 Dec 1 17:44 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 527 Dec 5 16:27 /etc/pihole/blacklist.txt
r4---sn-vgqs7nez.googlevideo.com
r4.sn-vgqs7nez.googlevideo.com
www.youtube-nocookie.com
i1.ytimg.com
r17---sn-vgqsenes.googlevideo.com
r2---sn-vgqs7n7k.googlevideo.com
clients6.google.com
r1---sn-vgqsen7z.googlevideo.com
r1.sn-vgqsen7z.googlevideo.com
r20---sn-vgqs7ne7.googlevideo.com
r20.sn-vgqs7ne7.googlevideo.com
r3---sn-25ge7nes.googlevideo.com
r3.sn-25ge7nes.googlevideo.com
r5---sn-a5mlrn7z.googlevideo.com
r5.sn-a5mlrn7z.googlevideo.com
r5---sn-u2bpouxgoxu-hxaz.googlevideo.com
r5.sn-u2bpouxgoxu-hxaz.googlevideo.com
-rw-r--r-- 1 root root 37 Dec 10 02:10 /etc/pihole/local.list
10.0.4.70 myserver
10.0.4.70 pi.hole
-rw-r--r-- 1 root root 234 Dec 13 12:45 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 117 Dec 1 17:45 /etc/pihole/whitelist.txt
raw.githubusercontent.com
mirror1.malwaredomains.com
sysctl.org
zeustracker.abuse.ch
s3.amazonaws.com
hosts-file.net
-rw-r--r-- 1 root root 1527 Dec 13 12:45 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=208.67.222.222
server=208.67.220.220
interface=enxb827ebf6ab73
-rw-r--r-- 1 root root 3027 Dec 13 12:45 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
       "X-Frame-Options" => "DENY"
   $HTTP["url"] =~ ".ttf$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1419 Dec 13 12:45 /etc/cron.d/pihole
29 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker
-rw-r--r-- 1 www-data www-data 680 Dec 10 19:17 /var/log/lighttpd/error.log
2017-12-10 18:47:06: (log.c.217) server started
2017-12-10 18:47:06: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2017-12-10 19:17:11: (log.c.217) server started
2017-12-10 19:17:11: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2017-12-10 19:17:12: (log.c.217) server started
2017-12-10 19:17:12: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2017-12-10 19:17:10: (log.c.217) server started
2017-12-10 19:17:10: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 30858 Dec 13 20:27 /var/log/pihole-FTL.log
[2017-12-13 00:00:02.165] NOTICE: pihole.log has been flushed
[2017-12-13 00:00:02.165] Resetting internal data structure
[2017-12-13 00:00:02.165] Queries in memory before flushing: 13624
[2017-12-13 00:00:02.546] Gravity list entries: 106854
[2017-12-13 00:00:02.547] Blacklist entries: 17
[2017-12-13 00:00:02.548] No wildcard blocking list present
[2017-12-13 00:00:02.548] Reading from /var/log/pihole.log.1 (rw-r--r--)
[2017-12-13 00:00:02.548] Notice: Increasing forwarded struct size from 0 to 4 (328.00 B)
[2017-12-13 00:00:02.553] New forward server: 208.67.220.220 resolver2.opendns.com (0/4)
[2017-12-13 00:00:02.553] Notice: Increasing overTime struct size from 0 to 100 (3.56 KB)
[2017-12-13 00:00:02.558] New forward server: 208.67.222.222 resolver1.opendns.com (1/4)
[2017-12-13 00:00:02.558] Notice: Increasing queries struct size from 0 to 10000 (323.61 KB)
[2017-12-13 00:00:02.559] Notice: Increasing domains struct size from 0 to 1000 (343.61 KB)
[2017-12-13 00:00:02.559] Notice: Increasing clients struct size from 0 to 10 (343.79 KB)
[2017-12-13 00:00:02.559] New client: 127.0.0.1 localhost (0/10)
[2017-12-13 00:00:02.568] New client: 10.0.4.90 (1/10)
[2017-12-13 00:00:03.358] Notice: Increasing overTime struct size from 100 to 200 (362.14 KB)
[2017-12-13 00:00:03.991] Reading from /var/log/pihole.log (rw-r--r--)
[2017-12-13 04:39:59.579] Notice: Increasing queries struct size from 10000 to 20000 (687.93 KB)
[2017-12-13 09:12:19.780] Notice: Increasing overTime struct size from 200 to 300 (692.16 KB)
[2017-12-13 10:47:42.622]
[2017-12-13 10:47:42.639] FTL branch: (no branch)
[2017-12-13 10:47:42.639] FTL hash: v2.11.1
[2017-12-13 10:47:42.639] FTL date: 2017-10-08 12:35:40 -0700
[2017-12-13 10:47:42.639] FTL user: pihole
-rw-r--r-- 1 dnsmasq root 1941506 Dec 13 15:00 /var/log/pihole.log
-----head of pihole.log------
Dec 13 00:00:02 dnsmasq[449]: query[PTR] 220.220.67.208.in-addr.arpa from 127.0.0.1
Dec 13 00:00:02 dnsmasq[449]: cached 208.67.220.220 is resolver2.opendns.com
Dec 13 00:00:02 dnsmasq[449]: query[PTR] 222.222.67.208.in-addr.arpa from 127.0.0.1
Dec 13 00:00:02 dnsmasq[449]: cached 208.67.222.222 is resolver1.opendns.com
Dec 13 00:00:02 dnsmasq[449]: query[PTR] 90.4.0.10.in-addr.arpa from 127.0.0.1
Dec 13 00:00:02 dnsmasq[449]: config 10.0.4.90 is NXDOMAIN
Dec 13 00:00:04 dnsmasq[449]: query[PTR] 90.4.0.10.in-addr.arpa from 127.0.0.1
Dec 13 00:00:04 dnsmasq[449]: config 10.0.4.90 is NXDOMAIN
Dec 13 00:00:09 dnsmasq[449]: query[PTR] 62.4.0.10.in-addr.arpa from 127.0.0.1
Dec 13 00:00:09 dnsmasq[449]: config 10.0.4.62 is NXDOMAIN
Dec 13 00:00:09 dnsmasq[449]: query[A] yaycork.ie from 127.0.0.1
Dec 13 00:00:09 dnsmasq[449]: forwarded yaycork.ie to 208.67.220.220
Dec 13 00:00:09 dnsmasq[449]: forwarded yaycork.ie to 208.67.222.222
Dec 13 00:00:09 dnsmasq[449]: query[AAAA] yaycork.ie from 127.0.0.1
Dec 13 00:00:10 dnsmasq[449]: reply yaycork.ie is 104.27.152.222
Dec 13 00:00:10 dnsmasq[449]: reply yaycork.ie is 104.27.153.222
Dec 13 00:00:10 dnsmasq[449]: reply yaycork.ie is 2400:cb00:2048:1::681b:98de
Dec 13 00:00:10 dnsmasq[449]: reply yaycork.ie is 2400:cb00:2048:1::681b:99de
Dec 13 00:00:11 dnsmasq[449]: query[A] www.facebook.com from 127.0.0.1
You need to let lighttpd have access to port 80 on the same IP that you set Pi-hole to use. Then, you can navigate to http://pi.hole/admin (or use the IP address) to go to the web interface.
well the ip/admin still return to pi hole, just text only, I guess it's an issue with PHP.
also I keep having the issue with sudo nano /etc/resolv.conf which I have to change to a external DNS otherwise I have no internet at all
You said you have apache (but I don't see it in the log), where is that running? If you are trying to access the web interface through it without setting up PHP then the page will not render correctly (it will just show text as you've seen).
A post was split to a new topic: Lost DNS resolution
