X-Header does not match or could not be retrieved in debug log
Setup
Router
Router: Fritz!Box 7390
FRITZ!OS: 06.83
IPv6: Off (my internet provider only supports IPv4
DNS Server: pi-hole IP
DHCP: off
DNS Rebind Protection, Domain name exceptions: pi.hole
Pi-hole
Board: Odroid C2
OS: DietPi
Pi-hole version is v4.0 (Latest: v4.0)
AdminLTE version is v4.0 (Latest: v4.0)
FTL version is v4.0 (Latest: v4.0)
DHCP: on
Everything is working great, however, I have a couple of issues in the debug log and wondering if someone could provide some advice on fixing them
[ DIAGNOSING ]: Dashboard and block page
[āœ—] Block page X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 403 Forbidden
Content-Type: text/html
Content-Length: 345
Date: Tue, 21 Aug 2018 08:29:56 GMT
Server: lighttpd/1.4.45
[āœ—] Web interface X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Set-Cookie: PHPSESSID=rc3029ircjd3nfgc6anmct1956; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Other
[āœ—] dnsmasq daemon is inactive
I believe this is a non issue, as in v.4 the pihole-FTL replaced the default dnsmasq daemon.
Is the above correct?
vbm181cuya
Many thanks :slight_smile:
With 4.0 the default blocking method has been modified to be NULLROUTING so this is an expected bheaviour you can learn more here
The X-Header warnings can usually be ignored if everything else seems to be working.
The dnsmasq check in the debugger will be removed in the next release, since as you point out FTL has an embedded dnsmasq already.
Thank you @technicalpyro and @Mcat12
