Matt
February 11, 2020, 4:47am
1
Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Pi-hole version is v4.3.2-397-g0a70bbd (Latest: v4.3.2)
AdminLTE version is v4.3.2-393-g843e46d (Latest: v4.3.2)
FTL version is vDev-fb01e09 (Latest: v4.3.1)
Raspberry Pi Zero running DietPi
Problem with Beta 5.0:
Noticed certain fonts on the web weren't loading and saw that fonts.gstatic.com
had made its way into my gravity list. Not a big deal, just tossed it on the whitelist, but I wanted to identify the culprit responsible for blocking this domain. I queried my lists using the web interface tool. This typically functions as expected and outputs all of the lists which contain the domain, but in this case I'm getting 0 results.
Not a deal breaker, but it does cut into the utility of the query tool if it is unable to find a culprit.
https://tricorder.pi-hole.net/owq1j1lpdk
It's probably a CNAME block then. Does the web interface show the domain being blocked?
Matt
February 11, 2020, 4:50am
3
2020-02-10 20:49:05 A fonts.gstatic.com matts-pc.LAN Blocked (gravity) - (28.2ms)
Matt
February 11, 2020, 4:53am
5
Sorry, that was the output from the web interface, showing it being blocked in the query log. Is there something else you were after?
Yes, a screenshot of the web interface showing the domain being blocked.
Yes, it does show that it's not a CNAME block so that eliminates a big section to check through.
The debug log shows the database being unlinked while active and that may be an issue.
[2020-02-10 20:24:35.016 497] Reloading DNS cache
[2020-02-10 20:24:35.016 497] Blocking status is enabled
[2020-02-10 20:24:35.026 497] SQLite3 message: file unlinked while open: /etc/pihole/gravity.db (28)
[2020-02-10 20:24:36.158 497] INFO: No regex whitelist entries found
[2020-02-10 20:24:36.341 497] Compiled 0 whitelist and 2 blacklist regex filters in 189.3 msec
[2020-02-10 20:31:16.429 497] New forward server: <redact> (3/1024)
[2020-02-10 20:32:05.116 497] New forward server: <redact> (4/1024)
[2020-02-10 20:32:05.650 497] Reloading DNS cache
[2020-02-10 20:32:05.650 497] Blocking status is enabled
[2020-02-10 20:32:05.655 497] SQLite3 message: file unlinked while open: /etc/pihole/gravity.db (28)
[2020-02-10 20:32:06.881 497] INFO: No regex whitelist entries found
[2020-02-10 20:32:07.047 497] Compiled 0 whitelist and 2 blacklist regex filters in 181.7 msec
[2020-02-10 20:32:07.955 497] New forward server: <redact> (5/1024)
Are there any hits when using the non-exact query for fonts.gstatic.com
or gstatic.com
Matt
February 11, 2020, 5:11am
12
No partial matches for fonts.gstatic.com
, but [i] Over 100 results found for gstatic.com
Using pihole -q gstatic.com -all
Match found in https://dbl.oisd.nl:
111208-android-ds.metric.gstatic.com
124023-android-ds.metric.gstatic.com
129102-i1-v6exp3-ds.metric.gstatic.com
423621-android-ds.metric.gstatic.com
565455-android-ds.metric.gstatic.com
571a132a-klb6p3m3pucbid32-c2r-ds.metric.gstatic.com
5785dd9b-izguv3eankrlygw5-c2r-ds.metric.gstatic.com
5df215fa-n4vdt5f27etni5je-c2r-ds.metric.gstatic.com
607683-android-ds.metric.gstatic.com
6abb263a-dlml6jqmtavtsqef-c2r-ds.metric.gstatic.com
6abb263a-hca3e3vv7vrvzkpe-c2r-ds.metric.gstatic.com
6abb263a-ji2zqkiijix2kob6-c2r-ds.metric.gstatic.com
718832-android-ds.metric.gstatic.com
757680-android-ds.metric.gstatic.com
785682-android-ds.metric.gstatic.com
790518-android-ds.metric.gstatic.com
918776-android-ds.metric.gstatic.com
921267-android-ds.metric.gstatic.com
924069-android-ds.metric.gstatic.com
anycast-edge.metric.gstatic.com
anycast-stb.metric.gstatic.com
anycast.metric.gstatic.com
anycast2-stb.metric.gstatic.com
anycast2.metric.gstatic.com
caf6fc61-bdhqn2qa4dm2drfi-c2r-ds.metric.gstatic.com
connectivitycheck.gstatic.comwf.cbarsrv.com
cotnet.diggstatic.com
diagnose.igstatic.com
dnsotls-ds.metric.gstatic.com
encrypted-tbn2.gstatic.comexchange.basebanner.com
gstatic.comstatic.getclicky.com
metric.gstatic.com
p2-a6strlxzclbee-bakozueyhcf6e7k4-if-v6exp3-v4.metric.gstatic.com
p2-aahhyknavsj2m-wtnlrzkba6lht33q-if-v6exp3-v4.metric.gstatic.com
p2-ab6kblbfj4yqo-azvteebk3wtkkaae-if-v6exp3-v4.metric.gstatic.com
p2-ajqzcgzl2l3xw-gepf7uctxogn5vzq-if-v6exp3-v4.metric.gstatic.com
p2-akapqjehwrcrc-v7hgkyjk36dap5kn-if-v6exp3-v4.metric.gstatic.com
p2-b36f5ioumffie-lpf2lgcksfv4igta-if-v6exp3-v4.metric.gstatic.com
p2-bbwo6kotpl5wa-iyheqk4xlx2wp35s-if-v6exp3-v4.metric.gstatic.com
p2-bq72dqfsa3wgc-uwqvdawy4hkrxl67-if-v6exp3-v4.metric.gstatic.com
p2-bqvskhonsju5q-ed4zavcsaojzmvmb-if-v6exp3-v4.metric.gstatic.com
p2-bxz7j225wmras-k5bwv4c5my7725hk-if-v6exp3-v4.metric.gstatic.com
p2-bzcoyqan65p6u-hwd7eivbqi3q7vew-318585-i1.stbcast2-stb.metric.gstatic.com
p2-bzcoyqan65p6u-hwd7eivbqi3q7vew-318585-i2.anycast-stb.metric.gstatic.com
p2-ctce2sxr5ie7m-4basnp7qybiddvk5-if-v6exp3-v4.metric.gstatic.com
p2-d2wl6hqdmw5fm-d6ynnwza6o4xdke3-if-v6exp3-v4.metric.gstatic.com
p2-dd6a6eii6pkau-wmfwouqbkj6dyzr3-if-v6exp3-v4.metric.gstatic.com
p2-dfmajs4yht3xs-lh6uop7hzpqzaqlp-488881-i1-v6exp3.v4.metric.gstatic.com
p2-dfmajs4yht3xs-lh6uop7hzpqzaqlp-488881-i2-v6exp3.ds.metric.gstatic.com
p2-dfmajs4yht3xs-lh6uop7hzpqzaqlp-488881-s1-v6exp3-v4.metric.gstatic.com
p2-dfmajs4yht3xs-lh6uop7hzpqzaqlp-if-v6exp3-v4.metric.gstatic.com
p2-e7mqn7f2xyw3e-u4e2p6fwj6njdbwa-if-v6exp3-v4.metric.gstatic.com
p2-eiiimthobfgem-7x232fmdowoyflio-if-v6exp3-v4.metric.gstatic.com
p2-enmdpqijudiua-eying5wyxgzp6dwz-if-v6exp3-v4.metric.gstatic.com
p2-f6rp6piuxns4u-uzq4vp76bu3w2tso-if-v6exp3-v4.metric.gstatic.com
p2-fg34pmrldkima-motu4m32vplhpevw-if-v6exp3-v4.metric.gstatic.com
p2-fkgdhaabwvfxw-xv2qbevds4lr622e-if-v6exp3-v4.metric.gstatic.com
p2-fz5b5o6sj6q6q-coeryxbgapk2qtgq-if-v6exp3-v4.metric.gstatic.com
p2-ggwrelokxwzwo-uuovim4bdorjplkp-if-v6exp3-v4.metric.gstatic.com
p2-gtjjv47jo4omc-4eqbklolvef7nhnu-773808-i2-v6exp3.v4.metric.gstatic.com
p2-gtjjv47jo4omc-4eqbklolvef7nhnu-773808-s1-v6exp3-v4.metric.gstatic.com
p2-gtjjv47jo4omc-4eqbklolvef7nhnu-if-v6exp3-v4.metric.gstatic.com
p2-hktvemjznhzt6-krdjd3zqh6oryado-if-v6exp3-v4.metric.gstatic.com
p2-ic763fautqjcw-fivh4pd5m2avg32w-268649-s1-v6exp3-v4.metric.gstatic.com
p2-ic763fautqjcw-fivh4pd5m2avg32w-if-v6exp3-v4.metric.gstatic.com
p2-icjnnhsktmz7g-3ytxc7yscrcd4wy3-194412-i1-v6exp3.ds.metric.gstatic.com
p2-icjnnhsktmz7g-3ytxc7yscrcd4wy3-if-v6exp3-v4.metric.gstatic.com
p2-iemmhkvlemspu-efful6gj327yvhst-if-v6exp3-v4.metric.gstatic.com
p2-iwjm6zadug2vs-jgx5ec4frry4jmuj-if-v6exp3-v4.metric.gstatic.com
p2-ix662tg6h6yes-dktun4tnjl2ivquk-if-v6exp3-v4.metric.gstatic.com
p2-ixrh4jazt6bka-vrg2ihieqq7h7x66-if-v6exp3-v4.metric.gstatic.com
p2-je6k6sdp3gv5a-5jrhdvf7zmtekh2u-if-v6exp3-v4.metric.gstatic.com
p2-jljpwrszy7p3k-dhoofyfuwtrmbswn-if-v6exp3-v4.metric.gstatic.com
p2-jrq7b5foqsbcu-eelydxtejpqj3hjk-if-v6exp3-v4.metric.gstatic.com
p2-kkoyp4x7yroh2-w5rofzscu46wcnb5-if-v6exp3-v4.metric.gstatic.com
p2-kqfcwg2p2eb44-jpijqtwabgy6p5vh-if-v6exp3-v4.metric.gstatic.com
p2-lc3m5xim2s7to-wt3nusd6k5v7ulqi-if-v6exp3-v4.metric.gstatic.com
p2-mcjq5tmdhtthy-hzquthqfmi2oswey-if-v6exp3-v4.metric.gstatic.com
p2-mf6wl2reylhk2-6yhwet3jypbmfsii-if-v6exp3-v4.metric.gstatic.com
p2-mggad6xokxaeu-lbkcjpihsdipb6ce-if-v6exp3-v4.metric.gstatic.com
p2-milsxuvuhonew-k3g6tgmfoyh5dp6s-if-v6exp3-v4.metric.gstatic.com
p2-mupiednesy7ja-uxlqvdod3lispchc-if-v6exp3-v4.metric.gstatic.com
p2-myir2ri5pndg2-mv654vtfbytq7prv-837094-s1-v6exp3-v4.metric.gstatic.com
p2-n3zurhre4jjvk-can5rb2f2a4urcxh-if-v6exp3-v4.metric.gstatic.com
p2-ncx2sdularkho-rksxyev3cqqqormg-if-v6exp3-v4.metric.gstatic.com
p2-nivq53trsjby2-gfwg4rj5y6eeqd4l-if-v6exp3-v4.metric.gstatic.com
p2-nzo4mjkxsby7m-4riuaqld34iidi7e-if-v6exp3-v4.metric.gstatic.com
p2-okfkfa3glya76-n7iyso22ilexb2bg-797293-i1-v6exp3.v4.metric.gstatic.com
p2-okfkfa3glya76-n7iyso22ilexb2bg-797293-i2-v6exp3.ds.metric.gstatic.com
p2-okfkfa3glya76-n7iyso22ilexb2bg-797293-s1-v6exp3-v4.metric.gstatic.com
p2-okfkfa3glya76-n7iyso22ilexb2bg-if-v6exp3-v4.metric.gstatic.com
p2-otwi3mgtoxdu4-miojxvnh6q2jthhd-if-v6exp3-v4.metric.gstatic.com
p2-oxuwpt5bjn63y-iqxsjs37jl6vuovt-if-v6exp3-v4.metric.gstatic.com
p2-p4mwbakl7c4hc-724ymvjetki3ksxg-if-v6exp3-v4.metric.gstatic.com
p2-puvcqwo7kcp4o-yh7fmhtxkbpjckui-if-v6exp3-v4.metric.gstatic.com
p4-a3weruhjsbecu-nwddtrmxt4w6j7m7-840550-i1-v6exp3.ds.metric.gstatic.com
p4-ae4jqsoqjhskk-pablncpuykhwc7uk-if-v6exp3-v4.metric.gstatic.com
p4-aiggkvxpodjea-ficofuquzfbfdnea-if-v6exp3-v4.metric.gstatic.com
p4-aiwvbmormrv3a-puz2bwwehbn3ucwh-if-v6exp3-v4.metric.gstatic.com
p4-ajvwyt5lpjazy-us7r2dzqcjsqh7pt-164149-i1-v6exp3-v4.metric.gstatic.com
p4-ajvwyt5lpjazy-us7r2dzqcjsqh7pt-164149-i2-v6exp3-ds.metric.gstatic.com
p4-ajvwyt5lpjazy-us7r2dzqcjsqh7pt-164149-s1-v6exp3-v4.metric.gstatic.com
p4-ajvwyt5lpjazy-us7r2dzqcjsqh7pt-if-v6exp3-v4.metric.gstatic.com
p4-akanjyzgfx3nk-53pa7whletkrml4s-if-v6exp3-v4.metric.gstatic.com
p4-andaqhcimtyrs-kbvlhfzrtagrf66p-916825-i1-v6exp3.v4.metric.gstatic.com
p4-andaqhcimtyrs-kbvlhfzrtagrf66p-916825-i2-v6exp3.ds.metric.gstatic.com
p4-andaqhcimtyrs-kbvlhfzrtagrf66p-if-v6exp3-v4.metric.gstatic.com
p4-anoimw6rp7xaw-b7xas2k3chqyrkui-931396-i1-v6exp3.ds.metric.gstatic.com
p4-anoimw6rp7xaw-b7xas2k3chqyrkui-931396-i2-v6exp3.v4.metric.gstatic.com
p4-anoimw6rp7xaw-b7xas2k3chqyrkui-931396-s1-v6exp3-v4.metric.gstatic.com
p4-anoimw6rp7xaw-b7xas2k3chqyrkui-if-v6exp3-v4.metric.gstatic.com
p4-aohopkfh3j2yc-a5hug2r6fzlfynzl-514615-i1-v6exp3.v4.metric.gstatic.com
p4-aohopkfh3j2yc-a5hug2r6fzlfynzl-514615-i2-v6exp3.ds.metric.gstatic.com
p4-aohopkfh3j2yc-a5hug2r6fzlfynzl-514615-s1-v6exp3-v4.metric.gstatic.com
p4-aohopkfh3j2yc-a5hug2r6fzlfynzl-if-v6exp3-v4.metric.gstatic.com
p4-apcqhmdh2ztgg-fp6ufqr2mtay6nx6-if-v6exp3-v4.metric.gstatic.com
p4-auuh22vv4idts-nprsy4spnixfffkb-if-v6exp3-v4.metric.gstatic.com
p4-awf2mryqoswny-lplzdqomitsmit4v-675920-i1-v6exp3-ds.metric.gstatic.com
p4-axcwucfqkndym-4zugfggmhfcv46t2-246232-s1-v6exp3-v4.metric.gstatic.com
p4-axcwucfqkndym-4zugfggmhfcv46t2-if-v6exp3-v4.metric.gstatic.com
p4-axzle4ljo7yq6-c7pr4ng4ngtvfi4i-870803-i1-v6exp3.v4.metric.gstatic.com
p4-axzle4ljo7yq6-c7pr4ng4ngtvfi4i-870803-i2-v6exp3.ds.metric.gstatic.com
p4-axzle4ljo7yq6-c7pr4ng4ngtvfi4i-870803-s1-v6exp3-v4.metric.gstatic.com
p4-axzle4ljo7yq6-c7pr4ng4ngtvfi4i-if-v6exp3-v4.metric.gstatic.com
p4-azcfya2k3bu7c-hvq3atzzkecfkthx-if-v6exp3-v4.metric.gstatic.com
p4-azjdn73f5cvno-u4uugijdczwoyeue-316899-i1.stbcast2-stb.metric.gstatic.com
p4-azjdn73f5cvno-u4uugijdczwoyeue-316899-i2.anycast-stb.metric.gstatic.com
p4-azjdn73f5cvno-u4uugijdczwoyeue-316899-s1-v6exp3-v4.metric.gstatic.com
p4-azjdn73f5cvno-u4uugijdczwoyeue-if-v6exp3-v4.metric.gstatic.com
p4-azx2jdl5pja2o-65ym7ke7wzmhymcb-881549-i1-v6exp3.v4.metric.gstatic.com
p4-azx2jdl5pja2o-65ym7ke7wzmhymcb-881549-i2-v6exp3.ds.metric.gstatic.com
p4-b2cjvuinryb7i-hdtlwx6lfb43vvgm-605631-i1-v6exp3.v4.metric.gstatic.com
p4-b2cjvuinryb7i-hdtlwx6lfb43vvgm-605631-i2-v6exp3.ds.metric.gstatic.com
p4-b2cjvuinryb7i-hdtlwx6lfb43vvgm-605631-s1-v6exp3-v4.metric.gstatic.com
p4-b2cjvuinryb7i-hdtlwx6lfb43vvgm-if-v6exp3-v4.metric.gstatic.com
p4-b2wxqtmcws7zw-2hbawoansacxpemp-if-v6exp3-v4.metric.gstatic.com
p4-b4o6ninlvgqfm-uiywyh2rijofosq6-810858-i1-v6exp3.ds.metric.gstatic.com
p4-b4o6ninlvgqfm-uiywyh2rijofosq6-810858-i2-v6exp3.v4.metric.gstatic.com
p4-b4o6ninlvgqfm-uiywyh2rijofosq6-810858-s1-v6exp3-v4.metric.gstatic.com
p4-b4o6ninlvgqfm-uiywyh2rijofosq6-if-v6exp3-v4.metric.gstatic.com
p4-bamoj2aukuwqi-n2he2nfkt477lnjj-if-v6exp3-v4.metric.gstatic.com
p4-bdd3ij525kkje-kf2mnch4v53ienp5-if-v6exp3-v4.metric.gstatic.com
p4-bdtcxgk23ayaa-5djp634hqbadhwjk-if-v6exp3-v4.metric.gstatic.com
p4-bqlyhrqhhk3us-3se3hbhxnmlr32ci-751434-i1-v6exp3.ds.metric.gstatic.com
p4-bqlyhrqhhk3us-3se3hbhxnmlr32ci-751434-i2-v6exp3.v4.metric.gstatic.com
p4-bqlyhrqhhk3us-3se3hbhxnmlr32ci-751434-s1-v6exp3-v4.metric.gstatic.com
p4-bqlyhrqhhk3us-3se3hbhxnmlr32ci-if-v6exp3-v4.metric.gstatic.com
p4-bqxkvohg3jjj6-tbppztuenbk54wts-260679-s1-v6exp3-v4.metric.gstatic.com
p4-bqxkvohg3jjj6-tbppztuenbk54wts-if-v6exp3-v4.metric.gstatic.com
p4-bsz4bazhpd6yw-ee2nj7ez5u3xnmps-742458-i1-v6exp3.ds.metric.gstatic.com
p4-bsz4bazhpd6yw-ee2nj7ez5u3xnmps-742458-i2-v6exp3.v4.metric.gstatic.com
p4-bsz4bazhpd6yw-ee2nj7ez5u3xnmps-742458-s1-v6exp3-v4.metric.gstatic.com
p4-bsz4bazhpd6yw-ee2nj7ez5u3xnmps-if-v6exp3-v4.metric.gstatic.com
p4-buuxzpii2mkmq-svsoqivepolszxi2-532911-i1-v6exp3.v4.metric.gstatic.com
p4-buuxzpii2mkmq-svsoqivepolszxi2-532911-i2-v6exp3.ds.metric.gstatic.com
p4-buuxzpii2mkmq-svsoqivepolszxi2-if-v6exp3-v4.metric.gstatic.com
p4-bxdnlwv25dyha-3oiu3a643bfdt2co-639526-i1-v6exp3.ds.metric.gstatic.com
p4-bxdnlwv25dyha-3oiu3a643bfdt2co-639526-i2-v6exp3.v4.metric.gstatic.com
p4-bxdnlwv25dyha-3oiu3a643bfdt2co-639526-s1-v6exp3-v4.metric.gstatic.com
p4-bxdnlwv25dyha-3oiu3a643bfdt2co-if-v6exp3-v4.metric.gstatic.com
p4-c4cmdfqwoaij4-um4rcntoakb6trmr-677543-i1-v6exp3.v4.metric.gstatic.com
p4-c4cmdfqwoaij4-um4rcntoakb6trmr-677543-i2-v6exp3.ds.metric.gstatic.com
p4-c4cmdfqwoaij4-um4rcntoakb6trmr-if-v6exp3-v4.metric.gstatic.com
p4-c4krcudt6ogbq-yywvckz3xojk5d36-406761-i1-v6exp3.v4.metric.gstatic.com
p4-c4krcudt6ogbq-yywvckz3xojk5d36-406761-i2-v6exp3.ds.metric.gstatic.com
p4-c4krcudt6ogbq-yywvckz3xojk5d36-406761-s1-v6exp3-v4.metric.gstatic.com
p4-c4krcudt6ogbq-yywvckz3xojk5d36-if-v6exp3-v4.metric.gstatic.com
p4-c5v7hkac4pady-kfiqcvx5h2x3wdtd-975644-i1-v6exp3.ds.metric.gstatic.com
p4-c5v7hkac4pady-kfiqcvx5h2x3wdtd-975644-i2-v6exp3.v4.metric.gstatic.com
p4-c5v7hkac4pady-kfiqcvx5h2x3wdtd-975644-s1-v6exp3-v4.metric.gstatic.com
p4-c5v7hkac4pady-kfiqcvx5h2x3wdtd-if-v6exp3-v4.metric.gstatic.com
p4-c73io5yusvt2a-ih7nudnpa6iimp26-818476-i1-v6exp3.ds.metric.gstatic.com
p4-c73io5yusvt2a-ih7nudnpa6iimp26-818476-i2-v6exp3.v4.metric.gstatic.com
p4-c73io5yusvt2a-ih7nudnpa6iimp26-818476-s1-v6exp3-v4.metric.gstatic.com
p4-c73io5yusvt2a-ih7nudnpa6iimp26-if-v6exp3-v4.metric.gstatic.com
p4-c7kr73ts6kqis-azlsyqtu3rfkydaj-if-v6exp3-v4.metric.gstatic.com
p4-c7p7cdt7czz5i-jf5egmz6blp4l75k-if-v6exp3-v4.metric.gstatic.com
p4-c7zrxegtmgcsc-escwxf4cdaqrjukz-if-v6exp3-v4.metric.gstatic.com
p4-cbgqg3i7aqloa-qi2ke7obppfc25uv-if-v6exp3-v4.metric.gstatic.com
p4-ccte5yxkofevq-sxn3734a6on3lr2f-if-v6exp3-v4.metric.gstatic.com
p4-cg4mmrfm32ysa-jchb2ktemt2salwt-608504-i1-v6exp3.ds.metric.gstatic.com
p4-cg4mmrfm32ysa-jchb2ktemt2salwt-608504-i2-v6exp3.v4.metric.gstatic.com
p4-cg4mmrfm32ysa-jchb2ktemt2salwt-608504-s1-v6exp3-v4.metric.gstatic.com
p4-cg4mmrfm32ysa-jchb2ktemt2salwt-if-v6exp3-v4.metric.gstatic.com
p4-chiifeozc3eca-wbmfklf6w2qp3hwr-799230-i1-v6exp3.ds.metric.gstatic.com
p4-chiifeozc3eca-wbmfklf6w2qp3hwr-799230-i2-v6exp3.v4.metric.gstatic.com
p4-chiifeozc3eca-wbmfklf6w2qp3hwr-799230-s1-v6exp3-v4.metric.gstatic.com
p4-chiifeozc3eca-wbmfklf6w2qp3hwr-if-v6exp3-v4.metric.gstatic.com
p4-ciddibtcnkyyi-b6ayyr7rqwepni76-316309-i1.stbcast2.metric.gstatic.com
p4-ciddibtcnkyyi-b6ayyr7rqwepni76-316309-i2.anycast.metric.gstatic.com
p4-ciddibtcnkyyi-b6ayyr7rqwepni76-316309-s1-v6exp3-v4.metric.gstatic.com
p4-ciddibtcnkyyi-b6ayyr7rqwepni76-if-v6exp3-v4.metric.gstatic.com
p4-ciy3rbrtzq6qw-u6z4sxs65fygwv77-if-v6exp3-v4.metric.gstatic.com
p4-coccnicd66qza-kyiiunc776qdgsok-106676-i1.stbcast.metric.gstatic.com
p4-coccnicd66qza-kyiiunc776qdgsok-106676-i2.unicast.metric.gstatic.com
p4-coccnicd66qza-kyiiunc776qdgsok-106676-s1-v6exp3-v4.metric.gstatic.com
p4-coccnicd66qza-kyiiunc776qdgsok-if-v6exp3-v4.metric.gstatic.com
p4-codfpthdyoo66-acwugconzsqbonxp-335948-i1.anycast2-stb.metric.gstatic.com
p4-codfpthdyoo66-acwugconzsqbonxp-335948-i2.unicast2-stb.metric.gstatic.com
p4-codfpthdyoo66-acwugconzsqbonxp-if-v6exp3-v4.metric.gstatic.com
p4-cthpq4xm64aty-aeq4gc3ak2upjhzm-477532-i1-v6exp3.ds.metric.gstatic.com
p4-cthpq4xm64aty-aeq4gc3ak2upjhzm-477532-i2-v6exp3.v4.metric.gstatic.com
p4-cthpq4xm64aty-aeq4gc3ak2upjhzm-477532-s1-v6exp3-v4.metric.gstatic.com
p4-cthpq4xm64aty-aeq4gc3ak2upjhzm-if-v6exp3-v4.metric.gstatic.com
p4-cwuaqev6wrtfw-ijpfxezw3tzef7l4-227543-s1-v6exp3-v4.metric.gstatic.com
p4-cwuaqev6wrtfw-ijpfxezw3tzef7l4-if-v6exp3-v4.metric.gstatic.com
p4-d3dtsmgx3l6ge-ywm5cen6qb2k2r6f-205369-i1-v6exp3.v4.metric.gstatic.com
p4-d3dtsmgx3l6ge-ywm5cen6qb2k2r6f-205369-i2-v6exp3.ds.metric.gstatic.com
p4-d3dtsmgx3l6ge-ywm5cen6qb2k2r6f-205369-s1-v6exp3-v4.metric.gstatic.com
p4-d3dtsmgx3l6ge-ywm5cen6qb2k2r6f-if-v6exp3-v4.metric.gstatic.com
p4-d3xip5yaq4j4m-tn6wxy6bu4frnavp-200784-i1-v6exp3.ds.metric.gstatic.com
p4-d3xip5yaq4j4m-tn6wxy6bu4frnavp-200784-i2-v6exp3.v4.metric.gstatic.com
p4-d3xip5yaq4j4m-tn6wxy6bu4frnavp-if-v6exp3-v4.metric.gstatic.com
p4-d4xkpdpdhj5k4-pfsgqgkke4se3lf6-if-v6exp3-v4.metric.gstatic.com
p4-d5bkry5fwhpz6-nvexyvjczwnwz5xm-702878-i1-v6exp3.ds.metric.gstatic.com
p4-d5bkry5fwhpz6-nvexyvjczwnwz5xm-702878-i2-v6exp3.v4.metric.gstatic.com
p4-d5bkry5fwhpz6-nvexyvjczwnwz5xm-702878-s1-v6exp3-v4.metric.gstatic.com
p4-d5bkry5fwhpz6-nvexyvjczwnwz5xm-if-v6exp3-v4.metric.gstatic.com
p4-dcalcjtp3jbws-u4ealxg7g3h44cph-if-v6exp3-v4.metric.gstatic.com
p4-dcisz3td6vruu-kaw6jx2kmsz64yql-160004-i1-v6exp3.ds.metric.gstatic.com
p4-dcisz3td6vruu-kaw6jx2kmsz64yql-160004-i2-v6exp3.v4.metric.gstatic.com
p4-dcisz3td6vruu-kaw6jx2kmsz64yql-if-v6exp3-v4.metric.gstatic.com
p4-ddu4cswrpon6e-3veqyytetktctwpo-995710-i1-v6exp3.ds.metric.gstatic.com
p4-ddu4cswrpon6e-3veqyytetktctwpo-995710-i2-v6exp3.v4.metric.gstatic.com
p4-ddu4cswrpon6e-3veqyytetktctwpo-995710-s1-v6exp3-v4.metric.gstatic.com
p4-ddu4cswrpon6e-3veqyytetktctwpo-if-v6exp3-v4.metric.gstatic.com
p4-dimigmuwheqig-y4mpulobhelx3swa-362377-i1-v6exp3.v4.metric.gstatic.com
p4-dimigmuwheqig-y4mpulobhelx3swa-362377-i2-v6exp3.ds.metric.gstatic.com
p4-dimigmuwheqig-y4mpulobhelx3swa-362377-s1-v6exp3-v4.metric.gstatic.com
p4-dimigmuwheqig-y4mpulobhelx3swa-if-v6exp3-v4.metric.gstatic.com
p4-dkh6p36rje4ek-bnjd7hrclb63xvmn-443413-i1-v6exp3.v4.metric.gstatic.com
p4-dkh6p36rje4ek-bnjd7hrclb63xvmn-443413-i2-v6exp3.ds.metric.gstatic.com
p4-dkh6p36rje4ek-bnjd7hrclb63xvmn-443413-s1-v6exp3-v4.metric.gstatic.com
p4-dkh6p36rje4ek-bnjd7hrclb63xvmn-if-v6exp3-v4.metric.gstatic.com
p4-dkpeqfjquqz2w-djxetwiwsnpmmz44-427341-i1-v6exp3.v4.metric.gstatic.com
p4-dkpeqfjquqz2w-djxetwiwsnpmmz44-427341-i2-v6exp3.ds.metric.gstatic.com
p4-dkpeqfjquqz2w-djxetwiwsnpmmz44-427341-s1-v6exp3-v4.metric.gstatic.com
p4-dkpeqfjquqz2w-djxetwiwsnpmmz44-if-v6exp3-v4.metric.gstatic.com
p4-dpyuw5anlse5o-55skiztpcz3f5wjs-626043-i1-v6exp3.v4.metric.gstatic.com
p4-dpyuw5anlse5o-55skiztpcz3f5wjs-626043-i2-v6exp3.ds.metric.gstatic.com
p4-dpyuw5anlse5o-55skiztpcz3f5wjs-626043-s1-v6exp3-v4.metric.gstatic.com
p4-dpyuw5anlse5o-55skiztpcz3f5wjs-if-v6exp3-v4.metric.gstatic.com
p4-ds7sfsq6bygsy-6psypef36uaxefjt-471605-i1-v6exp3.v4.metric.gstatic.com
p4-ds7sfsq6bygsy-6psypef36uaxefjt-471605-i2-v6exp3.ds.metric.gstatic.com
p4-ds7sfsq6bygsy-6psypef36uaxefjt-if-v6exp3-v4.metric.gstatic.com
p4-dtb6ftqnv6nfs-jdtcp5o2lbmrxinv-451629-i1-v6exp3.v4.metric.gstatic.com
p4-dtb6ftqnv6nfs-jdtcp5o2lbmrxinv-451629-i2-v6exp3.ds.metric.gstatic.com
p4-dtb6ftqnv6nfs-jdtcp5o2lbmrxinv-451629-s1-v6exp3-v4.metric.gstatic.com
p4-dtb6ftqnv6nfs-jdtcp5o2lbmrxinv-if-v6exp3-v4.metric.gstatic.com
p4-dtz7wdnx74nwk-m4j5jhrqboaj6lqy-if-v6exp3-v4.metric.gstatic.com
p4-dxb23zr4rwme6-toywnvyksulwh7wt-if-v6exp3-v4.metric.gstatic.com
p4-dzu6idx2j75c4-z7w5vpsutqxepyyk-if-v6exp3-v4.metric.gstatic.com
p4-e3g42yyhs6zlo-oxdwrlz7o2po6qdd-if-v6exp3-v4.metric.gstatic.com
p4-e5ytte2xgget4-kfawemnvshtpczre-717422-i1-v6exp3.ds.metric.gstatic.com
p4-e5ytte2xgget4-kfawemnvshtpczre-717422-i2-v6exp3.v4.metric.gstatic.com
p4-e5ytte2xgget4-kfawemnvshtpczre-if-v6exp3-v4.metric.gstatic.com
p4-e6fnhqpypyt66-wunfeblz7xnpcdq7-762564-i1-v6exp3.ds.metric.gstatic.com
p4-e6fnhqpypyt66-wunfeblz7xnpcdq7-762564-i2-v6exp3.v4.metric.gstatic.com
p4-e6fnhqpypyt66-wunfeblz7xnpcdq7-if-v6exp3-v4.metric.gstatic.com
p4-eaoggdgo4svvq-xwdluticsynxiyfc-521614-i1-v6exp3.ds.metric.gstatic.com
p4-eaoggdgo4svvq-xwdluticsynxiyfc-521614-i2-v6exp3.v4.metric.gstatic.com
p4-eaoggdgo4svvq-xwdluticsynxiyfc-521614-s1-v6exp3-v4.metric.gstatic.com
p4-eaoggdgo4svvq-xwdluticsynxiyfc-if-v6exp3-v4.metric.gstatic.com
p4-eeiwmr7wl3ggc-ksyyzcsj3kq7vk2l-820533-s1-v6exp3-v4.metric.gstatic.com
p4-efbcrkxx56tdc-dfzwsdzl547grqqd-if-v6exp3-v4.metric.gstatic.com
p4-ejvvfs66ms36y-nsomci5kmtrc5q6o-if-v6exp3-v4.metric.gstatic.com
p4-en6h7rtxmavjg-hjbp3sjlolhaamso-457865-i1-v6exp3.v4.metric.gstatic.com
p4-en6h7rtxmavjg-hjbp3sjlolhaamso-457865-i2-v6exp3.ds.metric.gstatic.com
p4-en6h7rtxmavjg-hjbp3sjlolhaamso-457865-s1-v6exp3-v4.metric.gstatic.com
p4-en6h7rtxmavjg-hjbp3sjlolhaamso-if-v6exp3-v4.metric.gstatic.com
p4-endozb75rkpmw-435eqw6r2bykzyks-841476-i1-v6exp3.ds.metric.gstatic.com
p4-endozb75rkpmw-435eqw6r2bykzyks-841476-i2-v6exp3.v4.metric.gstatic.com
p4-endozb75rkpmw-435eqw6r2bykzyks-if-v6exp3-v4.metric.gstatic.com
p4-erm6te4eqst3q-tjigzxnodrm6t7qp-334431-i1.unicast2.metric.gstatic.com
p4-erm6te4eqst3q-tjigzxnodrm6t7qp-334431-i2.anycast2.metric.gstatic.com
p4-erm6te4eqst3q-tjigzxnodrm6t7qp-334431-s1-v6exp3-v4.metric.gstatic.com
p4-erm6te4eqst3q-tjigzxnodrm6t7qp-if-v6exp3-v4.metric.gstatic.com
p4-etnrszofktypa-5koemx3msbgfjoxd-379045-i1-v6exp3.v4.metric.gstatic.com
p4-etnrszofktypa-5koemx3msbgfjoxd-379045-i2-v6exp3.ds.metric.gstatic.com
p4-etnrszofktypa-5koemx3msbgfjoxd-if-v6exp3-v4.metric.gstatic.com
p4-etvscxd6bkrwo-mxpps4fb5fs24gst-291819-i1.stbcast3-stb.metric.gstatic.com
p4-etvscxd6bkrwo-mxpps4fb5fs24gst-291819-i2.stbcast4-stb.metric.gstatic.com
p4-etvscxd6bkrwo-mxpps4fb5fs24gst-291819-s1-v6exp3-v4.metric.gstatic.com
p4-etvscxd6bkrwo-mxpps4fb5fs24gst-if-v6exp3-v4.metric.gstatic.com
p4-eyh2uteevue7g-hwlmmgttnipuqgul-412853-i1-v6exp3.v4.metric.gstatic.com
p4-eyh2uteevue7g-hwlmmgttnipuqgul-412853-i2-v6exp3.ds.metric.gstatic.com
p4-eyh2uteevue7g-hwlmmgttnipuqgul-412853-s1-v6exp3-v4.metric.gstatic.com
p4-eyh2uteevue7g-hwlmmgttnipuqgul-if-v6exp3-v4.metric.gstatic.com
p4-fbiyrcdan76zy-y2ahjsoma6t4rgxg-841131-s1-v6exp3-v4.metric.gstatic.com
p4-fdssjgqt7ah4e-ifbujyboezv7zlsf-if-v6exp3-v4.metric.gstatic.com
p4-fg7fsr3ywyjuq-7gdkvjxwt34d6vqd-713448-i1-v6exp3.ds.metric.gstatic.com
p4-fg7fsr3ywyjuq-7gdkvjxwt34d6vqd-713448-i2-v6exp3.v4.metric.gstatic.com
p4-fg7fsr3ywyjuq-7gdkvjxwt34d6vqd-713448-s1-v6exp3-v4.metric.gstatic.com
p4-fg7fsr3ywyjuq-7gdkvjxwt34d6vqd-if-v6exp3-v4.metric.gstatic.com
p4-fgoerdqajziqm-oh43mb25k76w7pkw-if-v6exp3-v4.metric.gstatic.com
p4-fgz4grek4mwv6-bbntrmhnnmf3q4vm-if-v6exp3-v4.metric.gstatic.com
p4-fhz6jndoreuac-rz4xegzyp6tgpqds-312694-i1.anycast-stb.metric.gstatic.com
p4-fhz6jndoreuac-rz4xegzyp6tgpqds-312694-i2.stbcast2-stb.metric.gstatic.com
p4-fhz6jndoreuac-rz4xegzyp6tgpqds-if-v6exp3-v4.metric.gstatic.com
p4-fkoaemnghcs46-sjleglwip7fod5li-298265-i1.stbcast3-stb.metric.gstatic.com
p4-fkoaemnghcs46-sjleglwip7fod5li-298265-i2.stbcast4-stb.metric.gstatic.com
p4-fkoaemnghcs46-sjleglwip7fod5li-298265-s1-v6exp3-v4.metric.gstatic.com
p4-fkoaemnghcs46-sjleglwip7fod5li-if-v6exp3-v4.metric.gstatic.com
p4-flfylbiefblkg-laskv23n63mur5g5-563704-i1-v6exp3.ds.metric.gstatic.com
p4-flfylbiefblkg-laskv23n63mur5g5-563704-i2-v6exp3.v4.metric.gstatic.com
p4-flfylbiefblkg-laskv23n63mur5g5-563704-s1-v6exp3-v4.metric.gstatic.com
p4-flfylbiefblkg-laskv23n63mur5g5-if-v6exp3-v4.metric.gstatic.com
p4-fqoygbo2ssreq-5wf5fae3dfbg4n35-621724-i1-v6exp3.ds.metric.gstatic.com
p4-fqoygbo2ssreq-5wf5fae3dfbg4n35-621724-i2-v6exp3.v4.metric.gstatic.com
p4-fqoygbo2ssreq-5wf5fae3dfbg4n35-621724-s1-v6exp3-v4.metric.gstatic.com
p4-fqoygbo2ssreq-5wf5fae3dfbg4n35-if-v6exp3-v4.metric.gstatic.com
p4-frhqcmz4oqrhy-rbye3zi266xkoiot-125162-i1-v6exp3.ds.metric.gstatic.com
p4-frhqcmz4oqrhy-rbye3zi266xkoiot-125162-i2-v6exp3.v4.metric.gstatic.com
p4-frhqcmz4oqrhy-rbye3zi266xkoiot-125162-s1-v6exp3-v4.metric.gstatic.com
p4-frhqcmz4oqrhy-rbye3zi266xkoiot-if-v6exp3-v4.metric.gstatic.com
p4-fsagtxitjnq5g-fzr645apr3lwm6sy-if-v6exp3-v4.metric.gstatic.com
p4-ftmlnqc4fidhc-7qocd6ok4s3ijidg-if-v6exp3-v4.metric.gstatic.com
p4-ftwliee4sex2k-bwnng7g2u6s7hzrm-311490-i1.anycast-stb.metric.gstatic.com
p4-ftwliee4sex2k-bwnng7g2u6s7hzrm-311490-i2.stbcast2-stb.metric.gstatic.com
p4-ftwliee4sex2k-bwnng7g2u6s7hzrm-311490-s1-v6exp3-v4.metric.gstatic.com
p4-ftwliee4sex2k-bwnng7g2u6s7hzrm-if-v6exp3-v4.metric.gstatic.com
p4-fueuzncg6d4yk-huw4vsyvfps54yr7-207267-i1-v6exp3.v4.metric.gstatic.com
p4-fueuzncg6d4yk-huw4vsyvfps54yr7-207267-i2-v6exp3.ds.metric.gstatic.com
p4-fueuzncg6d4yk-huw4vsyvfps54yr7-if-v6exp3-v4.metric.gstatic.com
p4-fvsadmkly4b2u-fy2mxlqkadeioyo4-208022-i2-v6exp3-ds.metric.gstatic.com
p4-fwhzspbg5syv6-e2ftmlxzi2kscmkl-464838-i1-v6exp3.ds.metric.gstatic.com
p4-fwhzspbg5syv6-e2ftmlxzi2kscmkl-464838-i2-v6exp3.v4.metric.gstatic.com
p4-fwhzspbg5syv6-e2ftmlxzi2kscmkl-if-v6exp3-v4.metric.gstatic.com
p4-fzozu2cnclhja-sleenrz4kpd4cwgc-757870-i1-v6exp3-ds.metric.gstatic.com
p4-fzrmpiluwyga6-w5rogdzzxq2i6zjk-143168-i1-v6exp3.ds.metric.gstatic.com
p4-fzrmpiluwyga6-w5rogdzzxq2i6zjk-143168-i2-v6exp3.v4.metric.gstatic.com
p4-fzrmpiluwyga6-w5rogdzzxq2i6zjk-143168-s1-v6exp3-v4.metric.gstatic.com
p4-fzrmpiluwyga6-w5rogdzzxq2i6zjk-if-v6exp3-v4.metric.gstatic.com
p4-g3qxlf54lgayo-jdou52dv6qkzksls-821555-i1-v6exp3.v4.metric.gstatic.com
p4-g3qxlf54lgayo-jdou52dv6qkzksls-821555-i2-v6exp3.ds.metric.gstatic.com
p4-g3qxlf54lgayo-jdou52dv6qkzksls-if-v6exp3-v4.metric.gstatic.com
p4-g4qhmjal25hd6-gfd6jw4ihqzpqvqx-if-v6exp3-v4.metric.gstatic.com
p4-g5z2iczumafaa-pcphizpovan7k2pu-707982-i1-v6exp3.ds.metric.gstatic.com
p4-g5z2iczumafaa-pcphizpovan7k2pu-707982-i2-v6exp3.v4.metric.gstatic.com
p4-g5z2iczumafaa-pcphizpovan7k2pu-707982-s1-v6exp3-v4.metric.gstatic.com
p4-g5z2iczumafaa-pcphizpovan7k2pu-if-v6exp3-v4.metric.gstatic.com
p4-g6ycurr6r4eey-gkwwp44qokkhghl4-if-v6exp3-v4.metric.gstatic.com
p4-g72qimqn7gesk-y543r5zvz25emr7b-if-v6exp3-v4.metric.gstatic.com
p4-gegkkrvghohxy-v42smcq2rostut3w-if-v6exp3-v4.metric.gstatic.com
p4-ggwurtailastq-fq25dajduthpscb2-if-v6exp3-v4.metric.gstatic.com
p4-gmsqlnn2ucaf4-qxbl32h4kw3kdtn6-if-v6exp3-v4.metric.gstatic.com
p4-gqmnr2ogf4vga-2j3xgesx6vcfpykb-561178-i1-v6exp3.ds.metric.gstatic.com
p4-gqmnr2ogf4vga-2j3xgesx6vcfpykb-561178-i2-v6exp3.v4.metric.gstatic.com
p4-gqmnr2ogf4vga-2j3xgesx6vcfpykb-561178-s1-v6exp3-v4.metric.gstatic.com
p4-gqmnr2ogf4vga-2j3xgesx6vcfpykb-if-v6exp3-v4.metric.gstatic.com
p4-gtwkde7dcyvf2-zxztjbd4gyd3niii-500822-i1-v6exp3.ds.metric.gstatic.com
p4-gtwkde7dcyvf2-zxztjbd4gyd3niii-500822-i2-v6exp3.v4.metric.gstatic.com
p4-gtwkde7dcyvf2-zxztjbd4gyd3niii-if-v6exp3-v4.metric.gstatic.com
p4-gua6ilgkj6222-c37u6zka7ys5pa27-if-v6exp3-v4.metric.gstatic.com
p4-gukp5tywozhji-ltv4g2p6ldbdzil4-551096-i1-v6exp3.ds.metric.gstatic.com
p4-gukp5tywozhji-ltv4g2p6ldbdzil4-551096-i2-v6exp3.v4.metric.gstatic.com
p4-gukp5tywozhji-ltv4g2p6ldbdzil4-551096-s1-v6exp3-v4.metric.gstatic.com
p4-gukp5tywozhji-ltv4g2p6ldbdzil4-if-v6exp3-v4.metric.gstatic.com
p4-guxpfb7fvzwss-vjs7g7p73xf5tu6a-594261-i1-v6exp3.v4.metric.gstatic.com
p4-guxpfb7fvzwss-vjs7g7p73xf5tu6a-594261-i2-v6exp3.ds.metric.gstatic.com
p4-guxpfb7fvzwss-vjs7g7p73xf5tu6a-594261-s1-v6exp3-v4.metric.gstatic.com
p4-guxpfb7fvzwss-vjs7g7p73xf5tu6a-if-v6exp3-v4.metric.gstatic.com
p4-gvbdqooh5kulc-qhnnwffthhqojds4-595915-i1-v6exp3.v4.metric.gstatic.com
p4-gvbdqooh5kulc-qhnnwffthhqojds4-595915-i2-v6exp3.ds.metric.gstatic.com
p4-gvbdqooh5kulc-qhnnwffthhqojds4-595915-s1-v6exp3-v4.metric.gstatic.com
p4-gvbdqooh5kulc-qhnnwffthhqojds4-if-v6exp3-v4.metric.gstatic.com
p4-h5w65eaw3ov2c-ujpao36frqupenqo-if-v6exp3-v4.metric.gstatic.com
p4-hatymyxvgi7ig-ojnm26sperilw2rx-341754-i1.anycast2-stb.metric.gstatic.com
p4-hatymyxvgi7ig-ojnm26sperilw2rx-341754-i2.unicast2-stb.metric.gstatic.com
p4-hatymyxvgi7ig-ojnm26sperilw2rx-if-v6exp3-v4.metric.gstatic.com
p4-hgloyfdan544w-bjgxplzr6izsu2tj-701609-i1-v6exp3.v4.metric.gstatic.com
p4-hgloyfdan544w-bjgxplzr6izsu2tj-701609-i2-v6exp3.ds.metric.gstatic.com
p4-hgloyfdan544w-bjgxplzr6izsu2tj-701609-s1-v6exp3-v4.metric.gstatic.com
p4-hgloyfdan544w-bjgxplzr6izsu2tj-if-v6exp3-v4.metric.gstatic.com
p4-hhuyiuz4g64vm-6s2ygcco3xkqe7oz-662137-i1-v6exp3.v4.metric.gstatic.com
p4-hhuyiuz4g64vm-6s2ygcco3xkqe7oz-662137-i2-v6exp3.ds.metric.gstatic.com
p4-hhuyiuz4g64vm-6s2ygcco3xkqe7oz-if-v6exp3-v4.metric.gstatic.com
p4-hi3uhbm3q7k36-kowjgemzxg5wm2zs-246817-s1-v6exp3-v4.metric.gstatic.com
p4-hi3uhbm3q7k36-kowjgemzxg5wm2zs-if-v6exp3-v4.metric.gstatic.com
p4-hibqdjoow4vms-zj4v337wjmgo3sqs-814212-i1-v6exp3.ds.metric.gstatic.com
p4-hibqdjoow4vms-zj4v337wjmgo3sqs-814212-i2-v6exp3.v4.metric.gstatic.com
p4-hibqdjoow4vms-zj4v337wjmgo3sqs-if-v6exp3-v4.metric.gstatic.com
p4-hj3ux4lslfdzg-i7ht4kx4rqwp67zv-if-v6exp3-v4.metric.gstatic.com
p4-hmp3ziwuwsya6-ccf3tio5ddow2d2i-957556-i1-v6exp3.ds.metric.gstatic.com
p4-hmp3ziwuwsya6-ccf3tio5ddow2d2i-957556-i2-v6exp3.v4.metric.gstatic.com
p4-hmp3ziwuwsya6-ccf3tio5ddow2d2i-957556-s1-v6exp3-v4.metric.gstatic.com
p4-hmp3ziwuwsya6-ccf3tio5ddow2d2i-if-v6exp3-v4.metric.gstatic.com
p4-hod2gfe5vgrw4-7i23fvuysgxwg7bz-254388-s1-v6exp3-v4.metric.gstatic.com
p4-hod2gfe5vgrw4-7i23fvuysgxwg7bz-if-v6exp3-v4.metric.gstatic.com
p4-hr5x2zzm3334c-oq4kivioo3g37h5c-111452-i1.stbcast-stb.metric.gstatic.com
p4-hr5x2zzm3334c-oq4kivioo3g37h5c-111452-i2.unicast-stb.metric.gstatic.com
p4-hr5x2zzm3334c-oq4kivioo3g37h5c-111452-s1-v6exp3-v4.metric.gstatic.com
p4-hr5x2zzm3334c-oq4kivioo3g37h5c-if-v6exp3-v4.metric.gstatic.com
p4-hyzysbg2apwyw-unhf35lj2gkhnxzg-995684-i1-v6exp3.ds.metric.gstatic.com
p4-hyzysbg2apwyw-unhf35lj2gkhnxzg-995684-i2-v6exp3.v4.metric.gstatic.com
p4-hyzysbg2apwyw-unhf35lj2gkhnxzg-if-v6exp3-v4.metric.gstatic.com
p5-azm2zsgzroypu-j6t3d2k6qfkm5pp3-131709-i1-v6exp3.v4.metric.gstatic.com
p5-azm2zsgzroypu-j6t3d2k6qfkm5pp3-131709-i2-v6exp3.ds.metric.gstatic.com
p5-edsa6awevd5tc-j345tuw32lviv5in-679704-i1-v6exp3.ds.metric.gstatic.com
p5-edsa6awevd5tc-j345tuw32lviv5in-679704-i2-v6exp3.v4.metric.gstatic.com
p5-gweeeecyebjn2-j2bzo5yvzsdh2e4j-493639-i1-v6exp3.v4.metric.gstatic.com
p5-gweeeecyebjn2-j2bzo5yvzsdh2e4j-493639-i2-v6exp3.ds.metric.gstatic.com
p5-icemo7qkj2eya-52psaso3huyvnqqz-297531-i1.stbcast3.metric.gstatic.com
p5-icemo7qkj2eya-52psaso3huyvnqqz-297531-i2.stbcast4.metric.gstatic.com
p5-icemo7qkj2eya-52psaso3huyvnqqz-297531-s1-v6exp3-v4.metric.gstatic.com
p5-leclabnbo2pba-vfblo2qjncrb2sk4-328953-i1-unicast3.metric.gstatic.com
p5-leclabnbo2pba-vfblo2qjncrb2sk4-328953-i2-unicast4.metric.gstatic.com
p5-leclabnbo2pba-vfblo2qjncrb2sk4-328953-s1-v6exp3-v4.metric.gstatic.com
p5-lhw4jk4anlzk2-i63aajw7rkfmqnb7-248277-s1-v6exp3-v4.metric.gstatic.com
p5-lj5aujgj7jl7w-r2pmxqvndsgx2im2-931517-i1-v6exp3-v4.metric.gstatic.com
p5-lj5aujgj7jl7w-r2pmxqvndsgx2im2-931517-i2-v6exp3-ds.metric.gstatic.com
p5-lqenzr74px6mi-4s44bg5bqxyl7qbb-121319-i1-v6exp3.v4.metric.gstatic.com
p5-lqenzr74px6mi-4s44bg5bqxyl7qbb-121319-i2-v6exp3.ds.metric.gstatic.com
p5-lqenzr74px6mi-4s44bg5bqxyl7qbb-121319-s1-v6exp3-v4.metric.gstatic.com
p5-qwe7ttoqo46gw-3zkklvrd3vf77lxd-290843-i1.stbcast2-stb.metric.gstatic.com
p5-qwe7ttoqo46gw-3zkklvrd3vf77lxd-290843-i1.stbcast3-stb.metric.gstatic.com
p5-qwe7ttoqo46gw-3zkklvrd3vf77lxd-290843-i2.stbcast4-stb.metric.gstatic.com
p5-uxutwekbvq3he-hbq2ivvnkctx25z6-517216-i1-v6exp3.ds.metric.gstatic.com
p5-uxutwekbvq3he-hbq2ivvnkctx25z6-517216-i2-v6exp3.v4.metric.gstatic.com
p5-wknln4jd5q3qm-ik4z2y35yknm3pf6-576092-i2-v6exp3.v4.metric.gstatic.com
p5-wyy773liffdba-dgrv56uw7xwp7h7r-514802-i2-v6exp3.v4.metric.gstatic.com
p5-xcuk27iy7sqz2-lvtolymj4ju2ha3l-523822-i1-v6exp3.ds.metric.gstatic.com
p5-xcuk27iy7sqz2-lvtolymj4ju2ha3l-523822-i2-v6exp3.v4.metric.gstatic.com
p5-z6ncvqrb65bss-ypxh225pzjntuicv-200594-i1-v6exp3.ds.metric.gstatic.com
s-v6exp1-ds.metric.gstatic.com
s-v6exp1-v4.metric.gstatic.com
s6.netlogstatic.com
sg12.zopim.comssl.gstatic.comstatic.getclicky.com
test-ipv6-dot-com-v6exp3-v4.metric.gstatic.com
unicast-edge.metric.gstatic.com
Match found in https://v.firebog.net/hosts/AdguardDNS.txt:
metric.gstatic.com
Match found in https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt:
Match found in https://hosts-file.net/ad_servers.txt:
csi.gstatic.com
s6.netlogstatic.com
Match found in https://v.firebog.net/hosts/Easyprivacy.txt:
csi.gstatic.com
Match found in https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts:
csi.gstatic.com
Would your blacklist regex produce a match?
I had exactly the same issue with fonts.gstatic.com.
In the end I switched to the CNAME_inspection_details branch and it turned out to be a CNAME block.
DL6ER
February 11, 2020, 12:39pm
15
The CNAME analysis code should become part of the beta, soon. The necessary FTL code changes are currently under review.
As the web interface changes are already included, it's currently sufficient to only check out the FTL branch.
DL6ER
Split this topic
February 11, 2020, 4:29pm
16
