I followed this thread
I did a ping pi.hole:
anonymous@mint ~ $ ping pi.hole
PING pi.hole (202.71.99.194) 56(84) bytes of data.
64 bytes from 202.71.99.194: icmp_seq=1 ttl=57 time=11.8 ms
64 bytes from 202.71.99.194: icmp_seq=2 ttl=57 time=11.7 ms
64 bytes from 202.71.99.194: icmp_seq=3 ttl=57 time=12.4 ms
64 bytes from 202.71.99.194: icmp_seq=4 ttl=57 time=10.4 ms
64 bytes from 202.71.99.194: icmp_seq=5 ttl=57 time=12.5 ms
^C
--- pi.hole ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 10.490/11.828/12.599/0.763 ms
The 202.71.99.194 ip isn't my wan ip. I've checked. What is going on here? something to do with lighttpd?
nslookup pi.hole:
anonymous@mint ~ $ nslookup pi.hole
Server: 127.0.1.1
Address: 127.0.1.1#53
Non-authoritative answer:
Address: 202.71.99.194
tadgh
May 12, 2017, 2:15pm
42
I have just setup my pihole, and this is what I am experiencing. My linux box just...never gets an answer. domain gets whitelisted(cached), but DNS_PROBE_BAD_CONFIG comes back.
Router: Archer C3200
Pihole is using ethernet, WLAN disabled. Static IP assigned
Pinging the pihole from linux box: success
Dig google.com from linux box: Connection timed out; no servers could be reached
dig google.com from pihole: Success
Here is my debug token f90abseeaa
Note that it seems to be working over wifi on my macbook...and my android phone.
DanSchaper
Split this topic
May 12, 2017, 7:45pm
43
So my pihole is working now, after doing a reboot , the pi.hole/admin web interface works again.
So i'll mark this thread as solved and call it done ! Thanks to both of you @DanSchaper and @deHakkelaar for helping me out throughout !
Really appreciate it
deHakkelaar:
Do below to have udev rename it into wlan0:
echo 'SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="c4:e9:84:0d:37:1c", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="wlan0"' | sudo tee -a /etc/udev/rules.d/70-persistent-net.rules
sudo reboot
Thanks for this snippet of code, it now shows wlan0 again !
You can rename any network interface like this by just changing the MAC address: "ATTR{address}=="c4:e9:84:0d:37:1c"
MAC addresses for the interfaces are displayed when doing "ip link show".
If you know which driver is used for the network interface, "sudo lsmod", you wont even need a reboot:
sudo rmmod <DRIVER_MODULE>
sudo modprobe <DRIVER_MODULE>
