Upgrade from 4.0
upgrade run, dns reported as not started.
ran pihole -r, noticed error ftl not installed from github.
modified etc/pihole/install.log to 8.8.8.8, reran pihole -r. still no luck
web page reports: DNS service not running FTL offline
cnspidduf6
I got the same issue heer.
Running Ubuntu 18.4
Dansmarathon unaniem to open port. On x.x.x.x address already in Use.
Bind is NOT installed
You mean you modified /etc/resolv.conf with nameserver 8.8.8.8 right ?
Can you post full output of the pihole -r output ?
Keep in mind, I believe resolv.conf gets modified back every time you run pihole -r or pihole -up.
Better create you own thread as your issue seems different.
Chances are you have another DNS daemon running on ports 53 TCP/UDP, not pihole-FTL:
pi@noads:~ $ sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 20855/pihole-FTL
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 8101/lighttpd
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 20855/pihole-FTL
tcp6 0 0 ::1:4711 :::* LISTEN 20855/pihole-FTL
tcp6 0 0 :::80 :::* LISTEN 8101/lighttpd
tcp6 0 0 :::53 :::* LISTEN 20855/pihole-FTL
udp 0 0 0.0.0.0:53 0.0.0.0:* 20855/pihole-FTL
udp 0 0 0.0.0.0:67 0.0.0.0:* 20855/pihole-FTL
udp6 0 0 :::53 :::* 20855/pihole-FTL
Thanks for the heads up., but my issue WAS the same.
Autocorrect has been over active!
I got Dns running now! And the adds are blocked! So the primary goal is reached.
I removed the # before dns=5353 in /etc/dnsmasq.conf
But yes there is a catch. The counters in the admin page remain zero.
I will keep searching
Sorry I thought I deleted this topic, but since it's still here.
Yes, that's correct.
Unfortunately, to get this resolved, I wound up reimaging the pi. A new installation of 4.0 is now working.
It does not from what I could see trying pihole -r multiple times.
pi@noads:~ $ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 8.8.8.8
pi@noads:~ $ pihole -r
nameserver 127.0.0.1
