Unbound is forwarding to Cloudflare
So I just got unbound configured and it’s forwarding to Cloudflare, is this normal?
No.
If configured according to the official guide, Unbound will traverse the DNS tree recursively to find an authoritative DNS server for a particular domain/zone starting at the root servers below:
$ cat /usr/share/dns/root.hints
;       This file holds the information on root name servers needed to
;       initialize cache of Internet domain name servers
;       (e.g. reference this file in the "cache  .  <file>"
;       configuration file of BIND domain name servers).
;       This file is made available by InterNIC
;       under anonymous FTP as
;           file                /domain/named.cache
;           on server           FTP.INTERNIC.NET
;       -OR-                    RS.INTERNIC.NET
;       last update:     April 18, 2024
;       related version of root zone:     2024041801
; FORMERLY NS.INTERNIC.NET
.                        3600000      NS    A.ROOT-SERVERS.NET.
A.ROOT-SERVERS.NET.      3600000      A     198.41.0.4
A.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:ba3e::2:30
; FORMERLY NS1.ISI.EDU
.                        3600000      NS    B.ROOT-SERVERS.NET.
B.ROOT-SERVERS.NET.      3600000      A     170.247.170.2
B.ROOT-SERVERS.NET.      3600000      AAAA  2801:1b8:10::b
; FORMERLY C.PSI.NET
.                        3600000      NS    C.ROOT-SERVERS.NET.
C.ROOT-SERVERS.NET.      3600000      A     192.33.4.12
C.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2::c
; FORMERLY TERP.UMD.EDU
.                        3600000      NS    D.ROOT-SERVERS.NET.
D.ROOT-SERVERS.NET.      3600000      A     199.7.91.13
D.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2d::d
; FORMERLY NS.NASA.GOV
.                        3600000      NS    E.ROOT-SERVERS.NET.
E.ROOT-SERVERS.NET.      3600000      A     192.203.230.10
E.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:a8::e
; FORMERLY NS.ISC.ORG
.                        3600000      NS    F.ROOT-SERVERS.NET.
F.ROOT-SERVERS.NET.      3600000      A     192.5.5.241
F.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2f::f
; FORMERLY NS.NIC.DDN.MIL
.                        3600000      NS    G.ROOT-SERVERS.NET.
G.ROOT-SERVERS.NET.      3600000      A     192.112.36.4
G.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:12::d0d
; FORMERLY AOS.ARL.ARMY.MIL
.                        3600000      NS    H.ROOT-SERVERS.NET.
H.ROOT-SERVERS.NET.      3600000      A     198.97.190.53
H.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:1::53
; FORMERLY NIC.NORDU.NET
.                        3600000      NS    I.ROOT-SERVERS.NET.
I.ROOT-SERVERS.NET.      3600000      A     192.36.148.17
I.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fe::53
; OPERATED BY VERISIGN, INC.
.                        3600000      NS    J.ROOT-SERVERS.NET.
J.ROOT-SERVERS.NET.      3600000      A     192.58.128.30
J.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:c27::2:30
; OPERATED BY RIPE NCC
.                        3600000      NS    K.ROOT-SERVERS.NET.
K.ROOT-SERVERS.NET.      3600000      A     193.0.14.129
K.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fd::1
; OPERATED BY ICANN
.                        3600000      NS    L.ROOT-SERVERS.NET.
L.ROOT-SERVERS.NET.      3600000      A     199.7.83.42
L.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:9f::42
; OPERATED BY WIDE
.                        3600000      NS    M.ROOT-SERVERS.NET.
M.ROOT-SERVERS.NET.      3600000      A     202.12.27.33
M.ROOT-SERVERS.NET.      3600000      AAAA  2001:dc3::35
So I followed the guide to the T. But I had to force it to populate all the config files. How do I fix it so I can get away from Cloudflare
How did you determine queries are being forwarded to Cloudflare?
Post output for below one pls?
sudo rgrep -v '^ *\(#\|$\)' /etc/unbound/unbound.conf*
I used dnsleaktest.com
/etc/unbound/unbound.conf:include-toplevel: "/etc/unbound/unbound.conf.d/\*.conf"
/etc/unbound/unbound.conf.d/remote-control.conf:remote-control:
/etc/unbound/unbound.conf.d/remote-control.conf:  control-enable: yes
/etc/unbound/unbound.conf.d/remote-control.conf:  control-interface: /run/unbound.ctl
/etc/unbound/unbound.conf.d/pi-hole.conf:    do-ip6: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:    edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf:    private-address: 192.0.2.0/24
/etc/unbound/unbound.conf.d/pi-hole.conf:    private-address: 198.51.100.0/24
/etc/unbound/unbound.conf.d/pi-hole.conf:    private-address: 203.0.113.0/24
/etc/unbound/unbound.conf.d/pi-hole.conf:    private-address: 255.255.255.255/32
/etc/unbound/unbound.conf.d/pi-hole.conf:    private-address: 2001:db8::/32
Most likely its not reporting correctly.
What does below output?
sudo unbound-control lookup .
From above, do you have native IPv6 support by your ISP upstream if check with below link?
If you dont, better flip above do-ip6 setting to no.
I’m getting
this option requires a domain name
You most likely missed copying/pasting the last dot ".":
The dot represents the root domain.
The following name servers are used for lookup of .
;rrset 80112 13 1 8 0
.       80112   IN      NS      a.root-servers.net.
.       80112   IN      NS      b.root-servers.net.
.       80112   IN      NS      c.root-servers.net.
.       80112   IN      NS      d.root-servers.net.
.       80112   IN      NS      e.root-servers.net.
.       80112   IN      NS      f.root-servers.net.
.       80112   IN      NS      g.root-servers.net.
.       80112   IN      NS      h.root-servers.net.
.       80112   IN      NS      i.root-servers.net.
.       80112   IN      NS      j.root-servers.net.
.       80112   IN      NS      k.root-servers.net.
.       80112   IN      NS      l.root-servers.net.
.       80112   IN      NS      m.root-servers.net.
.       80112   IN      RRSIG   NS 8 0 518400 20260304170000 20260219160000 21831 . b3ogwpEmK+uUwUhsj3IwIGALm3V8FRGQur1fLCxG/WTwczuWJ603jF0eirVg4m3Jud3GawoFtodoSV0+V1K03XRDocRhMadX5ysvk0zCUBgP4py98Xjpiekr+uI0E9yjtKIZfaLifjBYhhYPrHvl1asGpZmcZ38WY1MZDpQSRpuhZyzhQuh33EIvx7OFEvIoHiCGrMcRm+3Ue1KONAVZxWJ3BC5m8cWmiIaGx+SzgOoNlyQ5FVqWCk+c+8WP2h92K+X4QEf4w86FYqqmAfSRgwnczlzrYonqCp3maBsRt0Y5PmGeNJlzPU+UOV8jcZ8GSqKGsdIN8USGtFqu1TG7wg== ;{id = 21831}
;rrset 80112 1 0 8 0
m.root-servers.net.     80112   IN      A     202.12.27.33
m.root-servers.net.     80112   IN      AAAA  2001:dc3::35
l.root-servers.net.     80112   IN      A     199.7.83.42
l.root-servers.net.     80112   IN      AAAA  2001:500:9f::42
;rrset 80112 1 0 3 0
k.root-servers.net.     80112   IN      A     193.0.14.129
k.root-servers.net.     80112   IN      AAAA  2001:7fd::1
j.root-servers.net.     80112   IN      A     192.58.128.30
j.root-servers.net.     80112   IN      AAAA  2001:503:c27::2:30
i.root-servers.net.     80112   IN      A     192.36.148.17
i.root-servers.net.     80112   IN      AAAA  2001:7fe::53
h.root-servers.net.     80112   IN      A     198.97.190.53
h.root-servers.net.     80112   IN      AAAA  2001:500:1::53
g.root-servers.net.     80112   IN      A     192.112.36.4
g.root-servers.net.     80112   IN      AAAA  2001:500:12::d0d
f.root-servers.net.     80112   IN      A     192.5.5.241
f.root-servers.net.     80112   IN      AAAA  2001:500:2f::f
e.root-servers.net.     80112   IN      A     192.203.230.10
e.root-servers.net.     80112   IN      AAAA  2001:500:a8::e
d.root-servers.net.     80112   IN      A     199.7.91.13
d.root-servers.net.     80112   IN      AAAA  2001:500:2d::d
c.root-servers.net.     80112   IN      A     192.33.4.12
c.root-servers.net.     80112   IN      AAAA  2001:500:2::c
b.root-servers.net.     80112   IN      A     170.247.170.2
b.root-servers.net.     80112   IN      AAAA  2801:1b8:10::b
a.root-servers.net.     80112   IN      A     198.41.0.4
a.root-servers.net.     80112   IN      AAAA  2001:503:ba3e::2:30
Delegation with 13 names, of which 0 can be examined to query further addresses.
It provides 26 IP addresses.
2001:503:ba3e::2:30     rto 376 msec, ttl 188, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
198.41.0.4              rto 301 msec, ttl 188, ping 1 var 75 rtt 301, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
2801:1b8:10::b          rto 376 msec, ttl 488, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
170.247.170.2           rto 302 msec, ttl 484, ping 2 var 75 rtt 302, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
2001:500:2::c           not in infra cache.
192.33.4.12             not in infra cache.
2001:500:2d::d          rto 376 msec, ttl 188, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
199.7.91.13             rto 243 msec, ttl 484, ping 3 var 60 rtt 243, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
2001:500:a8::e          not in infra cache.
192.203.230.10          rto 177 msec, ttl 188, ping 1 var 44 rtt 177, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
2001:500:2f::f          not in infra cache.
192.5.5.241             not in infra cache.
2001:500:12::d0d        not in infra cache.
192.112.36.4            not in infra cache.
2001:500:1::53          not in infra cache.
198.97.190.53           not in infra cache.
2001:7fe::53            not in infra cache.
192.36.148.17           not in infra cache.
2001:503:c27::2:30      not in infra cache.
192.58.128.30           rto 315 msec, ttl 488, ping 3 var 78 rtt 315, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
2001:7fd::1             not in infra cache.
193.0.14.129            not in infra cache.
2001:500:9f::42         not in infra cache.
199.7.83.42             rto 566 msec, ttl 187, ping 58 var 127 rtt 566, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
2001:dc3::35            rto 376 msec, ttl 188, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
202.12.27.33            not in infra cache.
Also my ISP does not support ipv6
Those are the root servers and not those of Cloudflare (1.1.1.1 or 1.0.0.1).
So flip below one:
And restart to apply:
sudo systemctl restart unbound.service
Its still using Cloudflare through dnsleaktest
Well Unbound doesnt query the Cloudflare servers.
Maybe you have a DNS leak somewhere.
For that I would suggest you open a new help topic including a debug token.
As this doesnt seem related to Unbound.
Ok, thank you for your time
It may be from my secondary pihole, so I’ll disable ipv6 on that as well
Dont need to disable anything IPv6 related in your network or on the O-Pi if below one run on the O-Pi doesnt return an IP (or multiple):
ip -br -6 address show scope global
Dont post IPv6 addresses here for privacy!
Is it possible you have cloudflare enabled as a DNS-over-HTTPS server in your browser that you're using to run leaktest?
I figured it out…. I was using dnsleaktest on my iPhone with Brave browser. Upon reading into it Cloudflare is hardcoded into the app.
Most Likely below setting that needs to be DISABLED or it will allow leaking:
