ping google.com should work
ping google.com ping: google.com: Temporary failure in name resolution
Couldn't upload to tricorder, so no token. Will post log in next message.
Details;
Raspberry Pi 2b, Raspbian stretch lite. Base install... pi-hole on top of latest stretch lite image (no apt-get upgrade... it kills the pi right now)
Observed behaviour: Switching the router (Tomato USB) to use the pi-hole as DNS kills the internet in the whole house...Makes sense when you know that the pi-hole can't resolve domain names!
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-09-17:08:58:38 debug log has been initialized.
[i] Core: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gddbdb51
[i] Web: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gaf8c926
[ā] FTL: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
*** [ DIAGNOSING ]: dnsmasq version
[i] 340:
[i] 1.4.45
[i] 7.0.30
[ā] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[ā] armv7l
[ā] IPv4 address(es) bound to the eth0 interface:
192.168.9.5/24 matches the IP found in /etc/pihole/setupVars.conf
[ā] IPv6 address(es) bound to the eth0 interface:
fe80::1157:4c17:bef6:ec79 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.9.1
* Pinging 192.168.9.1...
[ā] Gateway responded.
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
[ā] Failed to resolve zhongtongbus.lk via localhost (127.0.0.1)
[ā] Failed to resolve zhongtongbus.lk via Pi-hole (192.168.9.5)
[ā] doubleclick.com is 172.217.14.206 via a remote, public DNS server (8.8.8.8)
[ā] dnsmasq daemon is inactive
[ā] lighttpd daemon is active
[ā] pihole-FTL daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.9.5/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=8.8.8.8#53
PIHOLE_DNS_2=8.8.4.4#53
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
[ā] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[ā] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 3032506 Sep 16 03:43 /etc/pihole/gravity.list
0.0.0.0
0.r.msn.com
0.start.bz
000.0x1f4b0.com
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Sep 15 20:52 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 40 Sep 16 03:43 /etc/pihole/local.list
192.168.9.5 pi-hole
192.168.9.5 pi.hole
-rw-r--r-- 1 root root 234 Sep 15 21:10 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1539 Sep 17 08:27 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
domain-needed
bogus-priv
interface=eth0
-rw-r--r-- 1 root root 3027 Sep 15 21:09 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1495 Sep 15 21:09 /etc/cron.d/pihole
43 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
2 15 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 582 Sep 17 08:30 /var/log/lighttpd/error.log
2018-09-15 21:05:02: (log.c.217) server started
2018-09-15 21:11:04: (server.c.1828) server stopped by UID = 0 PID = 1
2018-09-15 21:11:04: (log.c.217) server started
2018-09-15 21:23:20: (server.c.1828) server stopped by UID = 0 PID = 1
2018-09-15 21:23:52: (log.c.217) server started
2018-09-16 07:45:34: (log.c.217) server started
2018-09-16 10:10:14: (server.c.1828) server stopped by UID = 0 PID = 1
2018-09-16 10:10:40: (log.c.217) server started
2018-09-17 08:29:46: (server.c.1828) server stopped2018-09-17 08:30:24: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 4054 Sep 17 08:30 /var/log/pihole-FTL.log
[2018-09-17 08:22:17.014] ########## FTL started! ##########
[2018-09-17 08:22:17.014] FTL branch:
[2018-09-17 08:22:17.015] FTL version: v4.0
[2018-09-17 08:22:17.015] FTL commit: 8493df4
[2018-09-17 08:22:17.015] FTL date: 2018-08-05 13:40:30 -0700
[2018-09-17 08:22:17.015] FTL user: pihole
[2018-09-17 08:22:17.015] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-09-17 08:22:17.015] SOCKET_LISTENING: only local
[2018-09-17 08:22:17.015] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-09-17 08:22:17.015] MAXDBDAYS: max age for stored queries is 365 days
[2018-09-17 08:22:17.015] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-09-17 08:22:17.016] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-09-17 08:22:17.016] DBINTERVAL: saving to DB file every minute
[2018-09-17 08:22:17.016] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-09-17 08:22:17.016] MAXLOGAGE: Importing up to 24.0 hours of log data
[2018-09-17 08:22:17.016] PRIVACYLEVEL: Set to 0
[2018-09-17 08:22:17.016] IGNORE_LOCALHOST: Show queries from localhost
[2018-09-17 08:22:17.016] BLOCKINGMODE: Null IPs for blocked domains
[2018-09-17 08:22:17.016] REGEX_DEBUGMODE: Inactive
[2018-09-17 08:22:17.016] Finished config file parsing
[2018-09-17 08:22:17.017] INFO: No whitelist file found
[2018-09-17 08:22:17.017] Compiled 0 Regex filters and -1 whitelisted domains in 0.2 msec (0 errors)
[2018-09-17 08:22:17.019] Database successfully initialized
[2018-09-17 08:22:17.020] Imported 0 queries from the long-term database
[2018-09-17 08:22:17.020] -> Total DNS queries: 0
[2018-09-17 08:22:17.020] -> Cached DNS queries: 0
[2018-09-17 08:22:17.020] -> Forwarded DNS queries: 0
[2018-09-17 08:22:17.020] -> Exactly blocked DNS queries: 0
[2018-09-17 08:22:17.020] -> Unknown DNS queries: 0
[2018-09-17 08:22:17.021] -> Unique domains: 0
[2018-09-17 08:22:17.021] -> Unique clients: 0
[2018-09-17 08:22:17.021] -> Known forward destinations: 0
[2018-09-17 08:22:17.021] Successfully accessed setupVars.conf
[2018-09-17 08:30:36.239] ########## FTL started! ##########
[2018-09-17 08:30:36.241] FTL branch:
[2018-09-17 08:30:36.241] FTL version: v4.0
[2018-09-17 08:30:36.241] FTL commit: 8493df4
[2018-09-17 08:30:36.241] FTL date: 2018-08-05 13:40:30 -0700
[2018-09-17 08:30:36.241] FTL user: pihole
[2018-09-17 08:30:36.246] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-09-17 08:30:36.246] SOCKET_LISTENING: only local
[2018-09-17 08:30:36.247] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-09-17 08:30:36.247] MAXDBDAYS: max age for stored queries is 365 days
[2018-09-17 08:30:36.247] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-09-17 08:30:36.247] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-09-17 08:30:36.247] DBINTERVAL: saving to DB file every minute
[2018-09-17 08:30:36.247] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-09-17 08:30:36.247] MAXLOGAGE: Importing up to 24.0 hours of log data
[2018-09-17 08:30:36.247] PRIVACYLEVEL: Set to 0
[2018-09-17 08:30:36.247] IGNORE_LOCALHOST: Show queries from localhost
[2018-09-17 08:30:36.247] BLOCKINGMODE: Null IPs for blocked domains
[2018-09-17 08:30:36.248] REGEX_DEBUGMODE: Inactive
[2018-09-17 08:30:36.248] Finished config file parsing
[2018-09-17 08:30:36.248] INFO: No whitelist file found
[2018-09-17 08:30:36.248] Compiled 0 Regex filters and -1 whitelisted domains in 0.3 msec (0 errors)
[2018-09-17 08:30:36.318] Database successfully initialized
[2018-09-17 08:30:36.326] Imported 0 queries from the long-term database
[2018-09-17 08:30:36.327] -> Total DNS queries: 0
[2018-09-17 08:30:36.327] -> Cached DNS queries: 0
[2018-09-17 08:30:36.327] -> Forwarded DNS queries: 0
[2018-09-17 08:30:36.327] -> Exactly blocked DNS queries: 0
[2018-09-17 08:30:36.327] -> Unknown DNS queries: 0
[2018-09-17 08:30:36.327] -> Unique domains: 0
[2018-09-17 08:30:36.327] -> Unique clients: 0
[2018-09-17 08:30:36.327] -> Known forward destinations: 0
[2018-09-17 08:30:36.328] Successfully accessed setupVars.conf
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 0 Sep 17 08:29 /var/log/pihole.log
-----head of pihole.log------
[ā] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Using openssl for transmission.
[ā] There was an error uploading your debug log.
* A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
I used method 1, and just changed the DNS server in TomatoUSB to the pi-hole server. Notice that in the screenshot on that page, "Use DNSMasq for DHCP" is CHECKED. This option appears to allow DNSMasq to continue to function as DHCP server, so that's what I was going for. I will try method 2, which tells dnsmasq to use pi-hole as the DNS server.
What I'm not clear on is that I then have to configure pi-hole to use my router as the upstream DNS server, but my router thinks that pi-hole is the DNS server.. This seems like a circular reference to me...
No that is not the case and it can perfectly be used as only a DNS server
Disable the separate running DNSmasq and trust that Pi-hole will do DHCP and DNS
Sorry mate - I know you're trying to help, but I just don't see how "it can be perfectly used as only a DNS server" and "trust that Pi-hole will do DHCP and DNS" are an answer.
If it's perfectly used as only a DNS server, then why are you telling me to let it do DHCP? I really don't want to reconfigure all my address reservations, and if this doesn't solve the problem, then my network is completely hooped until I get DHCP back to the router. If it's only DNS then, I can switch the DNS servers back to google on my router without too much hassle.
I'm trying pi-hole out, but I just can't afford to take the network down for hours at a time. Two teenage kids and a wife make for some serious grief if the network is down for more than few minutes.
Besides, "it can perfectly be used as only a DNS server" - so why don't you want to help me do that?
Not sure if you wrote that for the 2nd time because we've gone back and forth a lot without moving anything forward. Let's just close this off and I'll go see if I can solve the problem myself.
Thanks for trying to help - I really do appreciate it.
No. You can't run dnsmasq process separately on the Pi that hosts Pi-Hole. pihole-FTL uses port 53, and if dnsmasq is running on the Pi, then pihole-FTL cannot start, as is shown in your debug log.
You can use Pi-Hole as your DNS server without using it as your DHCP server (I would suspect this is how most users have it configured).
dnsmasq running on your router only affects how the router does it's own DNS routing, not how the Pi behaves.
This is not the case. Most users use one of the commercial third party DNS servers (8 options provided on the admin GUI).
With this setup (the two items above), the router does all the DHCP serving, and the Pi-Hole does all the DNS resolving.
Ok, problem solved... and as expected, it was pilot error.
TomatoUSB (I'm using the Shibby fork) has a switch to intercept DNS (port 53), whether or not an application tries to resolve names directly (Netflix). This switch was ON for me, and as soon as I unchecked that and saved the settings in the router, everything was off to the races.
I'm assuming that pi-hole intercepts port 53, which means applications can TRY to resolve directly to 8.8.8.8, but those requests will be intercepted and passed to pi.hole first, then sent upstream for resolution.
I know it's off topic here, but curious if that's indeed the case.
Thanks to jfb for trying to solve my stupidity, it was appreciated.
Ok, so that wasn't quite right... pi-hole won't capture port 53 (or at least not out of the box), so I was hoping the router would capture all port 53 requests and send to the DNS server (pi-hole), but it seems that doesn't work... perhaps because pi-hole is inside the router's subnet?
Currently:
modem: LAN 192.168.y.1
router: WAN 192.168.y.9
LAN 192.168.x.1
devices in the LAN (192.168.x.XXX)
incl pi-hole: 192.168.x.4
If I move the pi-hole upstream from the router thusly:
router: WAN 192.168.y.9 pi-hole: 192.168.y.4
LAN 192.168.x.1
Would that allow the router to capture port 53, then send the request up 1 subnet to the pi-hole?
