I concatenated every BlockList I could find
Try asking at your Pihole IP /admin/queryads.php and see which list it shows in.
You could also WhiteList Google.
Find Ad Domain In Lists
Search exact match. I just did mine.
Exact match for google.com found in:
list.0.raw.githubusercontent.com.domains
Hey could some one check this list eg wget https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
Not sure if it is a bug?
I will add this list soon and if any one has a bitcoin mining site that is updated I will add it to my lists.
https://raw.githubusercontent.com/hoshsadiq/adblock-nocoin-list/master/hosts.txt
Completely useless. For example,
ziggo.nl?????????? do you have kpn isp?
A lot of google urls, so maps is not or bad working. maps.google.nl, maps.google.com, accounts.google.com
twitter and facebook also speedtest.net
vodafone.
Completely useless lists witch this sort of blocking.
Also pi-hole can't run it good. On a amd A10 cpu. Pihole gets stuck a lot when useing this lists.
appleid.apple.com needs to be whitelisted, thanks!
Here is my whitelist - DNSlock-PiHole-whitelist/whitelist.list at master · raghavdua1995/DNSlock-PiHole-whitelist · GitHub.
This list does not contain facebook/twitter/Instagram/Pinterest/Reddit domains because I have blocked them deliberately.
Requesting-
Unblock:
'letsencrypt.org' is on the list. Could we have it unblocked?
'www.googleapis.com' youtube mobile app not working on iphone
Block:
ads.viber.com
Updated lists including https://github.com/ZeroDot1/CoinBlockerLists#donations
@anno @ajp2k17 @raghavdua1995 @duceduc
Maybe I missed it (or I am just dumb, both are possible =P) but is the https://smokingwheels.github.io/Pi-hole/allhosts the only list we need to get your blocklist SmokingWheels? Add that link to the list, save, save and update and the pi hole will do the rest?
is this being updated :blush:
Check out the github link(s). I would say anything in the past couple months means its being updated.
I have done a lot of the same thing. A lot of the lists have errors in them. When my Pi-hols starts I get lots of messages like:
May 29 23:02:42 dnsmasq[435]: bad name at /etc/pihole/gravity.list line 1954488
And if I look at that line, sure enough there will be something malformed in it.
My first thought was to grep out all of the "bad name" errors and write a little script to just remove those lines. Only I can not find any of the lines with those errors in the log.
Can someone tell me where these are stored on the pi?
Also, a suggestion for the developers. Have a command line switch to have the Pi-hole make a new master list omitting anything it does not like. It preens over the list anyway, why not have an option to report what it finds and clean it up. Keep the original under a new name.
I also suspect that I have a bunch of dupes in my master file, but I figure I will attack them after I get the malformed stuff fixed. Is it just my perception or does the logging of the malformed lines make the Pi-hole boot up much slower?
Anyway, thanks for a great piece of software. Please consider my idea for having a switch to preen the file over. It seems silly to have a seperate tool to do something the Pi-hole already has the core of.
/etc/pihole/
/etc/pihole/gravity.list is the file youre looking for specifically
also any duplicates are filtered out as a part of the gravity porocess
Thanks for the reply, but I was not clear about the question. I want to know where the errors are logged. The line in the error tells you where the file with the error is.
I looked in /var/log but nothing with the "bad name" string was found. Where are those error logged?
By default, dnsmasq logs daemon.debug. In /etc/syslog.conf look for debug to
see which log file and where located.
Try sudo systemctl status --no-pager --full -u dnsmasq.service or if you're running FTL, sudo systemctl status --no-pager --full -u pihole-FTL.service
As for the Feature Request, feel free to start a new post in the Feature Request category so that it's voted on by the community and will help us with priority.
Wow, thank you again for the wicked fast reply. I do not have a syslog,conf. Or I could not find it:
root@raspberrypi:/etc# find / -name syslog.conf
/usr/share/doc/sudo/examples/syslog.conf
I am running...
root@raspberrypi:/etc# more os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Thank you again!!
Hi Dan,
Truthfully I am not sure which one I am running. One of the gotchas with the "one line" installer. Whatever you get by default. However, neither of the commands works, they both object to the -u switch.
root@raspberrypi:/etc# systemctl status --no-pager --full -u dnsmasq.service
systemctl: invalid option -- 'u'
root@raspberrypi:/etc# systemctl status --no-pager --full -u pihole-FTL.service
Try with omitting the -u from the line so it reads exactly the same minus that flag.
I had tried that on my own, no joy.
root@raspberrypi:/etc# root@raspberrypi:/etc# systemctl status --no-pager --full pihole-FTL.service
bash: root@raspberrypi:/etc#: No such file or directory
root@raspberrypi:/etc# root@raspberrypi:/etc# systemctl status --no-pager --full dnsmasq.service
Thank you again for the amazingly quick reply.
