/var/log in Top Permitted Domains
[Why is it showing up ?]
[Tried but it's running for 10 minutes and it's stuck at "*** [ DIAGNOSING ]: Dashboard and block page"]
Somehow in my permitted domains i got the following 2 entry's showing up.
/dev/log
/dev/log.mydomainname
is there a way to ignore them ?
And why does it show up,
tried searching but couldn't find anything about it perhaps the words are to search to search for it.
Strange... Can you send pihole_debug-sanitized.log to us to see where it stopped?
cat /var/log/pihole_debug-sanitized.log | pihole tricorder
And also grab a snippet of the pihole.log with those entries or the timeframe in which they occurred.
Weird it works now to make a debug log,
perhaps it needed a reboot to make it work not sure.
debug token is:
tunoqne6j4
the token for the pihole_debug-sanitized.log
vaxz77dmo1
Snippet of the pihole.log
gjxkpnaii4
That IP showing up the the Snippet would be a VMWare i'm running that runs a Debian instance.
Sorry, I missed the cutoff and your submissions expired. Would you send the pihole_debug-sanitized.log again?
fh6f75z4me
I didn't see anything out of the ordinary there. Did you have a token for the pihole.log as well?
7bhejwszhl
I see the entries. What device is 192.168.2.100? Perhaps that will offer some clues.
it's a vmware that is running debian with some services,
nzbget, sonarr, autosub and nzbhydra etc.
it has been running without anychanges before i had pi-hole running and these entry's just showed up a few weeks ago.
But it's kinda weird it shows up and i'm not able to add them to the Exclude from Top Domains / Top Advertisers from the web interface.
There does not seem to be a Pi-hole issue here, as those queries are for invalid domains. Perhaps we could allow invalid domains to be used in the exclusion list (open a feature request for this if you want).
