Problem with FTL and dnsmasq after pihole -up
v4-0
#1
Pihole works normally after update, able to resolve DNS addresses.
After running pihole -up, it will not resolve DNS addresses. I can’t tell if there’s an issue with dnsmasq or FTL. The web GUI reads Lost Connection to API in the 4 differently colored status boxes.
I had to manually update /etc/resolv.conf to change 127.0.0.1 to a different DNS just so I could get the debug to upload since apparently dnsmasq isn’t working.
One other thing to note – i’m running pi-hole in an LXC container on an Intel NUC, it’s been working great for 2+ years, this is the first issue I’ve had.
8cxcemecwx
Other maybe helpful information:
root@pi-hole:~# cat /etc/os-release
NAME=“Ubuntu”
VERSION=“16.04.5 LTS (Xenial Xerus)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 16.04.5 LTS”
VERSION_ID=“16.04”
HOME_URL=“http://www.ubuntu.com/
SUPPORT_URL=“http://help.ubuntu.com/
BUG_REPORT_URL=“http://bugs.launchpad.net/ubuntu/
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
root@pi-hole:~# service dnsmasq status
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; disabled; vendor preset: enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: inactive (dead)
root@pi-hole:~# systemctl status pihole-FTL.service
Loaded: loaded (/etc/init.d/pihole-FTL; bad; vendor preset: enabled)
Active: active (exited) since Sat 2018-08-11 10:00:36 EDT; 10min ago
Aug 11 10:00:36 pi-hole pihole-FTL[1672]: chown: cannot access ‘/etc/pihole/dhcp.leases’: No such file or directory
Aug 11 10:00:36 pi-hole pihole-FTL[1672]: Failed to set capabilities on file `/usr/bin/pihole-FTL’ (Invalid argument
Aug 11 10:00:36 pi-hole pihole-FTL[1672]: The value of the capability argument is not permitted for a file. Or the f
Aug 11 10:00:36 pi-hole su[1696]: Successful su for pihole by root
Aug 11 10:00:36 pi-hole su[1696]: + ??? root:pihole
Aug 11 10:00:36 pi-hole su[1696]: pam_unix(su:session): session opened for user pihole by (uid=0)
Aug 11 10:00:36 pi-hole pihole-FTL[1672]: dnsmasq: failed to create listening socket for port 53: Permission denied
Aug 11 10:00:36 pi-hole systemd[1]: Started LSB: pihole-FTL daemon.
Aug 11 10:00:45 pi-hole systemd[1]: Started LSB: pihole-FTL daemon.
Aug 11 10:01:37 pi-hole systemd[1]: Started LSB: pihole-FTL daemon.
root@pi-hole:~# pihole status
[✗] DNS service is NOT running
root@pi-hole:~# dnsmasq --version
Dnsmasq version 2.75 Copyright © 2000-2015 Simon Kelley
Compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
DNS Service not running - Ubuntu 16.04.5 LTS
#3
Your debug log shows you at V4 for everything, so you are updated.
Note that with V4 and FTLDNS, dnsmasq is no longer run as a process, since pihole-FTL does this function. This link has additional info: https://docs.pi-hole.net/ftldns/dns-resolver/
Your debug log shows lightttpd and pihole-FTL daemons active, but nothing using ports 80 and 53 respectively, which those should be using.
Run the following to restart FTL and see if this improves things:
sudo service pihole-FTL restart
#5
I get the same error: not sure why it says active (exited).
root@pi-hole2:~# service pihole-FTL restart
root@pi-hole2:~# systemctl status pihole-FTL
Active: active (exited) since Sat 2018-08-11 16:12:53 UTC; 2s ago
Process: 2983 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
Process: 2987 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Aug 11 16:12:53 pi-hole2 systemd[1]: Starting LSB: pihole-FTL daemon…
Aug 11 16:12:53 pi-hole2 pihole-FTL[2987]: Not running
Aug 11 16:12:53 pi-hole2 pihole-FTL[2987]: chown: cannot access ‘/etc/pihole/dhcp.leases’: No such file or directory
Aug 11 16:12:53 pi-hole2 pihole-FTL[2987]: Failed to set capabilities on file `/usr/bin/pihole-FTL’ (Invalid argumen
Aug 11 16:12:53 pi-hole2 pihole-FTL[2987]: The value of the capability argument is not permitted for a file. Or the
Aug 11 16:12:53 pi-hole2 su[3011]: Successful su for pihole by root
Aug 11 16:12:53 pi-hole2 su[3011]: + ??? root:pihole
Aug 11 16:12:53 pi-hole2 su[3011]: pam_unix(su:session): session opened for user pihole by (uid=0)
Aug 11 16:12:53 pi-hole2 pihole-FTL[2987]: dnsmasq: failed to create listening socket for port 53: Permission denied
Aug 11 16:12:53 pi-hole2 systemd[1]: Started LSB: pihole-FTL daemon.
#7
This issue seems to match this other topic: DNS Unable to start and FTL offline v 4.0
#8
@Mcat12 - agreed this seems similiar. I wonder if I’m running into this since I’m running pi-hole inside an LXD container on an Ubuntu 16.04 server on an Intel NUC.
Can you help me understand what changes I need to perform the following? I think this will help my issue.
modify the startup scripts of pihole-FTL to ensure the daemon is started as root.
#9
In your /etc/init.d/pihole-FTL you can find a line
su -s /bin/sh -c "/usr/bin/pihole-FTL" "$FTLUSER"
replace it by
/usr/bin/pihole-FTL
#10
Yep! That fixed it immediately.
Are there any security concerns operating in this mode?
I presume it’ll get wiped out again if I run
pihole -up
#11
No, not really. dnsmasq is always started as root we just preferred to start pihole-FTL under an unprivileged user such as pihole. It’s kind of a security model in the sense of “if there is a bug in the code, it can cause less harm under a non-root user”.
#12
This seems like the problem I am facing. Can you show me exactly how this line suppose to look in its entirely after the edit? Thanks.
replace it by
/usr/bin/pihole-FTL
#13
It’s as simple as you think it is – the whole line gets replaced.
Afterwards that line should only read:
/usr/bin/pihole-FTL
#14
Ah. That was simple enough indeed. However, it didn’t help with my issue. I did created a thread about it.
