After update Pi-hole gone and Ubuntu damaged
Today an update was available and updated.
Should not have done that, after years of using Pi-hole, it has been removed.
Pi-hole did not function anymore and Ubuntu was not able to update any more.
Reinstalling was not possible there the update had damaged Ubuntu in such a way, there was no internet connection any more.
I am running a Zimaboard with Ubuntu 20.1
Luckily domoticz and deConz are still alive.
The end of a long time using Pi-hole. I think almost of the start of the project.
I am guessing you only lost 127.0.0.1 connectivity via /etc/resolv.conf so if you edit that to 1.1.1.1 or 9.9.9.9 or 8.8.8.8 you will be able to APT again :wink:
And then you can try fixing Pi-Hole v6 too :+1:
I think you do not understanding the issue.
Pi-hole has damaged Ubuntu, I can not re-install Pi-hole.
It has broken Ubuntu, that is really special, how it has done it.
I do not even want to know.
The server has more programs to run, not only Pi-hole.
First action is to repair Ubuntu, than we can have a look to find Ad blocking software which works.
Until now, Pi-hole was a good piece of software. But not anymore.
It is now past history.
I think you do not understand my reply :slight_smile:
But let's start here :
How do you know that your Ubuntu has been damaged ?!
What is not working anymore exactly ?
You wrote :
So you have network connectivity or not ?!
Can you :
  • ping 8.8.8.8
  • ping ubuntu.com
  • Succesfully run 'apt update' for example ?!
I can run apt update or other commands.
However, nothing will happen, failure connecting with the world.
That is the reason I can not reinstall Pi-hole.
The connection with the outside world is gone.
Tomorrow I will update Pi-hole at the backup server and see what happens.
But first i have to take care, that my homeserver works as it should.
I have been able to get things running again.
Cleaning and rebooting the server solved the issues.
After reinstalling Pi-hole, no web interface.
I found out that lighttpd was still running. Stopped lighttpd and disabled it)
Now I was able the access the web interface.
However, I have a larger conflict, Pi-Hole is conflicting with deConz.
deConz was using that web address and now Pi-Hole is doing the same.
In the past, Pi-hole was running on 8093 and no 8080.
I have stopped Pi-hole again, there deConz is more important.
Now I have to figure out to change the Pi-Hole Web interface adddress. (New Address)
I thing I got the same issue. After updating with pihole -up the webinterface shows "403 forbidden" and the DNS resolution doesn't work anymore. Can anybody give some hints to analyze or fix.
Issue & Setup
So, i noticed that there are a lot of posts more-or-less about this issue, but this is the one that came up for me in a web search, so this is the one i'm going to reply to; my apologies if there is a more appropriate place.
I hope to outline a [temporary?] solution here.
I have encountered a similar issue. After running
$ pihole-up
about an hour ago, unbound DNS resolution broke for me, as did the pi-hole web interface. Details about my setup:
My pi-hole is set up to do its own DNS resolution via unbound, as outlined at:
https://docs.pi-hole.net/guides/dns/unbound/
I typically do all maintenance via ssh, so, to be fair, it's possible that the web interface has been broken for a while without my noticing. In any case.
It looks like maybe some config files got totally clobbered in the upgrade process? My solution:
[Temporary?] Solution
First, i logged into my router and changed DNS resolution back to allowing my ISP to do it, as a temporary measure; i'm not sure whether this is necessary, but it made getting online /at all/ much more convenient.
At this point, DNS resolution on the pi-hole itself seemed to come back, as the commands
$ dig fail01.dnssec.works @127.0.0.1 -p 5335
and
$ dig dnssec.works @127.0.0.1 -p 5335
began returning the expected results, although it's possible that some reboots of the pi-hole that ended up being necessary were the cause of this, i'm not certain.
Second, i took the advice here and killed lighttpd, via
$ sudo service lighttpd stop
I have not yet disabled lighttpd entirely [edit: i have done now, as this appears to be a normal part of the v6 update process; see the "Edit: Additional Info" section below]; i will mess around with whether this is necessary in the coming days, but for now i just wanted to get things working again over the weekend.
Once lighttpd was killed, i was able to access the web interface again. /However,/ i had to reset my login password on the pi-hole, over ssh, via:
$ sudo pihole setpassword
before i was able to actually log in. It seems the update clobbered the password.
Next, after logging in, i visited the DNS settings under System > Settings > DNS. Here, my custom DNS setting was gone, so it seems the update clobbered this, too. I re-added the
127.0.0.1#5335
entry to the "Custom DNS Servers" box at the bottom of the page (note that the interface seems to have changed here; i no longer see four boxes for custom DNS settings in the web interface; only one large box at the bottom of the page).
Once set, i logged back into the router and changed my DNS settings back to allow the pi-hole to do all DNS resolution. Things now seem to be working again.
Conclusion & Questions
I hope this helps others who may run across this issue. Follow-up comments from more knowledgeable users would be most welcome, as, while things are /working/ again, it feels a hack—for example, why do i need to kill lighttpd [edit: this is part of the update process to v6 for most users; see below]? Is this clobbering a one-time thing, or is there a deeper problem? Etc.
Thanks!
So, part of the issue is that i was unaware that this was a major update;
$ pihole -up
doesn't provide much warning. Others may wish to see the release notes here:
https://discourse.pi-hole.net/t/introducing-pi-hole-v6/75863
In particular:
Since i update over ssh, i, of course, never saw this dialog box. I suspect many others will have missed this note, too. To disable lighttpd permanently:
$ sudo systemctl lighttpd disable
I hope this additional context is helpful.
Then I guess I was right and this still applies : After update Pi-hole gone and Ubuntu damaged - #2 by nero355
I also made some instructions for a similar situation (No DNS Resolving on the Server running Pi-Hole) here : 404 and no DNS after recent update - #9 by nero355
You can change the ports used by Pi-Hole in /etc/pihole/pihole.toml and then restart Pi-Hole via systemctl restart pihole-FTL :slight_smile:
For the moment I have installed Adguard. It works but has never been as good as Pi-hole. It is said that this is the outcome of this update. A simple update which almost destroyed my home server. Maybe I come back overtime, when thing are sorted out. For the moment I am not spending time on this so called update.
