debug log:
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-04-07:11:27:28 debug log has been initialized.
[i] Core: v3.3.1 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.3.1-0-gfbee18e
[i] Web: v3.3 (How do I update Pi-hole?)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0 (How do I update Pi-hole?)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.27
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
192.168.0.102/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::c02f:57ae:35c:cb6b does not match the IP found in /etc/pihole/setupVars.conf (Use IPv6 ULA addresses for Pi-hole)
[i] Default IPv4 gateway: 192.168.0.1
[22] is in use by sshd
[53] is in use by dnsmasq
[5900] is in use by vncserver
[80] is in use by lighttpd
is in use by
[✓] aio.lp.mydas.mobi is 192.168.0.102 via localhost (127.0.0.1)
[✓] aio.lp.mydas.mobi is 192.168.0.102 via Pi-hole (192.168.0.102)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
DNSMASQ_LISTENING=local
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
HOSTRECORD=
DHCP_ACTIVE=true
DHCP_START=192.168.0.201
DHCP_END=192.168.0.251
DHCP_ROUTER=192.168.0.1
DHCP_LEASETIME=24
PIHOLE_DOMAIN=lan
DHCP_IPv6=false
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.0.102/24
IPV6_ADDRESS=
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
[✓] X-Pi-hole: A black hole for Internet advertisements.
[✓] X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 4455247 Apr 7 02:24 /etc/pihole/gravity.list
192.168.0.102 0.0.0.0
192.168.0.102 0.r.msn.com
192.168.0.102 0.start.bz
192.168.0.102 000.gaysexe.free.fr
192.168.0.102 zzsyw.com
192.168.0.102 zztxdown.com
192.168.0.102 zzz.clickbank.net
192.168.0.102 zzzrtrcm2.com
-rw-r--r-- 1 root root 633 Apr 6 23:55 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 13 Apr 7 10:24 /etc/pihole/blacklist.txt
moltkskyltyn
-rw-r--r-- 1 root root 48 Apr 7 02:24 /etc/pihole/local.list
192.168.0.102 raspberrypi
192.168.0.102 pi.hole
-rw-r--r-- 1 root root 234 Apr 7 02:24 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 0 Apr 7 00:39 /etc/pihole/whitelist.txt
-rw-r--r-- 1 root root 1546 Apr 7 02:24 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=208.67.222.222
server=208.67.220.220
domain-needed
bogus-priv
local-service
-rw-r--r-- 1 root root 483 Apr 7 02:24 /etc/dnsmasq.d/02-pihole-dhcp.conf
dhcp-authoritative
dhcp-range=192.168.0.201,192.168.0.251,24h
dhcp-option=option:router,192.168.0.1
dhcp-leasefile=/etc/pihole/dhcp.leases
domain=lan
-rw-r--r-- 1 root root 3027 Apr 7 02:24 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
$HTTP["url"] =~ "^/admin/.(.*)" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Apr 7 02:24 /etc/cron.d/pihole
58 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
31 16 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 2129 Apr 7 02:24 /var/log/lighttpd/error.log
2018-04-06 23:54:49: (log.c.217) server started
2018-04-06 23:55:51: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-06 23:55:51: (log.c.217) server started
2018-04-06 23:55:51: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 00:10:19: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 00:10:19: (log.c.217) server started
2018-04-07 00:10:19: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 00:13:41: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 00:14:23: (log.c.217) server started
2018-04-07 00:14:23: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 00:16:09: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 00:16:30: (log.c.217) server started
2018-04-07 00:16:30: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 01:00:50: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 01:01:05: (log.c.217) server started
2018-04-07 01:01:05: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 01:04:54: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 01:05:19: (log.c.217) server started
2018-04-07 01:05:19: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 01:17:34: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 01:17:49: (log.c.217) server started
2018-04-07 01:17:49: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-04-07 01:28:10: (server.c.1828) server stopped by UID = 0 PID = 1
2018-04-07 01:28:37: (log.c.217) server started
2018-04-07 01:28:37: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 52250 Apr 7 10:34 /var/log/pihole-FTL.log
[2018-04-07 00:00:02.536] Gravity list entries: 121803
[2018-04-07 00:00:02.536] No blacklist present
[2018-04-07 00:00:02.536] No wildcard blocking list present
[2018-04-07 00:00:02.537] Notice: Increasing queries struct size from 0 to 10000 (440.17 KB)
[2018-04-07 00:00:02.537] Notice: Increasing domains struct size from 0 to 1000 (460.17 KB)
[2018-04-07 00:00:02.537] Notice: Increasing clients struct size from 0 to 10 (460.33 KB)
[2018-04-07 00:00:02.537] New client: 127.0.0.1 localhost (0/10)
[2018-04-07 00:00:02.537] Notice: Increasing forwarded struct size from 0 to 4 (460.44 KB)
[2018-04-07 00:00:02.646] New forward server: 208.67.220.220 resolver2.opendns.com (0/4)
[2018-04-07 00:00:02.646] Notice: Increasing overTime struct size from 0 to 100 (464.48 KB)
[2018-04-07 00:00:02.646] Imported 22 queries from the long-term database
[2018-04-07 00:00:02.646] Reading from /var/log/pihole.log (rw-r--r--)
[2018-04-07 00:01:30.693] New forward server: 208.67.222.222 resolver1.opendns.com (1/4)
[2018-04-07 00:03:32.601] NOTICE: Received signal SIGHUP - re-reading gravity files
[2018-04-07 00:03:32.847] Gravity list entries: 121803
[2018-04-07 00:03:32.847] No blacklist present
[2018-04-07 00:03:32.847] No wildcard blocking list present
[2018-04-07 00:03:32.847] -> Total DNS queries: 33
[2018-04-07 00:03:32.847] -> Cached DNS queries: 7
[2018-04-07 00:03:32.847] -> Forwarded DNS queries: 26
[2018-04-07 00:03:32.847] -> Exactly blocked DNS queries: 0
[2018-04-07 00:03:32.847] -> Wildcard blocked DNS queries: 0
[2018-04-07 00:03:32.847] -> Unknown DNS queries: 0
[2018-04-07 00:03:32.847] -> Unique domains: 18
[2018-04-07 00:03:32.847] -> Unique clients: 1
-rw-r--r-- 1 dnsmasq root 2193929 Apr 7 11:30 /var/log/pihole.log
-----head of pihole.log------
Apr 7 00:00:02 dnsmasq[8440]: 124 127.0.0.1/46827 query[PTR] 220.220.67.208.in-addr.arpa from 127.0.0.1
Apr 7 00:00:02 dnsmasq[8440]: 124 127.0.0.1/46827 forwarded 220.220.67.208.in-addr.arpa to 208.67.220.220
Apr 7 00:00:02 dnsmasq[8440]: 124 127.0.0.1/46827 forwarded 220.220.67.208.in-addr.arpa to 208.67.222.222
Apr 7 00:00:02 dnsmasq[8440]: 124 127.0.0.1/46827 reply 208.67.220.220 is resolver2.opendns.com
Apr 7 00:00:09 dnsmasq[8440]: 125 127.0.0.1/53629 query[A] duckduckgo.com from 127.0.0.1
Apr 7 00:00:09 dnsmasq[8440]: 125 127.0.0.1/53629 forwarded duckduckgo.com to 208.67.220.220
Apr 7 00:00:09 dnsmasq[8440]: 125 127.0.0.1/53629 reply duckduckgo.com is 34.243.144.154
Apr 7 00:00:09 dnsmasq[8440]: 125 127.0.0.1/53629 reply duckduckgo.com is 34.241.201.179
Apr 7 00:00:09 dnsmasq[8440]: 125 127.0.0.1/53629 reply duckduckgo.com is 34.243.160.29
Apr 7 00:00:10 dnsmasq[8440]: 126 127.0.0.1/50151 query[A] translate.googleapis.com from 127.0.0.1
Apr 7 00:00:10 dnsmasq[8440]: 126 127.0.0.1/50151 forwarded translate.googleapis.com to 208.67.220.220
Apr 7 00:00:10 dnsmasq[8440]: 126 127.0.0.1/50151 reply translate.googleapis.com is 216.58.209.138
Apr 7 00:00:16 dnsmasq[8440]: 127 127.0.0.1/39859 query[A] uyxympttvadk.sokrates.bosj.local from 127.0.0.1
Apr 7 00:00:16 dnsmasq[8440]: 127 127.0.0.1/39859 forwarded uyxympttvadk.sokrates.bosj.local to 208.67.220.220
Apr 7 00:00:16 dnsmasq[8440]: 128 127.0.0.1/41913 query[A] brvvldpukugivfl.sokrates.bosj.local from 127.0.0.1
Apr 7 00:00:16 dnsmasq[8440]: 128 127.0.0.1/41913 forwarded brvvldpukugivfl.sokrates.bosj.local to 208.67.220.220
Apr 7 00:00:16 dnsmasq[8440]: 129 127.0.0.1/38037 query[A] spzyygndb.sokrates.bosj.local from 127.0.0.1
Apr 7 00:00:16 dnsmasq[8440]: 129 127.0.0.1/38037 forwarded spzyygndb.sokrates.bosj.local to 208.67.220.220
Apr 7 00:00:16 dnsmasq[8440]: 127 127.0.0.1/39859 reply uyxympttvadk.sokrates.bosj.local is NXDOMAIN
Apr 7 00:00:16 dnsmasq[8440]: 130 127.0.0.1/55146 query[A] uyxympttvadk from 127.0.0.1
