wooar
February 23, 2020, 12:12pm
1
I have installed stable version for i686 platform (debian)
If i press "enable" from web interface the state remain unknown (orange) and in error.log i read:
sudo: PERM_ROOT: setresuid(0, -1, -1): Operation not permitted
sudo: unable to initialize policy plugin
[Sun Feb 23 11:02:44.078313 2020] [php7:warn] [pid 26472] [client 172.16.1.239:61729] PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/admin/api.php on line 47, referer: http://172.16.1.1/admin/settings.php?tab=blocklists
jfb
February 23, 2020, 12:35pm
2
Tools > Generate Debug Log
wooar
February 23, 2020, 1:44pm
3
How i can upload the debug log?
Would you like to upload the log? [y/N] y
Please try again or contact the Pi-hole team for assistance.
A local copy of the debug log can be found at: /var/log/pihole_debug.log
jfb
February 23, 2020, 2:16pm
4
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run pihole -d and upload the debug log
wooar
February 23, 2020, 2:24pm
5
nothing....
root@apu:/var/www/admin# cat /etc/resolv.conf
Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
127.0.0.53 is the systemd-resolved stub resolver.
run "systemd-resolve --status" to see details about the actual nameservers.
nameserver 9.9.9.9
jfb
February 23, 2020, 5:11pm
9
You are running an unsupported OS (Bullseye) and there are configuration problems with the connectivity on the device.
*** [ DIAGNOSING ]:e[0m Networking [✓] IPv4 address(es) bound to the vlan2 interface: 169.254.105.110/16e[0m does not match the IP found in /etc/pihole/setupVars.conf Use IPv6 ULA addresses for Pi-hole
[i] Default IPv4 gateway: ppp0 192.168.1.1 *
Pinging ppp0 192.168.1.1...
Gateway did not respond https://discourse.pi-hole.net/t/why-is-a-default-gateway-important-for-pi-hole/3546e [0m)
wooar
February 23, 2020, 5:15pm
10
jfb:
Bullseye
vlan2+wlan0 are in bridge
The used interface is br0
192.168.1.1 is not a real gw
ppp0 is wan interface
DNS work but i have sudo error with web interface
jfb
February 23, 2020, 5:16pm
11
You are running on an unsupported OS, so there may be dependency or other problems.
wooar
February 23, 2020, 5:30pm
12
why sudo fail?
Your answer is too generic
That's an OS level error, not anything related to Pi-hole.
Edit: A google search of that error leads to LDAP issues.
Edit2: Check the permissions on /etc/sudoers and /etc/sudoers.d they are likely wrong.
wooar
February 23, 2020, 6:21pm
15
it's the first time I've seen such an uncontrolled use of sudo in php pages.
It is surely an unsafe solution
I don't use ldap modules for apache and the installed php libraries are 7.3
It's not uncontrolled. There is a pihole user that is granted ability to run a very specific and limited number of functions.
The code has been reviewed and checked for vulnerabilities and all issues have been addressed.
Check the permissions of the /etc/sudoers and the sudoers.d directory to see what they are set to.
system
Closed
March 15, 2020, 6:39pm
17
