Pi-hole retains Global Link IPv6 address in setupVars.conf and in admin settings UI.
Global Link IPv6 address disappears from setupVars.conf, and therefore does not appear in the UI.
cpma51tppx
Notes
I've reviewed Use IPv6 ULA addresses for Pi-hole.
At 22:17 Pacific time last night, I manually edited the setupVars.conf file and made sure the current IPv6 was listed in the file. I retrieved the IPv6 address from my RPI with the following:
ifconfig | grep 'Scope:Global' | sed -n '1p' | awk '{print $3}' | awk -F'/' '{print $1}'
I verified the timestamp of the file was:
$ ls -la setupVars.conf
-rw-r--r-- 1 pi pi 734 Mar 25 22:17 setupVars.conf
Upon checking the /etc/pihole directory this morning, the setupVars.conf file had a new timestamp of 23:00 Pacific time:
-rw-r--r-- 1 pi pi 697 Mar 25 23:00 setupVars.conf
The file size is slightly smaller, because the IPv6 value is blank again.
I ran my pihole6check script (GitHub - stevejenkins/pihole-utils: Checks the Pi-hole server's current IPv6 address and updates the IPv6 address configured in /etc/pihole/setupVars.conf if necessary.) which puts the IPv6 address back into setupVars.conf. Also, my IPv6 has not changed in the past 24 hours.
What causes the IPv6 value to disappear from setupVars.conf?
