thanks again.
I've never noticed earlier any such issues - though, I don't always review everything...
I tried fsck, not sure at this point how to proceed...
~ $ sudo pihole -g
[✓] DNS resolution is available
[✓] Creating new gravity databases
[i] Using libz compression
[✓] Parsed 117214 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
[i] List stayed unchanged
[i] Target: https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/SmartTV.txt
[✓] Parsed 242 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
[i] Target: https://v.firebog.net/hosts/static/w3kbl.txt
[✓] Status: No changes detected
[✓] Parsed 351 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
[i] Target: https://raw.githubusercontent.com/d3ward/toolz/master/src/d3host.txt
[✓] Parsed 131 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
[i] Target: https://raw.githubusercontent.com/MajkiIT/polish-ads-filter/master/polish-pihole-filters/hostfile.txt
[✓] Parsed 318 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
[i] Target: https://raw.githubusercontent.com/hkamran80/blocklists/main/smart-tv.txt
[✓] Parsed 290 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
[✓] Building tree
[i] Number of gravity domains: 118546 (118007 unique domains)
[i] Number of exact denied domains: 0
[i] Number of regex denied filters: 0
[i] Number of exact allowed domains: 0
[i] Number of regex allowed filters: 0
[✓] Optimizing database
[✓] Swapping databases
[✓] The old database remains available
[✓] Cleaning up stray matter
[✓] Done.
~ $ df -H
Filesystem Size Used Avail Use% Mounted on
udev 1.8G 0 1.8G 0% /dev
tmpfs 398M 55M 344M 14% /run
/dev/mmcblk0p2 16G 8.1G 6.2G 57% /
tmpfs 2.0G 2.2M 2.0G 1% /dev/shm
tmpfs 5.3M 17k 5.3M 1% /run/lock
/dev/mmcblk0p1 535M 80M 456M 15% /boot/firmware
tmpfs 33M 447k 33M 2% /var/cache/fontconfig
tmpfs 398M 46k 398M 1% /run/user/1000
:~ $ sudo fsck /dev/mmcblk0p1
fsck from util-linux 2.38.1
fsck.fat 4.2 (2021-01-31)
There are differences between boot sector and its backup.
This is mostly harmless. Differences: (offset:original/backup)
65:01/00
- Copy original to backup
- Copy backup to original
- No action
[123?q]? q
65:01/00
- No action
[123?q]? 1
Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
- Remove dirty bit
- No action
[12?q]? 1
*** Filesystem was changed ***
The changes have not yet been written, you can still choose to leave the
filesystem unmodified:
- Write changes
- Leave filesystem unchanged
[12?q]? 1
/dev/mmcblk0p1: 395 files, 38795/261115 clusters
