Pihole DHCP: push a static route to clients
Hello there.
I'm using pi-hole 4.3 with FTL 4.3.1 on a Raspbian 9 machine.
I've enabled the builtin DHCP server in pi-hole and it's working great so far!
Question is, how can I - if at all - push any static routes to to my clients
using the builtin DHCP server?
Thanks,
/tom
You can use the classless-static-route DHCP option but you will need to push the default route as well through this option.
In below example, 10.0.0.1 is my router and I am adding a route to 206.189.252.0/24 via 10.0.0.99.
pi@noads:~ $ man dnsmasq
       -O,            --dhcp-option=[tag:<tag>,[tag:<tag>,]][encap:<opt>,][vi-
       encap:<enterprise>,][vendor:[<vendor-class>],][<opt>|option:<opt-
       name>|option6:<opt>|option6:<opt-name>],[<value>[,<value>]]
              Specify  different or extra options to DHCP clients. By default,
              dnsmasq sends some standard options to DHCP clients, the netmask
              and  broadcast  address  are set to the same as the host running
              dnsmasq, and the DNS server and default route  are  set  to  the
              address  of the machine running dnsmasq. (Equivalent rules apply
              for IPv6.) If the domain name option has been set, that is sent.
              This  configuration  allows  these defaults to be overridden, or
              other options specified. The option, to be sent may be given  as
              a decimal number or as "option:<option-name>" The option numbers
              are specified in RFC2132 and subsequent RFCs. The set of option-
              names  known  by  dnsmasq  can be discovered by running "dnsmasq
              --help dhcp".  For example, to set the default route  option  to
              192.168.4.4,  do  --dhcp-option=3,192.168.4.4 or --dhcp-option =
              option:router, 192.168.4.4 and to set the time-server address to
              192.168.0.4,  do --dhcp-option = 42,192.168.0.4 or --dhcp-option
              = option:ntp-server, 192.168.0.4 The special address 0.0.0.0  is
              taken to mean "the address of the machine running dnsmasq".
              Data   types   allowed  are  comma  separated  dotted-quad  IPv4
              addresses, []-wrapped IPv6 addresses, a decimal  number,  colon-
              separated hex digits and a text string. If the optional tags are
              given then this option is  only  sent  when  all  the  tags  are
              matched.
pi@noads:~ $ dnsmasq --help dhcp
Known DHCP options:
121 classless-static-route
pi@noads:~ $ echo 'dhcp-option=option:classless-static-route,0.0.0.0/0,10.0.0.1,206.189.252.0/24,10.0.0.99' | sudo tee /etc/dnsmasq.d/99-my-settings.conf
pi@noads:~ $ sudo service pihole-FTL reload
pi@noads:~ $
deHakkelaar@laptop:~$ ip r
default via 10.0.0.1 dev wlan0
10.0.0.0/24 dev wlan0 proto kernel scope link src 10.0.0.220
deHakkelaar@laptop:~$ sudo dhclient -r wlan0; sudo dhclient wlan0
Killed old client process
206.189.252.0/24 via 10.0.0.99 dev wlan0
Works like a charm! Thanks a lot!
