Can I make my Pihole have 2 valid IP addresses for DNS?
My router allows setting custom DNS addresses for DHCP, but it requires 2 different, valid addresses for primary and secondary addresses. And apparently, whichever address isn't my Pi takes precedence 100% of the time. I can't leave the secondary address blank, make it invalid, local, or a null address. My router has to be able to connect to it.
So is there a way to give my pi/pihole 2 addresses that my router can connect to, so I can set it as my primary AND secondary DNS?
Debug log here: https://tricorder.pi-hole.net/KmmMhNm0/https://tricorder.pi-hole.net/KmmMhNm0/
If you can't use local IP's for DNS on your router, this may be due to DNS rebind protection on the router:
If you cannot disable this on the router, then your best approach is to disable DHCP on the router, and use the Pi-hole DHCP server.
What make and model router are you using?
I am using a Spectrum router, SAX2V1S. I don't believe there is an option to disable either rebind protection or DHCP.
You still have options.
Leave DHCP enabled on the router, and restrict the IP range to a single IP. Make that IP the static IP of your Pi.
Then, enable DHCP on the Pi-hole, and make the IP range such that it doesn't overlap the IP of the Pi-hole.
Example:
Router DHCP set to 192.168.1.174. Reserve this IP for the Pi (use the Pi wlan0 MAC address).
Pihole DHCP set to range 192.168.1.20 to 192.168.1.120.
Actually, I think I just found that this model actually CAN disable rebind protection, it just unhelpfully labels it as "network security" with no additional info. Thanks for your help, hopefully pihole will actually work on my devices now.
