Pi-hole DNS not resolving
Pi-hole resolves DNS queries made by clients
DNS requests made to the pi-hole are not resolving
a38rbm4607
Your debug log shows that your Pi-Hole is working properly. The problem appears to be in the configuration of your router and/or clients to use the Pi-Hole.
I would start with manually assigning the Pi-Hole as DNS on a single client, and get that client working on Pi-Hole. Then work on the router assignment to get the entire network on Pi-Hole.
I have my router DNS set to be the pi-hole. When I set the DNS to the pi-hole nothing loads, but when I set it back to Cloudflare DNS everything is fine again.
Since the debug log is showing that the Pi can properly resolve queries, this is an indicator of a router problem. By manually assigning a client to Pi-Hole, you can verify that Pi-Hole is working and see the client queries populate the Pi-Hole log.
Let's do some basic troubleshooting. From a client, run the following commands and post the output:
nslookup pi-hole.net
nslookup pi-hole.net 192.168.1.94
nslookup flurry.com 192.168.1.94
From the Pi terminal run these commands and post the output:
dig pi-hole.net
dig flurry.com
I set the Windows 10 machine I ran these on to use the pi-hole.
Server: raspberrypi
Address: 192.168.1.94
Non-authoritative answer:
Addresses: 2604:a880:400:d0::1071:1
206.189.252.21
Server: raspberrypi
206.189.252.21
Server: raspberrypi
Addresses: ::
0.0.0.0
dig pi-hole.net
; <<>> DiG 9.10.3-P4-Raspbian <<>> pi-hole.net
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 29692
;pi-hole.net. IN A
pi-hole.net. 185 IN A 206.189.252.21
;; Query time: 1 msec
;; WHEN: Mon Feb 18 04:11:59 GMT 2019
;; MSG SIZE rcvd: 56
dig flurry.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> flurry.com
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 31186
;flurry.com. IN A
flurry.com. 2 IN A 0.0.0.0
;; WHEN: Mon Feb 18 04:12:17 GMT 2019
;; MSG SIZE rcvd: 55
What these replies tell us:
nslookup pi-hole.net - returned the correct IP, the DNS server was the Pi-Hole at IP 94. This client is using Pi-Hole as DNS server
nslookup pi-hole.net 192.168.1.94 - this lookup forced the DNS to go to the Pi-Hole, and is the same reply as the nslookup above, confirming that the Pi-Hole is working and is the default DNS for that client.
nslookup flurry.com 192.168.1.94 returned the NULL IP as expected - this is a known ad-serving domain and was blocked by Pi-Hole.
The two digs returned the correct answers, indicating that Pi-Hole is working.
Everything we have tested so far, plus your debug log, indicates that DNS requests made to the Pi-Hole are resolving.
The problem lies in your router, by all indications.
This works
This doesn't
This is a router problem. Check all the router settings for items like rebind protection, etc. You can try listing the Pi-Hole DNS twice, etc.
In the meantime, since your Pi-Hole is working, manually assign clients to use Pi-Hole as DNS while you sort out your router.
I think the router has rebind protection turned on without an option to disable it (or something else is wrong). Anyway, I setup the pi-hole as a DHCP server and it's working now. Thanks for all the help!
