Asus AC68
SOrry, my bad....again!
pi@PiHole:~ $ grep -v '^#|^$' /etc/dhcpcd.conf
hostname
clientid
persistent
option rapid_commit
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
option ntp_servers
option interface_mtu
require dhcp_server_identifier
slaac private
interface eth0
static ip_address=10.1.1.3/24
static routers=10.1.1.1
interface eth0
static ip_address=10.1.1.240/24
pi@PiHole:~ $
You have two instances now of the same eth0 interface thats not connected.
Somehow the changes you made not being stored ? EDIT: sorry it was stored but the two instances is creating problems.
Try edit again:
sudo nano /etc/dhcpcd.conf
Delete everything under the line with " #fallback static_eth0",
and paste below at the bottom:
interface wlan0
Save it and check if stored now with:
cat /etc/dhcpcd.conf
Reboot and check out the new IP:
ip a
Just to ensure I am following the instructions correctly, I still have not switched off DHCP on the router...as I thought it came after this step..????....
AARGH!.....now I cannot VNC into the Rpi as the IP has changed from 240 to 3 and I forgot to adjust the VNC .....so I have to get out the screen and keyboard and set it all up again.....sorry....I may be some time....probably tomorrow as it is getting late here.
First get Pi-hole working and configured properly before switching DHCP service.
Dont need VNC if the SSH daemon on Pi is enebled:
https://www.raspberrypi.org/documentation/remote-access/ssh/
SSH not enabled as I generally use VNC :frowning:
I dont use/install desktops on any of my servers.
All is done through SSH and Bash.
If I need a graphical application that needs desktop support, I export my display on server to network and use X to run applications on from a remote PC/laptop/etc:
That is certainly the ideal!....but for a novice like me....who does sporadic projects and forgets easily...VNC seems to work. I would certainly follow your suggested route if I were more experienced.
You can have both VNC and SSHd active ... after you get in again :wink:
Given this experience, I think it would be a good idea!
Good night ....thanks again for your patience and your help!
Sorry about that!...I am back!
pi@PiHole:~ $ ip a
    inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether b8:27:eb:dd:0c:bf brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:88:59:ea brd ff:ff:ff:ff:ff:ff
    inet 10.1.1.3/24 brd 10.1.1.255 scope global wlan0
    inet6 fe80::c275:c91:b0e:89c9/64 scope link
pi@PiHole:~ $
Looks good.
Run below ones on Pi to enable the sshd daemon and start sshd for next time you lose VNC:
sudo systemctl enable ssh
sudo systemctl start ssh
From the pj-selgbuild client, you should now be able to ssh into Pi with:
ssh -l pi 10.1.1.3
Next configure Pi-hole to use the new 10.1.1.3 address by running reconfigure:
echo 'nameserver 8.8.8.8' | sudo tee /etc/resolv.conf
pihole -r
Reboot Pi to be sure and test from Pi and a client:
nslookup pi.hole 10.1.1.3
If that all works, you can try switching DHCP service from router to Pi-hole:
After the switch, reboot the pj-selgbuild client and run below ones on it to see if it picked up the new DHCP settings including the Pi DNS IP:
ip a
cat /etc/resolv.conf
nslookup pi.hole
If that looks good, reboot your other client devices to renew DHCP lease so they too start using the new DHCP service + ad blocking through Pi-hole's DNS.
??? Where did the 240 come from now????
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u3
[i] Repair option selected
[βœ“] Disk space check
[βœ“] Update local cache of available packages
[βœ“] Checking apt-get for upgraded packages... up to date!
[βœ“] Checking for apt-utils
[βœ“] Checking for dialog
[βœ“] Checking for debconf
[βœ“] Checking for dhcpcd5
[βœ“] Checking for git
[βœ“] Checking for iproute2
[βœ“] Checking for whiptail
[i] Performing reconfiguration, skipping download of local repos
[βœ“] Resetting repository within /etc/.pihole...
[βœ“] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[βœ“] Checking for cron
[βœ“] Checking for curl
[βœ“] Checking for dnsutils
[βœ“] Checking for iputils-ping
[βœ“] Checking for lsof
[βœ“] Checking for netcat
[βœ“] Checking for psmisc
[βœ“] Checking for sudo
[βœ“] Checking for unzip
[βœ“] Checking for wget
[βœ“] Checking for idn2
[βœ“] Checking for sqlite3
[βœ“] Checking for libcap2-bin
[βœ“] Checking for dns-root-data
[βœ“] Checking for resolvconf
[βœ“] Checking for lighttpd
[βœ“] Checking for php7.0-common
[βœ“] Checking for php7.0-cgi
[βœ“] Checking for php7.0-sqlite3
[βœ“] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[βœ“] Detected ARM-hf architecture (armv7+)
[i] Latest FTL Binary already installed (v4.2.3). Confirming Checksum...
[i] Checksum correct. No need to download!
[βœ“] Checking for user 'pihole'
[βœ“] Installing scripts from /etc/.pihole
[βœ“] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[βœ“] Creating directory for blocking page, and copying files
[βœ—] Backing up index.lighttpd.html
[βœ“] Installing sudoer file
[βœ“] Installing latest Cron script
[βœ“] Installing latest logrotate script
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[βœ“] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[βœ“] Restarting lighttpd service...
[i] Restarting services...
[βœ“] Enabling pihole-FTL service to start on reboot...
[βœ“] Restarting pihole-FTL service...
[βœ“] Deleting existing list cache
[βœ“] Pulling blocklist source list into range
[i] Target: raw.githubusercontent.com (hosts)
[βœ“] Status: Retrieval successful
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[βœ“] Consolidating blocklists
[βœ“] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 134824
[βœ“] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 112381
[i] Number of whitelisted domains: 0
[i] Number of blacklisted domains: 2
[i] Number of regex filters: 0
[βœ“] Parsing domains into hosts format
[βœ“] Cleaning up stray matter
[βœ“] Force-reloading DNS service
[βœ“] DNS service is running
[βœ“] Pi-hole blocking is Enabled
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v4.2.2
Current AdminLTE version is v4.2
Current FTL version is v4.2.3
pi@PiHole:~ $ nslookup pi.hole 10.1.1.3
Server: 10.1.1.3
Address: 10.1.1.3#53
Address: 10.1.1.240
pi@PiHole:~ $
Ooops! did not do the reboot! :frowning:
Hmmm! even after the reboot 240 still comes up? what am I doing wrong?
Server: 10.1.1.3
Address: 10.1.1.240
pi@PiHole:~ $
When you did run reconfigure pihole -r, did you select the correct interface wlan0 ?
And further on, were you not asked to use your current network settings ?
What did you reply here (yes/no) and what IP address was displayed here ?
Can you post outcome for below ones again pls ?
ip a
grep -v '^#\|^$' /etc/dhcpcd.conf
grep 'IPV[4,6]_ADDRESS\|PIHOLE_INTERFACE' /etc/pihole/setupVars.conf
sudo grep -v '^#\|^$' -R /etc/dnsmasq.*
It might be that your desktop runs some kind of network manager that messes things up.
Ohw if some network manager is messing, below one might reveal:
sudo grep 10.1.1.240 -R /etc/
Ooops! I just realised the problem....I ran this late last night....and was distracted by somebody at the crucial moment and so hit repair instead of reconfigure....my bad! Sorry! Back to square 1 and I will start again!
Yeah I noticed later :smiley:
But you could check below ones anyway to search for rouge network managers:
sudo grep 10.1.1.240 -R ~
OK will do.....but I seem to have screwed something up....
pi@PiHole:~ $
