Hi, thanks for being part of this great project. I would need help as my friend google can not help me anymore
Access to web interface
after a power outage the web interface is not accessible anymore. lighttpd refuses to start, blocking and dns over http works
k999znraw2
what I did:
pihole -r didn't help
~$ systemctl status lighttpd.service
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2018-11-04 19:44:12 WIB; 18min ago
Process: 4158 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Process: 4148 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 4158 (code=exited, status=255)
Nov 04 19:44:12 orangepizero systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 04 19:44:12 orangepizero systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Nov 04 19:44:12 orangepizero systemd[1]: Stopped Lighttpd Daemon.
Nov 04 19:44:12 orangepizero systemd[1]: lighttpd.service: Start request repeated too quickly.
Nov 04 19:44:12 orangepizero systemd[1]: Failed to start Lighttpd Daemon.
Nov 04 19:44:12 orangepizero systemd[1]: lighttpd.service: Unit entered failed state.
thanks in advance cheers
RamSet
November 4, 2018, 2:57pm
4
Can you paste the contents of /etc/lighttpd/lighttpd.conf ?
@RamSet , thanks for helping
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
# default listening port for IPv6 falls back to the IPv4 port
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
# Prevent Lighttpd from enabling Let's Encrypt SSL for every blocked domain
#include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\"\n' 2>/dev/null"
# If the URL starts with /admin, it is the Web interface
$HTTP["url"] =~ "^/admin/" {
# Create a response header for debugging using curl -I
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
# Allow Block Page access to local fonts
# Block . files from being served, such as .git, .github, .gitignore
url.access-deny = ("")
Mcat12
November 5, 2018, 3:52pm
9
What is the output of this command?
journalctl -u lighttpd
dieterg
November 5, 2018, 3:55pm
10
orangepione@orangepizero:~$ journalctl -u lighttpd
-- Logs begin at Mon 2018-11-05 13:17:01 WIB, end at Mon 2018-11-05 22:54:05 WIB
Nov 05 13:17:13 orangepizero systemd[1]: Starting Lighttpd Daemon...
Nov 05 13:17:14 orangepizero systemd[1]: Started Lighttpd Daemon.
Nov 05 13:17:14 orangepizero lighttpd[957]: 2018-11-05 13:17:14: (log.c.171) ope
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Main process exited,
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Unit entered failed s
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Failed with result 'e
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Service hold-off time
Nov 05 13:17:14 orangepizero systemd[1]: Stopped Lighttpd Daemon.
Nov 05 13:17:14 orangepizero systemd[1]: Starting Lighttpd Daemon...
Nov 05 13:17:15 orangepizero lighttpd[984]: 2018-11-05 13:17:14: (log.c.171) ope
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Main process exited,
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Unit entered failed s
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Failed with result 'e
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Service hold-off time
Nov 05 13:17:15 orangepizero systemd[1]: Stopped Lighttpd Daemon.
Nov 05 13:17:15 orangepizero systemd[1]: Starting Lighttpd Daemon...
Nov 05 13:17:15 orangepizero systemd[1]: Started Lighttpd Daemon.
Nov 05 13:17:15 orangepizero lighttpd[1016]: 2018-11-05 13:17:15: (log.c.171) op
lines 1-23...skipping...
Mcat12
November 5, 2018, 3:57pm
11
The output is cut off, try journalctl -u lighttpd -l
dieterg
November 5, 2018, 3:59pm
12
orangepione@orangepizero:~$ journalctl -u lighttpd -l
-- Logs begin at Mon 2018-11-05 13:17:01 WIB, end at Mon 2018-11-05 22:55:01 WIB. --
Nov 05 13:17:14 orangepizero lighttpd[957]: 2018-11-05 13:17:14: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Unit entered failed state.
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 05 13:17:14 orangepizero systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Nov 05 13:17:15 orangepizero lighttpd[984]: 2018-11-05 13:17:14: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Unit entered failed state.
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 05 13:17:15 orangepizero systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Nov 05 13:17:15 orangepizero lighttpd[1016]: 2018-11-05 13:17:15: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Nov 05 13:17:16 orangepizero systemd[1]: Started Lighttpd Daemon.
Nov 05 13:17:16 orangepizero lighttpd[1037]: 2018-11-05 13:17:16: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Nov 05 13:17:16 orangepizero systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Nov 05 13:17:16 orangepizero systemd[1]: lighttpd.service: Unit entered failed state.
Nov 05 13:17:16 orangepizero systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 05 13:17:16 orangepizero systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Nov 05 13:17:16 orangepizero systemd[1]: Stopped Lighttpd Daemon.
Nov 05 13:17:16 orangepizero systemd[1]: Starting Lighttpd Daemon...
Nov 05 13:17:17 orangepizero lighttpd[1058]: 2018-11-05 13:17:16: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Nov 05 13:17:17 orangepizero systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Nov 05 13:17:17 orangepizero systemd[1]: lighttpd.service: Unit entered failed state.
Nov 05 13:17:17 orangepizero systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Mcat12
November 5, 2018, 4:00pm
13
Check the permissions on this file
dieterg
November 5, 2018, 4:02pm
14
-rw-r--r-- 1 root root 122 Nov 4 06:25 /var/log/lighttpd/error.log
Mcat12
November 5, 2018, 4:03pm
15
Run sudo chown www-data:www-data /var/log/lighttpd/error.log
dieterg
November 5, 2018, 4:05pm
16
orangepione@orangepizero:~$ sudo chown www-data:www-data /var/log/lighttpd/error.log
orangepione@orangepizero:~$ sudo ls -l /var/log/lighttpd/error.log
-rw-r--r-- 1 www-data www-data 122 Nov 4 06:25 /var/log/lighttpd/error.log
Mcat12
17
Does restarting lighttpd work now?
dieterg
November 5, 2018, 4:08pm
18
orangepione@orangepizero:~$ sudo service lighthttpd restart
Failed to restart lighthttpd.service: Unit lighthttpd.service not found.
dieterg
November 5, 2018, 4:46pm
19
the log file is may strange
sudo nano /var/log/lighttpd/error.log
2018-11-02 13:17:11: (log.c.217) server started
2018-11-04 06:25:04: (server.c.1534) logfiles cycled UID = 0 PID = 1772
sudo service lighttpd restart
Be very careful on spelling, it counts with computers.
dieterg
November 5, 2018, 5:02pm
21
Thanks Dan
orangepione@orangepizero:~$ sudo service lighttpd restart
no output and
$ sudo systemctl status lighttpd.service
Active: failed (Result: exit-code) since Tue 2018-11-06 00:03:38 WIB; 14s ago
Process: 4833 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Process: 4823 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 4833 (code=exited, status=255)
Nov 06 00:03:38 orangepizero systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 06 00:03:38 orangepizero systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Nov 06 00:03:38 orangepizero systemd[1]: Stopped Lighttpd Daemon.
Nov 06 00:03:38 orangepizero systemd[1]: lighttpd.service: Start request repeated too quickly.
Nov 06 00:03:38 orangepizero systemd[1]: Failed to start Lighttpd Daemon.
Nov 06 00:03:38 orangepizero systemd[1]: lighttpd.service: Unit entered failed state.
Mcat12
November 5, 2018, 5:04pm
22
Check journalctl -u lighttpd -l again
dieterg
November 5, 2018, 5:05pm
23
-- Logs begin at Mon 2018-11-05 13:17:01 WIB, end at Tue 2018-11-06 00:05:01 WIB. --
lines 1-39
Mcat12
November 5, 2018, 5:08pm
24
Nothing new has been written to the log. Check the permissions on the error file again, and its contents.
dieterg
November 5, 2018, 5:10pm
25
