One-Step Automated Install with "curl -sSL https://install.pi-hole.net | bash"
- Operating System: Ubuntu 26.04.1 LTS
- Hardware: BOSGAME E2 Mini PC (3550H 16GB Ram 512GB SSD)
It's stuck on
[i] Root user check
[i] Script called with non-root privileges
The Pi-hole requires elevated privileges to install and run
Please check the installer for any concerns regarding this requirement
Make sure to download this script from a trusted source
[✓] Sudo utility check
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[✓] Building dependency package pihole-meta.deb
[✓] Installing Pi-hole dependency package
I have tried re-installing OS and using the install cmd again and waited a few mins and I think it's just stuck for some reason.
