Some sites won't let you get at the content you want until you turn off your ad-blocker. Will this happen with pi-hole? And if so, is there a quick/easy way (like a browser extension) to temporarily (or even permanently) disable it for the current site?
There are anti adblock adlists
You can just ad them to you'r pihole in most of the time it works then.
you can finde some here:
Direct link:
https://raw.githubusercontent.com/reek/anti-adblock-killer/master/anti-adblock-killer-filters.txt
just go to your interface then add this link and it should work then
maby flush you'r DNS logs on your computer to
I've found some sites have a button that says "OK, I've disabled my blocker" (even though you don't) it still works to click past it.
But otherwise those blocker-block lists may help. Is there a specific site you are having trouble with?
