Sure! Mind letting me know what information gets passed by sending over the token?
I thought we had an explanation of what was in the debug log somewhere.. but I can't find it! Basically copies of your configs, some key information about your system to help us troubleshoot.
If you like, you can run pihole -d and then choose no when prompted to upload it, and you can view the file locally at /var/log/pihole_debug.log to see what it contains (and then either run it again once you're happy with the contents, this time choosing yes to upload)
Some more info about how we process the logs here:
https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
Nobody has claimed the prize yet, 4 years on!
Great, can I edit the debug file and then upload the remainder to tricorder?
You sure can! See about halfway down this FAQ post:
Login into your Pi-hole's command line
Enter sudo pihole -d
Provide us with the debug token that is generated after the debug script completes
Alternative: Securely sending us additional information
Preferred Method
If there is additional information you want to provide us, you can upload any kind of text to our server. You will still get a debug token so your information will remain anonymous.
To do this, you can pipe some shell output into netcat, which will upload it to our secure server . …
Preferred Method
Here are a few examples of how you can send us this information:
VIa The pihole Command (assuming your install is not broken and the pihole command exists)
echo "hello developers" | pihole tricorder
cat some.log | pihole tricorder
pihole tricorder will always use openssl if it is available. If it’s not, it will revert to using netcat .
Via NetCat (cleartext)
echo "some text" | nc tricorder.pi-hole.net 9999
cat somefile.txt | nc tricorder.pi-hole.net 9999
tail -n4 /var/log/pihole.log | nc tricorder.pi-hole.net 9999
Via SSL (encrypted)
echo "Information to send over SSL" | openssl s_client -quiet -connect tricorder.pi-hole.net:9998 2> /dev/null
Be patient as it can sometime take a moment for it to upload. Once complete, you will receive a debug token such as 3vnm3hqwjs :
root@ubuntu:~$ echo "help me" | nc tricorder.pi-hole.net 9999
3vnm3hqwjs
When you are ready to get some help from us, give us this token and we can look up your information. Please note anything uploaded will self-destruct after 48 hours.
Just to confirm, I can do something like:
/var/log/pihole_debug.log | pihole tricorder
cat /var/log/pihole_debug.log | pihole tricorder or cat <anything> | pihole tricorder.
There are limits on the size of things that will be accepted.
