Hello
DNS will start start after repeated restarts and initiating from the Phihole UI.
The Pilhole UI show dns status service not running. I also shows FTL not running.
zyr6jrxvhu
Loaded: loaded (/etc/init.d/pihole-FTL; bad; vendor preset: enabled)
Active: active (exited) since Sat 2018-08-11 13:42:47 EDT; 33min ago
Process: 1764 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SU
Aug 11 13:42:44 amlogic pihole-FTL[1764]: Failed to set capabilities on file `/u
Aug 11 13:42:44 amlogic pihole-FTL[1764]: The value of the capability argument i
Aug 11 13:42:45 amlogic su[1934]: Successful su for pihole by root
Aug 11 13:42:45 amlogic su[1934]: + ??? root:pihole
Aug 11 13:42:45 amlogic su[1934]: pam_unix(su:session): session opened for user
Aug 11 13:42:47 amlogic pihole-FTL[1764]: dnsmasq: failed to create listening so
Aug 11 13:42:47 amlogic systemd[1]: Started LSB: pihole-FTL daemon.
Aug 11 13:49:57 amlogic systemd[1]: Started LSB: pihole-FTL daemon.
Aug 11 13:50:09 amlogic systemd[1]: Started LSB: pihole-FTL daemon.
Aug 11 14:13:52 amlogic systemd[1]: Started LSB: pihole-FTL daemon.
You can not grant users specific permissions, besides giving them sudo access. You can however give programs different capabilities, which is what we do with FTL. However, your system does not support that.
hmm problem is i know this kernel will support a amlogic 905x processor on a sdcard. What version of Ubuntu will support the capability you referenced in your previous thread?
root@amlogic:~# sudo systemctl status --full --no-pager pihole-FTL.service
Active: active (exited) since Sat 2018-08-11 14:27:22 EDT; 57min ago
Aug 11 14:27:21 amlogic pihole-FTL[9203]: Not running
Aug 11 14:27:21 amlogic pihole-FTL[9203]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Aug 11 14:27:21 amlogic pihole-FTL[9203]: Failed to set capabilities on file `/usr/bin/pihole-FTL' (Invalid argument)
Aug 11 14:27:21 amlogic pihole-FTL[9203]: The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
Aug 11 14:27:22 amlogic su[9228]: Successful su for pihole by root
Aug 11 14:27:22 amlogic su[9228]: + ??? root:pihole
Aug 11 14:27:22 amlogic su[9228]: pam_unix(su:session): session opened for user pihole by (uid=0)
Aug 11 14:27:22 amlogic pihole-FTL[9203]: dnsmasq: failed to create listening socket for port 53: Permission denied
Aug 11 14:27:22 amlogic systemd[1]: Started LSB: pihole-FTL daemon.
Aug 11 14:27:40 amlogic systemd[1]: Started LSB: pihole-FTL daemon.
root@amlogic:~# sudo setcap CAP_NET_BIND_SERVICE,CAP_NET_RAW,CAP_NET_ADMIN+eip /usr/bin/pihole-FTL
root@amlogic:~# sudo ls -lah /usr/bin/pihole-FTL
-rwxr-xr-x 1 root root 4.1M Aug 10 04:29 /usr/bin/pihole-FTL
root@amlogic:~#
Those are all the necessary commands for running FTLDNS. Since it is failing it does not look like we will be able to support that distribution or platform. What kind of server/board is it and what are you using for the distribution?
this distro , 4.16.1-amlogics905x
, supports the board on my Nexbox device (old andriod based media box). I have repurposed the device via sdcard boot to run pihole explicitly.
Users that cannot use Linux capabilites for various reasons (lacking kernel or file system support) can modify the startup scripts of pihole-FTL to ensure the daemon is started as
