Thanks for checking those. And that first one was ran in a terminal on the Pi-hole directly?
If so, those results imply that something on the Pi-hole OS really is interfering with DNS, even though the debug log showed that FTL was runnning that service.
You can create another debug log if you want, but I don't recall seeing anything that was messing with FTL.
What does anyone else/devs think?
It seems like there are all kinds of things interfering here, since an earlier test eliminated Pi-hole and the home network and pointed at external interference. Yet this test shows that nslookup on localhost cannot get Pi-hole's version from the CH TXT record, which is probably why Windows also cannot access it from another host.
This is the kind of situation where, if I was there, I'd want to take an approach like Moto suggested and scrap absolutely everything and start over with one machine and router, test, and build up from there. Once the Pi-hole becomes involved, I'd start with a clean install of the latest OS, test that and install Pi-hole, test again and ensure everything is working. At the very end I would add Unbound. At any point, the testing might show that results are not as expected and this will reveal the cause.
BengalEmpire767's unbound log demonstrates that the issue is lack of connectivity to the root servers:
That would be expected if something upstream is blocking access to the root servers (at least for port 53). If it is not a local firewall on the Pi-hole machine or the router blocking access, then something outside of your network's control is doing so, e.g. your ISP.
As I see it, deHakkelaar has supplied the best advice already:
