Using Pi-hole to push a static route to clients
I'm using Pi-hole 5.1.2 and FTL 5.2 on a Raspberry Pi. It's setup by a DNS and DHCP server. All seems to be working fine (aside from issue mentioned here) and I can use my network normally.
In a similar vein to the post below, I'm trying to push a static route to clients.
In this post, it seems the change actually takes effect after they run this command.
sudo dhclient -r wlan0; sudo dhclient wlan0
However mine just hangs. Using the verbose option I can see it repeats this over and over.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
And when I run ip r I can never get the line I'm looking for. In the post above that line is the following (my IPs are slightly different of course)
206.189.252.0/24 via 10.0.0.99 dev wlan0
Any ideas?
I'm happy to provide more information, I just didn't want to go too lengthy in this post. Thanks!
Commands from that link are executed on different hosts pi@noads & the Debian client deHakkelaar@laptop.
You need to renew the DHCP lease on the client for the new route to propagate.
And of course check routes on the client and not check routes on Pi-hole.
Of course! It was right in front of me and I didn't see it, and it turns out it was actually working all along. Thanks :slight_smile:
The only slight niggle I see is that while it seems to work on my Ubuntu and Windows machine, running ip r (using Termux) on Android doesn't show the route.
In my use case it's actually not a big problem so I'm not too fussed, but do you know why it might not appear in Android?
I dont know for sure.
It feels like Termux uses an entirely different environment.
Even if you do a nslookup in Termux, it always persists on using 8.8.8.8 for DNS instead of the Android configured DNS servers.
