Using a VPN with pi-hole
The issue I am facing:
I want to use a VPN service which I can easily toggle on and off. Using a VPN in my device renders pi-hole useless as all the communication is encrypted. Setting it on the pi-hole server is no that practical as I can’t control it easily.
Details about my system:
Latest Pi-hole Raspberry Pi
Nothing yet
Did you have a look at PiHole with OpenVPN the easy way — use PiVPN ?
