If you are Experiencing issues with a Pi-hole install that has non-standard elements
Mostly Standard Install. I have two ethernet ports on different subnets. One wired and one wireless. See image in first post:
https://discourse.pi-hole.net/t/dual-subnet-network-wired-wireless/46961
Hostname is incorrect in Query Log. I believe the correct hostname is MM3.localdoamin.
Shows up as an old device that now has the same IP address.
In Query Log the hostname shows up as YN1-US-*******.localdomain.
https://tricorder.pi-hole.net/aFk3Qeqb/
On the pihole box I cannot ping or nslookup the YN1-US-*******.localdomain. On a desktop computer I cannot ping or nslookup the YN1-US-*******.localdomain
Local DNS Records is empty (no entries)
Local CNAME Records is empty (no entries)
I tried:
- Rebooting the pi
- Flushing the Network Table
- Restarting DNS resolver
- -ing
No joy
EDIT:
I do not use IPv6
