Pi-hole no web interface, lighttpd.service failed to start
I accidentally bumped a power strip and restarted my Pihole. Now it no longer works. I tried a pihole -r it repairs fine, and pihole-d shows the expected x-header not available, and my web interface cannot be accessed. It was always working fine previously. I suspect the lighttpd service is corrupted. I tried the steps outlined by the user here, and it still doesn't work
pi@raspberrypi:~ $ sudo systemctl status lighttpd
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset:
Active: failed (Result: exit-code) since Mon 2020-04-13 16:36:54 BST; 3min 48
Process: 11174 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.c
Process: 11181 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
Main PID: 11181 (code=exited, status=255/EXCEPTION)
Apr 13 16:36:54 raspberrypi systemd[1]: lighttpd.service: Service RestartSec=100
Apr 13 16:36:54 raspberrypi systemd[1]: lighttpd.service: Scheduled restart job,
Apr 13 16:36:54 raspberrypi systemd[1]: Stopped Lighttpd Daemon.
Apr 13 16:36:54 raspberrypi systemd[1]: lighttpd.service: Start request repeated
Apr 13 16:36:54 raspberrypi systemd[1]: lighttpd.service: Failed with result 'ex
Apr 13 16:36:54 raspberrypi systemd[1]: Failed to start Lighttpd Daemon.
HTTP/1.1 200 OK
Date: Mon, 13 Apr 2020 15:42:13 GMT
Server: Apache/2.4.38 (Raspbian)
Last-Modified: Sun, 10 Nov 2019 20:21:55 GMT
ETag: "29cd-59703c42d44de"
Accept-Ranges: bytes
Content-Length: 10701
Vary: Accept-Encoding
Content-Type: text/html
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Last-Modified: Mon, 13 Apr 2020 00:28:59 GMT
ETag: "232b-5a3212b4f5474"
Content-Length: 9003
You have an instance of Apache2 that has started, and it is preventing lighttpd from binding to port 80.
HTTP/1.1 200 OK
ETag: "1748631526"
Date: Mon, 13 Apr 2020 16:42:48 GMT
Server: lighttpd/1.4.53
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
I stopped apache and restarted lighttpd (which now started fine). Still getting a trashed login page though
Please post a new debug token and a screen snap of what you see on the login page (after you clear your browser cache and reload the page).
