website should load
i notice that some https websites are being blocked for example https:discogs.com. website loads with pihole disabled.
6u3zgfi3db
mibere
September 15, 2017, 7:10pm
2
Had the same problem, enabling IPv6 ULA in my router solved it.
I am using ip4, only time i am on ip6 is when the VPN is on.
so this is what it should look like?
Mcat12
September 15, 2017, 10:19pm
6
I believe so. Do websites still time out?
I am going to further test. If i have a problem i will post back. thank you for all the replys.
I am afraid other stuff is still being blocked. my daughters tablet can not reach youtube when the pihole is enabled.
Edit: this is odd, i can disable it, go to the site, reenable it and it works?
Mcat12
September 16, 2017, 5:46pm
9
Sounds like the cache is still kept when it works. Have you tried whitelisting domains based on the query log?
I have, but i do not see anything that has to do with youtube.
Mcat12
September 16, 2017, 6:25pm
11
It's hard, but if it's Pi-hole it's somewhere in the logs.
man i guess so, i am whitelisting everything that comes up. now another app "postemates" is blocked. the app just spins upon opening until i disable pihole.
Mcat12
September 17, 2017, 12:53am
13
Try tailing the log (pihole -t) and then opening the app. It might show you want domains are being requested by the app.
I followed the log and also do not see anything being piholed. could it be something i have on my adlist?
Mcat12
September 17, 2017, 6:13pm
15
Maybe? You might not have seen anything in the log because the request was cached already.
ok so how do i clear the cache on pihole? here is a copy of my adlist.
Edit: seems pihole restartdns clears the cache.
Mcat12
September 17, 2017, 6:37pm
17
Clear the cache on your client device. In the case of a mobile phone, you usually need to either turn the wifi on and off or restart the device.
