Setup Pi hole, set static IP for it on a Netgear WNDR3700v4, ads are blocked
DNS doesn't resolve for any url.
Can generate if needed.
Please upload a debug log and post the token. Thanks.
Will do.
Also, I think the issue might be because my home router is its own nat and DCHP. If I don't then I can't change DNS on the ISP supplied router.
Would setting the "router behind router" config in fix this?
This may be the case. The also might be a DNS setting buried somewhere in the router setup menus that is letting DNS bypass the Pi-Hole.
For routers where you can't change DNS, use the Pi-Hole DHCP server and turn off this feature in the router.
I can set it on my router, but then all devices thing its the DNS(10.0.0.1) vs the Pi(10.0.0.50).
You can set what?
