Doesn't log for one of computers witch is mine "Linux Mint 18.3"
It logs my wife comp , orangepizero and localhost. There is no my comp
link in client list
On the client that isn't showing in the Pi-Hole logs, please run the following command (substitute nslookup for dig if your client doesn't support dig):
dig pi.hole
Then on the Pi-Hole host terminal, run the following command substituting the IP address of the missing client where the "zzz" appears:
dig pi hole
; <<>> DiG 9.10.3-P4-Ubuntu <<>> pi.hole
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 60356
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;pi.hole. IN A
;; AUTHORITY SECTION:
. 3600 IN SOA a.root-servers.net. nstld.verisign-grs.com. 2018120301 1800 900 604800 86400
;; Query time: 34 msec
;; SERVER: 127.0.2.1#53(127.0.2.1)
;; WHEN: Mon Dec 03 17:16:55 CET 2018
;; MSG SIZE rcvd: 111
Second command doesn't show, but I open nano an here is content
Dec 3 15:17:10 dnsmasq[1161]: started, version pi-hole-2.79 cachesize 10000
Dec 3 15:17:10 dnsmasq[1161]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ip$
Dec 3 15:17:10 dnsmasq[1161]: warning: failed to change owner of /var/log/pihole.log: Operation not permitted
Dec 3 15:17:10 dnsmasq[1161]: using nameserver 1.0.0.1#53
Dec 3 15:17:10 dnsmasq[1161]: using nameserver 1.1.1.1#53
Dec 3 15:17:10 dnsmasq[1161]: read /etc/hosts - 6 addresses
Dec 3 15:17:10 dnsmasq[1161]: read /etc/pihole/local.list - 2 addresses
Dec 3 15:17:10 dnsmasq[1161]: failed to load names from /etc/pihole/black.list: No such file or directory
Dec 3 15:17:12 dnsmasq[1161]: read /etc/pihole/gravity.list - 275338 addresses
Dec 3 16:14:57 dnsmasq[1161]: 1 127.0.0.1/47822 query[A] view.atdmt.com.35626.9169.302br.net from 127.0.0.1
Dec 3 16:14:57 dnsmasq[1161]: 1 127.0.0.1/47822 /etc/pihole/gravity.list view.atdmt.com.35626.9169.302br.net is 0.0.0.0
Dec 3 16:14:57 dnsmasq[1161]: 2 192.168.5.113/37014 query[A] view.atdmt.com.35626.9169.302br.net from 192.168.5.113
Dec 3 16:14:57 dnsmasq[1161]: 2 192.168.5.113/37014 /etc/pihole/gravity.list view.atdmt.com.35626.9169.302br.net is 0.0.0.0
Since the client can't lookup the pi.hole name, the client is apparently not using Pi-Hole as its DNS. Carefully check the DNS settings on that client.
I found that lighttpd stops working. After restarting as in this tread
content of pi hole log is different.
Dec 3 16:26:51 dnsmasq[1161]: 3 192.168.5.50/51153 query[A] client.dropbox.com from 192.168.5.50
Dec 3 16:26:51 dnsmasq[1161]: 3 192.168.5.50/51153 forwarded client.dropbox.com to 1.0.0.1
Dec 3 16:26:51 dnsmasq[1161]: 3 192.168.5.50/51153 forwarded client.dropbox.com to 1.1.1.1
Dec 3 16:26:51 dnsmasq[1161]: 3 192.168.5.50/51153 reply client.dropbox.com is <CNAME>
Dec 3 16:26:51 dnsmasq[1161]: 3 192.168.5.50/51153 reply client.dropbox-dns.com is 162.125.69.3
Dec 3 16:26:53 dnsmasq[1161]: 4 192.168.5.50/52332 query[A] api.dropboxapi.com from 192.168.5.50
Dec 3 16:26:53 dnsmasq[1161]: 4 192.168.5.50/52332 forwarded api.dropboxapi.com to 1.0.0.1
Dec 3 16:26:53 dnsmasq[1161]: 4 192.168.5.50/52332 reply api.dropboxapi.com is <CNAME>
Dec 3 16:26:53 dnsmasq[1161]: 4 192.168.5.50/52332 reply api.dropbox-dns.com is 162.125.69.7
Dec 3 16:27:57 dnsmasq[1161]: 5 192.168.5.50/54713 query[A] d.dropbox.com from 192.168.5.50
Dec 3 16:27:57 dnsmasq[1161]: 5 192.168.5.50/54713 forwarded d.dropbox.com to 1.0.0.1
Dec 3 16:27:57 dnsmasq[1161]: 5 192.168.5.50/54713 reply d.dropbox.com is <CNAME>
Dec 3 16:27:57 dnsmasq[1161]: 5 192.168.5.50/54713 reply d.v.dropbox.com is <CNAME>
Dec 3 16:27:57 dnsmasq[1161]: 5 192.168.5.50/54713 reply d-sjc.v.dropbox.com is 162.125.32.135
Dec 3 16:38:45 dnsmasq[1161]: 6 192.168.5.50/51794 query[A] client.dropbox.com from 192.168.5.50
Dec 3 16:38:45 dnsmasq[1161]: 6 192.168.5.50/51794 forwarded client.dropbox.com to 1.0.0.1
Dec 3 16:38:45 dnsmasq[1161]: 6 192.168.5.50/51794 forwarded client.dropbox.com to 1.1.1.1
Dec 3 16:38:45 dnsmasq[1161]: 6 192.168.5.50/51794 reply client.dropbox.com is <CNAME>
Dec 3 16:38:45 dnsmasq[1161]: 6 192.168.5.50/51794 reply client.dropbox-dns.com is 162.125.69.3
Dec 3 16:38:45 dnsmasq[1161]: 7 192.168.5.50/55901 query[A] block-edge-anycast.dropbox.com from 192.168.5.50
Dec 3 16:38:45 dnsmasq[1161]: 7 192.168.5.50/55901 forwarded block-edge-anycast.dropbox.com to 1.0.0.1
Dec 3 16:38:45 dnsmasq[1161]: 8 192.168.5.50/51519 query[A] dl-debug.dropbox.com from 192.168.5.50
The client can't resolve "pi.hole" and this address is mapped by the Pi-Hole working as DNS server. If you test this from another connected client, do you get the IP address of the Pi-Hole?
The Pi-Hole appears to be using the 113 address as well. From your debug log:
[ā] IPv4 address(es) bound to the eth0 interface:
192.168.5.113/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
192.168.5.55/24 matches the IP found in /etc/pihole/setupVars.con
What physical or virtual platform is hosting the Pi-Hole software?
The Pi-Hole should be listening on the assigned IP address of the ethernet port (which appears to be the active connection).
Ensure that the IP address assigned to the Zero is static or reserved at the router. Then run pihole -r and select reconfigure; then select the assigned IP address when asked.
I know that, now pi.hole have static address and in router is reserved for pi.hole.
It was always the case, static and reserved.
Now is this
192.169.5.55/24 does not match the IP found in /etc/pihole/setupVars.conf (Use IPv6 ULA addresses for Pi-hole)
192.168.5.55/24 matches the IP found in /etc/pihole/setupVars.conf
On the terminal on the Pi, run this command to live tail the pihole.log, and leave the window open:
tail -f /var/log/pihole.log
Then, on the missing client, open a browser and open www.cnn.com. This should result in a burst of activity in the pihole log from that client, starting with some cnn domains.
Dec 3 20:53:49 dnsmasq[1216]: 2341 192.168.5.50/53658 reply block-debug.x.dropbox.com is 52.6.78.241
Dec 3 20:53:49 dnsmasq[1216]: 2341 192.168.5.50/53658 reply block-debug.x.dropbox.com is 52.7.182.237
Dec 3 20:53:49 dnsmasq[1216]: 2341 192.168.5.50/53658 reply block-debug.x.dropbox.com is 52.21.155.87
Dec 3 20:53:49 dnsmasq[1216]: 2341 192.168.5.50/53658 reply block-debug.x.dropbox.com is 52.73.220.123
Dec 3 21:09:10 dnsmasq[1216]: 2342 192.168.5.50/53300 query[A] d.dropbox.com from 192.168.5.50
Dec 3 21:09:10 dnsmasq[1216]: 2342 192.168.5.50/53300 forwarded d.dropbox.com to 1.0.0.1
Dec 3 21:09:10 dnsmasq[1216]: 2342 192.168.5.50/53300 forwarded d.dropbox.com to 1.1.1.1
Dec 3 21:09:10 dnsmasq[1216]: 2342 192.168.5.50/53300 reply d.dropbox.com is
Dec 3 21:09:10 dnsmasq[1216]: 2342 192.168.5.50/53300 reply d.v.dropbox.com is
Dec 3 21:09:10 dnsmasq[1216]: 2342 192.168.5.50/53300 reply d-sjc.v.dropbox.com is 162.125.34.137
Dec 3 21:21:43 dnsmasq[1216]: 2343 192.168.5.50/55052 query[A] bolt.dropbox.com from 192.168.5.50
Dec 3 21:21:43 dnsmasq[1216]: 2343 192.168.5.50/55052 forwarded bolt.dropbox.com to 1.0.0.1
Dec 3 21:21:43 dnsmasq[1216]: 2343 192.168.5.50/55052 forwarded bolt.dropbox.com to 1.1.1.1
Dec 3 21:21:43 dnsmasq[1216]: 2343 192.168.5.50/55052 reply bolt.dropbox.com is
Dec 3 21:21:43 dnsmasq[1216]: 2343 192.168.5.50/55052 reply bolt.v.dropbox.com is 162.125.18.133
