Problem:
Temporary failure in name resolution when pinging website
Expected Behavior:
Resolves name when using ping google.com
Actual Behavior:
Returns "temporary failure in name resolution", pinging 8.8.8.8 or similar has no issues
Background:
Could not reach pihole servers to update to v6
Followed info in DNS Issue - Temporary failure in name resolution and DNS broken only on localhost
Sucessfully updated to v6
changing the file resolv.conf is back to its default 127.0.0.1 upon reboot -> ping: google.com
yields Temporary failure in name resolution
The {ipaddressOfPi}/admin yields 403 error regardless of what is in the resolv.conf
Adding the pi as the DNS server under the DHCP settings of my router also causes name resolution failures
https://tricorder.pi-hole.net/gK41vudo/
nero355
February 21, 2025, 3:58pm
2
Do you have any Upstream DNS Server configured ?!
Many seem to have some weird issue after the upgrade at the moment with their Upstream DNS Server disappearing for some reason...
I checked and yes, I have OpenDNS configured upstream. So it hasn't disappeared as far as I can tell.
from /etc/pihole/setupVars.conf
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
(sourced from Upstream DNS Providers - Pi-hole documentation )
nero355
February 21, 2025, 5:24pm
4
Those should be configured in /etc/pihole/pihole.toml for Pi-Hole v6 ?!
Ah! I see what you meant about the upstream DNS servers disappearing.
I modified it to upstreams= ["208.67.222.222", "208.67.220.220"]
which resolved the problem.
Thanks!
system
Closed
March 14, 2025, 6:28pm
6
