Can't switch privacy level through web interface
since a couple of weeks I've noticed, that the "Status" of Pi-hole on the web interface is "Unknown". This isn't a serious problem for me, since Pi-hole is blocking ads properly and according to pihole -d there seems to be no serious problem. But yesterday I tried to switch the privacy level from "Show everything and record everything" to a higher privacy level and after clicking "Apply" the changes haven't been saved.
The privacy level should be set according to the applied changes.
After clicking "Apply", the web interface gives the notification "The privacy level has been increased" but the wrong setting - in my case the lowest privacy level "Show everything and record everything" - remains set. No matter which privacy level I choose, it doesn't change after applying.
Additional Information:
The problem is pretty similar to this one. There seem to be a problem with lighttpd or www-data, but I wasn't able to solve it.
Outputs of some related commands:
$ which pihole
/usr/local/bin/pihole
$ sudo service lighttpd status -
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-07-04 23:13:11 CEST; 30min ago
Process: 524 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 798 (lighttpd)
CGroup: /system.slice/lighttpd.service
├─798 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
├─844 /usr/bin/php-cgi
├─923 /usr/bin/php-cgi
├─924 /usr/bin/php-cgi
├─925 /usr/bin/php-cgi
└─926 /usr/bin/php-cgi
Jul 04 23:42:51 raspberrypi sudo[10924]: pam_unix(sudo:auth): conversation failed
Jul 04 23:42:51 raspberrypi sudo[10924]: pam_unix(sudo:auth): auth could not identify password for [www-data]
Jul 04 23:42:57 raspberrypi lighttpd[798]: We trust you have received the usual lecture from the local System
Jul 04 23:42:57 raspberrypi lighttpd[798]: Administrator. It usually boils down to these three things:
Jul 04 23:42:57 raspberrypi lighttpd[798]: #1) Respect the privacy of others.
Jul 04 23:42:57 raspberrypi lighttpd[798]: #2) Think before you type.
Jul 04 23:42:57 raspberrypi lighttpd[798]: #3) With great power comes great responsibility.
Jul 04 23:42:57 raspberrypi lighttpd[798]: sudo: no tty present and no askpass program specified
Jul 04 23:42:57 raspberrypi sudo[10954]: pam_unix(sudo:auth): conversation failed
Jul 04 23:42:57 raspberrypi sudo[10954]: pam_unix(sudo:auth): auth could not identify password for [www-data]
Content of the file at /etc/sudoers.d/pihole :
// Pi-hole: A black hole for Internet advertisements
// (c) 2017 Pi-hole, LLC (https://pi-hole.net)
// Network-wide ad blocking via your own hardware.
// Allows the WebUI to use Pi-hole commands
// This file is copyright under the latest version of the EUPL.
// Please see LICENSE file for your rights under this license.
www-data ALL=NOPASSWD: /usr/local/bin/pihole
(Think of "#" instead of "//", didn't know how to write "#" as is, instead of making a caption)
In the output of pihole -d I noticed one error related to lighttpd:
HTTP/1.1 200 OK
Date: Fri, 05 Jul 2019 09:57:32 GMT
Server: lighttpd/1.4.45
but this seems to be normal behaviour according to this post.
I hope someone can help me.
Thanks in advance and best regards
https://tricorder.pi-hole.net/rkz381908y
This post can be closed. Finally after having a deeper look at this thread (post 29 or 30) the problem was, that www-data couldn't be executed with sudo. I simply ran:
echo 'www-data ALL = NOPASSWD : ALL' | sudo tee -a /etc/sudoers
and now the web interface is showing the current status (active) properly. I'm also able to make and save changes to the privacy settings again.
Nevertheless, thanks for this platform and your hard work!
