Error when searching for new songs on spotify
and when i try to get on to some internet sites it doesn't load it up or it just takes about 10 min
on ad-free pages!
do you guys have any ideas whats to do?
thanks for any help!!!
on ad-free pages!
Did you check Why doesn't Spotify work using Pi-hole? - FAQs - Pi-hole Userspace?
Also post the debug token after generating a debug log. Select 'Y' when asked to upload, to get the token.
@spacemonkey I did that spotify is okay now but with other important internet sites like the regional train info site
http://fahrplan.sbb.ch/bin/query.exe/de does not work how can i whitelist those?
The page loaded fine on my end. I was also able to search for a timetable successfully.
Please get and post back here, the debug token from Tools -> Generate debug log from http://pi.hole/admin/ so that the devs could narrow down you issue when they see this.
If you set the Pi-hole to reject connections on port 443 instead of dropping them, then the websites should stop taking so long to load. What is happening is that the blocked ads going over https hit Pi-hole's port 443, which basically ignores the connection and causes the web site to wait until the timeout before giving up on the request.
Okay so if i close the port completly it should be okay then
Thanks
