*Temp Solution in Reply* DNS-Over-HTTPS not working after updating to V6
I've had an RPI setup using the cloudflared DNS-Over-HTTPS for years. Originally with a RPI 4, now with a newer RPI5 like a year or 2 ago
Last night I stupidly updated pi-hole and it failed so reimaged it with new raspian lite and did a clean install then followed the same instructions for cloudflared DNS-Over-HTTPS at cloudflared (DoH) - Pi-hole documentation
After changing to custom server 127.0.0.1#5053 it does not work. If I delete the custom server and check the 2 defualt boxes for Cloudflare DNSSEC its back up and running
I'd really like to get my DNS-Over-HTTPS back up and running - any help would be greatly appreciated
Working debug when using the defualt upstream 2 IPv4 check boxes for Cloudflare (DNSSEC) https://tricorder.pi-hole.net/cpIyrqAn/
Non-working debug After unchecking the 2 boxes for IPv4 for the Cloudflare (DNSSEC) and entering the custom server 127.0.0.1#5053 https://tricorder.pi-hole.net/1qvp8gd2/
I just found its a known issue and theres a quick easy fix for this.
go to Settings>All Settings>Miscellaneous>misc.dnsmasq_lines and add this text in between the quotes "no-0x20-encode" and save
And be sure the custom server says 127.0.0.1#5053 like it says in DoH instructions
Source:
You can verify its working by going to 1.1.1.1 — One of the Internet’s Fastest, Privacy-First DNS Resolver it will tell you if DoH is working
Hopefully a real fix comes out for it
I'm having the same exact issue!
tried updating to V6 and it failed - did a fresh raspian lite image installed exactly how i had it before but when installing the cloudflared DOH DNS-over-HTTPS, removing the custom server and selecting the default Cloudflare (DNSSEC) got it working but I would like to have my cloudflared (DoH) back up and running
Here's my help post
You won't see it anymore.
For security reasons the user used to run the web interface was changed and it doesn't have enough permissions to execute the debug log.
You will need to execute pihole -d on a terminal.
Source:
